Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 11th March 2010, 15:57   #16
Hashim's Avatar
Thanked: 32 Times
Sure it will work, infact right now my gladiator battery is also on charge right now after filling magnesium sulphate solution. Its 2006 year make battery of Exide that came with bike was was not able to start the bike with self. OT: I am using 7.5Ah SMF computer UPS battery in my bike LOL.
All of you guys who try this tip, do post the results
Hashim is offline   Reply With Quote
Old 11th March 2010, 16:19   #17
Fordmanchau's Avatar
Thanked: 302 Times
Hashim, I too have a Gladiator Jun 2006 model, and the original battery is dead after serving for 2.5 years. It's still stuck in the bike. I took it to a shop for charging but the person asked me to discard it and get a new one.
My question is ?
1) how much will a 5ah charger cost?
2) and how much does a 2 teaspoon of Magnesium sulphate will cost. I have to find out from where I can source it.
I have zero technical knowledge. I'll see what I can do.
Fordmanchau is offline   Reply With Quote
Old 11th March 2010, 16:31   #18
Hashim's Avatar
Thanked: 32 Times
1.Please don't use 5 Ah charger for charging gladiator battery. Use 12v 1Ah charger. Don't know cost of charger as I built my own. Cost of making was about Rs.100/-
2. Almost free, get it from chemistry lab of any school. I got from my chemistry department lab. Its not a costly stuff. Also 2 spoon quantity was for car battery (as more electrolyte is needed to be prepared), for bike I used slightly more than half teaspoon.
Old 2nd April 2010, 20:51   #19
bj96's Avatar
Thanked: 130 Times
Originally Posted by Nilesh5417 View Post
My bullet battery is dead and i wasnt getting a 14ah battery...
OT: since, you are in Pune try following place
Sandesh Auto,
Opposite Karishma Society,
Karve Nagar, Karve Road, Pune.
This is where I found the Exide Backer 14AH battery, after recommendation from a friend. Its working for ~2yrs now.
Seriously, it is about time others (e.g. Amaron etc) too start making 14AH battery- there are too many REI ES bikes on streets now.
-BJ
bj96 is offline   Reply With Quote
Old 12th April 2010, 22:10   #20
rm_arjuna's Avatar
Thanked: 55 Times
today my battery conked off , after jump starting the mechanic showed small bubbles in the liquid and told that battery has died and cannot be charged is it true. my battery is 4 yrs old.
rm_arjuna is offline   Reply With Quote
Old 13th April 2010, 12:35   #21
Hashim's Avatar
Thanked: 32 Times
For a 4 year old battery maybe its time to change it. Bubbles as far as I know only indicate that battery is indeed charging and not dead. After the jump start were you able to crank the car, at least once?
Old 13th April 2010, 15:33   #22
rm_arjuna's Avatar
Thanked: 55 Times
car was idiling for few minutes, could not crank for second time and had to jump start again .
Old 16th September 2010, 22:02   #23
Thanked: 36 Times
Thanks, it is very informative.
Please PM me or post a tutorial about how to make a bike battery charger. My bike is a Pulsar 200 with a stock battery.
Please update soon.
abhipuru16 is offline   Reply With Quote
Old 17th September 2010, 10:15   #24
Hashim's Avatar
Thanked: 32 Times
Please update soon.
Here is a charger circuit I made using real pictures of components (except transformer as I could not find appropriate photo) so that there is no confusion while making the charger Part numbers are also there in diagram, just get the components and connect them exactly they are in diagram. Using thick copper wires for making connection. Assemble it on a PCB or a piece of plastic then house it in a small voltage stabilizer cabinet. I am sure you can find one dead stabilizer at home and use its cabinet. At the end of wires going to batteery terminal, attach crocodile clips.
This charger is good for most bikes battery 5Ah to 9Ah, if you want quicker charging, use 2Ah transformer. Rest of the components remain same.
Hashim is offline   (1) Thanks Reply With Quote
Old 17th September 2010, 15:44   #25
Cesc's Avatar
Thanked: 267 Times
Great work Hashim. You definitely deserve a good round of .
Has anybody tried this on inverter batteries yet?
Cesc is offline   Reply With Quote
Old 17th September 2010, 16:18   #26
shyamhegde's Avatar
Good work Hashim. Nice circuit diagram.
Do you think the capacitor is really necessary in this case?
shyamhegde is offline   Reply With Quote
Old 17th September 2010, 16:51   #27
Thanked: 196 Times
A capacitor is used across the DC output of the rectifier circuit to further smooth out the DC voltage created by the full wave rectifier.
tj123 is offline   Reply With Quote
Old 18th September 2010, 21:35   #28
Thanked: 44 Times
Guys, if any one else has tried it, please post the results.
Also, on an inverter battery, does one need to connect it to an outside charger, or is the UPS charger enough to charge the reconditioned battery?
filcord is offline   Reply With Quote
Old 18th September 2010, 22:52   #29
roadie_swift's Avatar
Thanked: 27 Times
Default What happens to the Mg?
[quote=pramodkumar;1777198]Guys i am no mad scientist but simple class tenth chemistry tells me MgSO4+ H20=H2SO4 when electricity is passed through this solution[quote=pramodkumar;1777198]
I barely managed to clear my Chem exams at school, so please enlighten me.
{MgSO4 + H2O = H2SO4} --> But then what happens to the Mg + 1 radical of Oxygen in it?
@ Hashim, sorry for the OT, just trying to fill a few gaps in my knowledge.
cheers,
R_S
roadie_swift is offline   Reply With Quote
Old 18th September 2010, 22:59   #30
Thanked: 36 Times
Do I risk overcharging my battery with this type of charger?
Also, what gauge wires do you suggest for making the connections?
Car battery life - How long did your battery last? shuvc Technical Stuff 917 14th July 2018 11:36
How to Jump Start your car (dead battery) mithun Technical Stuff 174 30th November 2017 18:25
Where to renew Driver License in Bangalore smsrini Shifting gears 3 18th July 2008 13:08
Now renew driving licence every year balechaparka The Indian Car Scene 30 22nd September 2007 16:30
Maruti likely to renew Maruti 800 with a brand new car askicode The Indian Car Scene 32 13th February 2007 12:57
