Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 25th April 2010, 20:16   #1
ghpk's Avatar
Thanked: 193 Times
Lightbulb D.I.Y. Door Safety and Foot Light on Santro
after not finding time for my earlier door/foot light, and couple of reminders from my fellow Bhpian I've
completed the door safety light on my santro.
Installation was damn simple logic :-
1). connect a Relay to prevent extra loads on existing wiring of cabin light, as this would come up sure shot when
any door is opened, no matter iginition is ON or OFF, car is running/stopped.
2). connected a Relay which gets on/off using small current from existing Cabin lamp.
3). connected a parallel wire from Hazard Light to relay so it provide current even when car is not running.
and its more of a utility than the bling bling factor.
Used L.E.D. Strips, using 6 Reds on Door, and 9 whites to lighten up the foot area, door opens and you know
that you are not stepping on to some sticky chewing gum,cow-d**
for 1 meter of strip you get 60 L.E.D.'s @Rs.250
you can cut it for each 3 L.E.D.
so using it for four doors you need 6L.E.D x 4 doors = 24 L.E.D. 30 incase you want boot door to also be covered.
Same is for white L.E.D. Strip. for each door use atleast 9, so you need 36 or 45 when including boot.
With all this much details, I am sure pictures would be able to speak much more than the words can.
Enjoy
Name:  removed side panel from pillar.jpg
Name:  soldered and tapped.jpg
Name:  relay and clips.jpg
ghpk is offline   (2) Thanks Reply With Quote
Old 25th April 2010, 20:22   #2
vaisakhr's Avatar
Thanked: 139 Times
Great. Looks so nice. As you said its a safety factor than bling bling.
vaisakhr is offline   Reply With Quote
Old 25th April 2010, 20:41   #3
shyamhegde's Avatar
Good stuff mate. Does look good and also sure, they help.
Not sure, if a relay was necessary as LEDs use pretty less current, may not be more than the relay actuator current itself.
Also please add a fuse to be more safe on wiring part.
Thanks for sharing.
shyamhegde is offline   Reply With Quote
Old 25th April 2010, 20:47   #4
vigsom's Avatar
Thanked: 604 Times
Good job ,mate.
the nicest part is - it is a DIY.
Old 25th April 2010, 23:10   #5
ghpk's Avatar
Thanked: 193 Times
Thanks all,
shyam, Relay is to prevent load and any shorts on original wiring.
i know L.E.D. don't put much load, but to avoid any possible wiring problems, I've used the Small Relay.
A fuse is already planned but not connected yet, as I'll be removing main power to connect other door tomorrow then the fuse goes in.
Old 25th April 2010, 23:16   #6
prince_pervez's Avatar
Thanked: 34 Times
This is great. Nice and neat job. It is great to have such talent. Good work.
prince_pervez is offline   Reply With Quote
Old 25th April 2010, 23:42   #7
anku94's Avatar
Thanked: 33 Times
Err...it's gotta be the stupidest question around, but what's the utility of those lights ?
Ah...missed the 'stepping on cow-dung, chewing-gum etc..." part. Apologies. Cool DIY though.
Last edited by anku94 : 25th April 2010 at 23:44. Reason: Asked a question that already had been responded to.
anku94 is offline   Reply With Quote
Old 26th April 2010, 00:19   #8
ghpk's Avatar
Thanked: 193 Times
Anku, the Red ones may also help the cyclist to have a mercy on your door who mostly Bang your door when you open up in a hurry.
Old 26th April 2010, 00:32   #9
shyamhegde's Avatar
Originally Posted by ghpk View Post
Thanks all,
yeah. relay and fuse will help, in case of any issues later.
i am planning to copy your efforts
I know it is not that easy one to complete with good finish as yours. needs lots of effort, patience etc.
Old 26th April 2010, 00:51   #10
THats a ver neat job there
THanks for Sharing it here.
winzeee is offline   Reply With Quote
Old 26th April 2010, 01:09   #11
ghpk's Avatar
Thanked: 193 Times
^ But i am sure you have the same L.E.D. insect as of mine :-)
To make it stick longer you can use few drops of fevikwik on the self adhesive tape which comes along these strips, it would make it stay much much longer on the place.
Another point which i forgot to mention would be waterproofing, as door can get real wet when car is washed or in rains, so use a transparent tape to closely cover the L.E.D. Strip and it would be quite well waterproof, Cello-Tape would not let water get inside easily.
Old 26th April 2010, 13:20   #12
UniqueMods's Avatar
Thanked: 50 Times
Nice DIY.
In the wiring going to the cabin light on the A pillar of your santro, what is the color of the "door open +ve" and "-ve ground"?
I assume black is -ve ground connected to the yellow cable you put ()2nd pic). What is your green cable connected to ?
UM
UniqueMods is offline   Reply With Quote
Old 26th April 2010, 13:27   #13
naveen.raju's Avatar
Thanked: 3,725 Times
that's a neat install. really liked the white leds... Wish I had those in mine..
naveen.raju is offline   Reply With Quote
Old 26th April 2010, 13:52   #14
thedreamcatcher's Avatar
Thanked: 62 Times
Hey, can you post some more pics of the same, but this time zoom out a little as it is a bit hard to make out clearly
thedreamcatcher is offline   Reply With Quote
Old 26th April 2010, 14:04   #15
ghpk's Avatar
Thanked: 193 Times
Originally Posted by UniqueMods View Post
Nice DIY.
UM
+ve which is coming from door switch is Blue Color.
-ve is brown, I don't remember now, but using the car chassis ground was not turning ON the relay so u used two wires.
3rd wire (which i didnt used is cabin light over-ride)
sure, please let me know which pic you wish to see, I can post them for sure.
Issue: Driver's foot (Accelerator foot) over a long drive joybhowmik Street Experiences 59 27th January 2018 23:44
New MINI 3-Door & 5-Door launched in India @ Rs 31.85 - 35.20 lakh Tushar The Indian Car Scene 33 13th April 2015 18:00
1950 Morris Minor -2 door low light muke31 Vintage Cars & Classics in India 10 8th December 2013 20:46
5745.4kms, Door to Door, 4 States and 1 UT Judemayne Travelogues 30 23rd April 2011 21:56
Audio system/roof light/door warning-Gone kaput together. akshay_b Technical Stuff 15 16th July 2009 11:36
