Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 9th June 2010, 21:51   #1
samsag12's Avatar
Thanked: 206 Times
Default Diy-fiat 1100d & President Meter Refurbishing
Hello to all fellow enthusiasts and DIYers. I recently acquired two meters, one of a Fiat 1100D and the other of a Premier President. Most fiatians on the forum may be knowing about my previous two meter restorations. Being inspired from the comments and suggestions i float this thread on TBHP community to share my passion with you all. I am attaching the pics of both the meter.
I am also posting the link to my previous meter restorations.
http://www.team-bhp.com/forum/1743297-post68.html
http://www.team-bhp.com/forum/1749335-post82.html
http://www.team-bhp.com/forum/1750969-post83.html
http://www.team-bhp.com/forum/1753169-post91.html
The Fiat 1100 D meter
The Premier President Meter
Old Gas filled Vaccum temperature nozzle
Old 10th June 2010, 07:43   #2
Sagar: What exactly you plan to do? Just clean it up?
FiatMyLife is offline   Reply With Quote
Old 10th June 2010, 08:12   #3
samsag12's Avatar
Thanked: 206 Times
I intend to do full refurbishing on these meters which include disassembling the whole meter, cleaning the meters from inside by removal of glass, rewiring the bulbs, changing the fused ones, repairing the console(the most difficult part) , followed by sanding, priming, and painting. Then 3 step polishing and reassembling.
BTW if there is any valuable input from your side, do post it.
Old 10th June 2010, 08:20   #4
How will you check if the meters are working or not?
Old 10th June 2010, 08:31   #5
samsag12's Avatar
Thanked: 206 Times
Made some progress yesterday. Disassembled the Delight meter and thoroughly cleaned the meter pods from the insides too. Will post the pics of them later as the console is being worked upon at present. It was cracked from 3 locations so was very delicate to touch. Applied the adhesive and now the pieces are in place for further minor filling job. A very shoddy paint job was done on the console before as the black paint is still visible over the round chrome bezels of the meter. Pics with description attached.
Crack on the console visible.
Bottom mount also cracked
After mending the flaw
The shoddy paintwork carried over the console before.
Old 10th June 2010, 08:39   #6
samsag12's Avatar
Thanked: 206 Times
Sir have taken it to the meter walla to get it checked. He told that the temperature meter of both the meters cannot be checked and also told, in his words, that (sahaab ye kaale meter ka taan ka sira pura nahi hai, doosara meter lagaana padega) but apart from that all others are working fine. Am planning to get them checked once again when i finish the restoration. I am in no mood to get the temperature pod of delight replaced as told you before. Will convert it to the electronic one at a later stage.
Old 10th June 2010, 09:13   #7
manishalive's Avatar
Thanked: 734 Times
Very simple to check the meters. For the coil in side the meter use a multimeter to check for the continuity (resistance). Latest generation multimetrs will beep on having continuity.
For the sensing element, the procedure is similar to a thermostat testing, dip in hot water abd supply the meter 12V supply, you are game.
Old 10th June 2010, 12:40   #8
samsag12's Avatar
Thanked: 206 Times
Thanks a lot Manish bhai for providing me the solution to test the temperature meter. Now i will not have to roam around for getting them tested. BTW i still don't have a multimeter so any good brand available to purchase, as i am planning to do so in near future.
Old 10th June 2010, 19:10   #9
Thanked: 734 Times
The best one is the Fluke Multimeter but it is the costliest, next you can go for any brand, Oprpat also makes them. Meco is one Indian company having repute.
Old 10th June 2010, 20:25   #10
samsag12's Avatar
Thanked: 206 Times
Thanks a lot for pointing out some good make multimeters. But i am still confused over the brand. Will check out with some dealers selling it. BTW Oprpat= Orpat or something else. Have inquired about the prices today and the range stated was somewhere around 200-500Rs.
Old 10th June 2010, 22:10   #11
SuperSelect's Avatar
Thanked: 224 Times
Good luck for you project - awaiting the final result....
By the way, I loved the picture with the glass of "chai". I'm a chai addict too, good to know there are more like us !!!
A small query: As the body is plastic, do you think the cracks can be fully camouflaged / made to disappear with filler and paint ? Might they not resurface due to expansion / contraction ?
Just a doubt, I may be wrong..
SuperSelect is offline   Reply With Quote
Old 10th June 2010, 23:11   #12
samsag12's Avatar
Thanked: 206 Times
Thanks a ton for your wishes Ravi bhai. Good to hear some like minded people who share the fiat passion along with the thirst for "chai". Restoration projects like these require passion, hard work and a cup of tea to engage in hard labour.
Regarding your query of crack repair NO you are NOT AT ALL WRONG rather you had pointed out a very good thing which i really appreciate. To overcome this problem i am planning to attach a couple of heated staples (the one which are seen on TV packing boxes) on both the sides of crack to prevent tension among the joint. But the plastic is very fragile(may be because of the 40 yrs of age) and brittle so working on it is very tedious.
Old 10th June 2010, 23:26   #13
samsag12's Avatar
Thanked: 206 Times
Default Update !!
Finally the refurbishing of all the meter pods is complete. Each and every meter is carefully cleaned from inside. Also cleaned the various glow lights and noted a very interesting thing that all the lights are complemented with the markings of their attachment (oil, ign, right turn,left turn) on the washers. Was amused to see this. A picture is attached for reference. Tomorrow these meters will be fitted on the mounting plate as the plate has been painted and left to dry the whole night.
Old 10th June 2010, 23:28   #14
Are the meters AutoMeter make or Yenkay?
Old 10th June 2010, 23:38   #15
samsag12's Avatar
Thanked: 206 Times
2 of them are Autometer. But i have nothing to lose as this meter came dirt cheap to me because of the cracked casing. I doubt if i can change them now as finding a replacement meter for them is very difficult. BTW did Autometer make meters originally came in delight or not.
REPORT with PICS: Refurbishing my OHC Vtec. And some mild performance mods! GTO Modifications & Accessories 195 2nd November 2017 07:58
DIY: Refurbishing a Maruti 800 on a budget aveemashfaq DIY - Do it yourself 33 22nd May 2017 08:51
DIY-Blue LED Parking Lamp & Speedo Meter+Wire Mesh Grille & Underbody Neons for Alto badboyscad DIY - Do it yourself 133 1st March 2015 00:50
DIY:Santro Meter Console Light with Bright Blue L.E.D. ghpk DIY - Do it yourself 15 2nd September 2014 11:49
Ikon - Refurbishing the 1.6ZXI in Mumbai rahuldeodhar Modifications & Accessories 10 7th March 2008 12:08
