Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 16th June 2010, 03:34   #1
ghpk's Avatar
Thanked: 193 Times
Lightbulb DIY : Installed Car Thermometer in my Santro
This is not much of a D.I.Y. project as the device used is purchased from ebay.com itself.
Car thermometer, it gives temp. readings for both inside cabin, and the outside temp.
The outside temperature sensor is a coat button like sensor which is connected thru a wire and is using self adhesive tape to stay at plastic area under the front wind-shield.
the wire is driven thru capped hole from where the cables get into passenger cabin from bonnet.
Only D.I.Y. stuff is the backlight adapter integrated into Gear Shift console as I already have auxilary power there to drive and control various L.E.D. in my car.
The Car thermometer is approx 10usd and I had to re-order it via registered post after it got lost in post first time.
At last the package reached me.
the Unit
Unit was working already
came with 1 outside sensor+backlit power adapter+small manual.
Testing
Nice colors
Soldered wires on the adapter pins
closer look on wires when soldered.
Thoroughly Taped to prevent short-circuit.
Its placed on Ash-Tray
A closer Look
The black-wire goes in where it gets the power and a switch.
I need to cleanly hide these wires, which i'll be doing someday.
Before installing the unit i even dumped the outdoor sensor to my refrigerator freezer section, it went upto -10C the temp. readings are quite accurate as I did many test and compared it with my In-home temp. measurement units.
Old 16th June 2010, 07:14   #2
MutantX's Avatar
Thanked: 89 Times
@ghpk, good idea dude. Have you monitered the temperature changes with the car A/C on. This should be a more accurate method of testing the thermometer.
MutantX is offline   Reply With Quote
Old 16th June 2010, 09:42   #3
WDM007's Avatar
Thanked: 12 Times
You installed it yourself? Is it user-friendly to install?
Does it require any pre-requisites like lighter or adapter etc?
WDM007 is offline   Reply With Quote
Old 16th June 2010, 09:46   #4
mjothi's Avatar
Thanked: 216 Times
Nice DIY. I have been thinking if I should buy this from ebay. Now, seems I should. Thanks for the step by step pics. Certianly helps.
Btw, was the power wires soldered to the 12v inlet directly? or you have another points?
mjothi is offline   Reply With Quote
Old 16th June 2010, 10:07   #5
esteem_lover's Avatar
Thanked: 451 Times
Couldn't you have just cut the cigarette lighter adapter and joined the wires directly to avoid the clutter ?
Old 16th June 2010, 10:46   #6
aargee's Avatar
Thanked: 2,142 Times
Guys, just tell me what's the use of checking the cabin temperature & outside temperature? I really couldn't understand the need. I mean, if its cold inside, I switch off the A/C, if not we switch ON. Can someone help me understand pls?
Old 16th June 2010, 11:10   #7
WDM007's Avatar
Thanked: 12 Times
@ aargee:
This is just an other gadget in the car.
Also to know how cool it is inside due to your AC.
To impress people with cool looking display.
Old 16th June 2010, 16:52   #8
ghpk's Avatar
Thanked: 193 Times
Thank you friends to show interest in my gadget.
yes the temp. goes to 20C with A.C. On, thats what i was able to measure on recent short drive.
yes its very very easy to install, you would need 12v cig. lighter socket else back-light would not work. unit's display and temp. display is powered by a button cell inside the unit itself.
12v supply is only to power the Orange/Blue backlit.
I've additional 12v power running to gear console so i used it this way.
As my car already had wires i used the gear console, one can also do what you have suggested.
Its just another gadget itch, sometime you need temperature to be quoted when you talk around, or may be just a bling factor as Santro's Dash is Very boring.
@ aargee:
Very true.
Old 29th August 2010, 18:41   #9
naveen.raju's Avatar
Thanked: 3,725 Times
That's a cool device. Really wanted that one. Let me try to source this for my swift. Guess it would look really cool especially with that blue display.
Thanks for sharing the gadget.
Cheers.!
naveen.raju is offline   Reply With Quote
Old 1st September 2010, 15:05   #10
tanwaramit's Avatar
Thanked: 387 Times
Nice work, though lack of good space for it makes it not so appealing. I liked the clock though.
Does the clock work on cells ?
tanwaramit is offline   Reply With Quote
Old 3rd September 2010, 09:55   #11
bhp_maniac's Avatar
Thanked: 111 Times
Cheers.!
Its a great DIY. Nice gadget to have. My small suggestion will be to cut out those adapter and connect it directly. One question is how it is switched. Is it in sync with the operation of the ignition switch?
@naveen: Bro, I am also looking for such a device for my Swift. It'd be great if we can get a replacement for the stock digital clock. Does the Dzire version fit into?
bhp_maniac is offline   Reply With Quote
Old 7th September 2010, 08:21   #12
deehunk's Avatar
Thanked: 1,010 Times
Smile Digital clock for Spark -PS version
I did not like the color of lights on my speedo console, so thought of changing it and opened up the console. I removed the green caps on the bulbs and left it blank. Then something on the display drew my attention, it was the digital clock. The display read 0.00, but it was hidden under the plastic, a P4 connector is required for activating the clock, but the PCB does not have the provision for connecting one as mine is a PS version. Then my brother-in law, activated the clock with a simple technique, he inserted a scissor between two holes on the P4 connector slot and the clock started working. Then I cut open the digital clock slot on the plastic. Now I have a digital clock which is working fine. I will post pictures of this DIY very soon.
deehunk is offline   Reply With Quote
Old 9th September 2010, 10:12   #13
ghpk's Avatar
Thanked: 193 Times
the clock and temp readings are available 24x7 as it runs off button cells.
the power adaptor is required for back lit only.
As my lighter socket is already having FM modulator, I connected the power adaptor to another power source which comes from ACC. out itself.
check ebay.com there are many sellers with different looks and prices for such car thermometer
Nice discovery do post the pics, it would be certainly a surprise for spark owners.
Also you can get L.E.D.'s to light up your speedometer console to look more happening.
Old 29th October 2010, 11:44   #14
josejoseph's Avatar
Thanked: 319 Times
@gppk,
please provide info about the batteries required for the power supply of this thermometer unit. I bought an item something like this, but the suppliers did not provide me the batteries.
Thanks,
Jose.
josejoseph is offline   Reply With Quote
Old 29th October 2010, 12:36   #15
shyamhegde's Avatar
Somehow I missed this DIY post.This is a nice DIY by you, ghpk. I liked it.
So, what's the temperature now!?
shyamhegde is offline   Reply With Quote
Diesel clutch release bearing installed in a petrol car. Possible effects? Crazy_Eddy Technical Stuff 2 16th July 2013 03:16
Car Thermometer Hygrometer / Weather information system? iMASKARAN In-Car Entertainment 6 30th August 2012 12:35
2004 Mitsubishi Lancer LE Car pc Installed Bangalore India sreejeshmp In-Car Entertainment 27 2nd April 2009 16:49
Installed screens in Safari, issue is they power on automatically when car starts xbox360 In-Car Entertainment 18 18th December 2008 19:37
Got my Car PC Installed! First on the forum dilipkumar7278 Technical Stuff 40 19th August 2008 18:44
