Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 7th July 2010, 18:03   #16
Thanked: 245 Times
Originally Posted by YC.BALENO.CHD View Post
I had similar queries in mind.
Also, what are the risks involved in a set-up like that?
Really no offense but this seems too good (and too inexpensive) to be true.
Hence, a detailed explanation plus some concrete data to gauge the effect in performance will be highly appreciated.
Lastly, Is a similar set-up likely to be as effective on a petrol engine? If that is the 'set-up' in question is effective at all.
I am not in a mood to experiment on my Baleno but it would not hurt to try on an old Alto we have.
Regards.
Without going into the nitty-gritties.This will result in more fuel consumption
Higher engine wear and tear
More carbon buildup
Eventually a shorter engine life overall.
Old 7th July 2010, 18:08   #17
Sprucegoose's Avatar
Thanked: 40 Times
Originally Posted by ImmortalZ View Post
Real remaps are proper intellectual property. Four dimensional maps involving fuel, ignition, cam phasing and valve timing is a serious amount of work.
What is Cam phasing?
Valve timing can only be adjusted if you have VTEC [or other similar technology] in the head right?
Sprucegoose is offline   Reply With Quote
Old 7th July 2010, 20:38   #18
vigneshram's Avatar
Thanked: 15 Times
we ve tried this kind of a mod on a Palio 1.2.The car feels effortless to drive in 2 nd gear now.
vigneshram is offline   Reply With Quote
Old 8th July 2010, 03:00   #19
aargee's Avatar
Thanked: 2,143 Times
so the ECU will inject more fuel thinking that the air going in the cylinders is colder, and therefore denser. This makes the engine run a little richer
The engine should be fed with optimal fuel right? If the mixture is running rich, you get the same performance for added fuel isn't it?
The improvements would be a little more for Diesel cars. For petrol vehicles, they would range from none to marginal
Again, if the mixture is rich, no matter Petrol or Diesel the performance is going to be the same isn't it? How does Diesel fair better over Petrol? Pls help understand both the points.
Old 8th July 2010, 03:36   #20
pranavt's Avatar
Thanked: 274 Times
Depending on the stock Air/Fuel ratios, adding more fuel can decrease performance. Maximum torque occurs at AFRs of 13.2:1. Anything lower than that and the primary function of the extra fuel is cooling the intake charge as it rushes into the combustion chamber. This is all about Gasoline/Petrol engines.
This observation was based plainly on the fact that Diesel tuning boxes seem to actually make a noticeable difference in the amount of power when they make the engine run richer compared to stock. Still, law of diminishing returns applies and this is only valid for small increases in fuel injection. If you go nuts and try dumping more fuel than necessary, it will just come out the back as black smoke.
Old 8th July 2010, 04:29   #21
CPH
Thanked: 34 Times
This is not what performance tuning is about.
As Pranavt stated there is more to mapping..
It will lead to overfuelling, which will kill the turbo.
I take it that your ECU is an EDC15, which might let you get away with it long term not going into limp mode.
Try doing this on a EDC17 and you will be in for a nasty surprise.
On petrol engines this mod is counterproductive as the ECU has got quite a few more sensors that will compensate for it and often sends the ECU into a fixed routine.
I would leave my hands of such a modification.
A re-map is something different.
CPH is offline   Reply With Quote
Old 9th July 2010, 19:19   #22
Originally Posted by air870 View Post
I ve just done a really cheap mod on my octy. we soldered a 2.2K ohm 1/4 W resistor on the number 7 pin wire of the injection fuel pump connector[ yellow blue/ green] and also a similar resistor on the number 1 pin wire of the MAP sensor both were properly insulated after that. The purpose was to intercept and alter the readings fed to the ECU of fuel and IAT and lower them substantially.Can be checked on VCDS. The resistors cost about a rupee each. I ve noticed a marked improvement in performance.
Hi Buddy, I am interested in doing the same mod. Sounds really cool and seems that there is a improvement in the performance.
Please tell me where can i get it done as I dont really a know of tech stuff. I stay in Mulund, Mumbai. If you wanna meet up and help me out, Im game..!
Else, please tell me any good garage/ mechanic where you recommend.
Thanks. Cheers..!
sameern.85 is offline   Reply With Quote
Old 11th July 2010, 06:21   #23
headers's Avatar
Thanked: 464 Times
Not really ! It is not as simple as the word!
Ideal stoic ratio is 14.7: 1 right?
Peter, Hi, How does overfuelling kill the turbo? IMO should it not come out as unburnt black smoke!!??
cheers
Old 11th July 2010, 08:41   #24
adheesh's Avatar
Thanked: 35 Times
cheers
14.7:1 is the theoretical stoichiometric ratio for pure petrol (for diesel its 14.6:1). The car at different situations needs slightly altered ratios. For example, at idling, a rich mixture is required which goes on leaning till stoichiometric ratio till nearly full throttle conditions where again a slightly rich mixture is required. All this is taken care by the ECU in our cars but in the days of carburetted cars there were different interrelated circuits in the carburettor like idling circuit, transition circuit, main-jet circuit and power circuit (where the air correction jet comes in).
The key to performance is inducing more air-fuel mixture in the engine (than rather just fuel). After a calculated restriction on natural induction, forced induction techniques like turbos are used to force induct more air and correspondingly more fuel.
Adheesh Parelkar
adheesh is offline   Reply With Quote
Old 11th July 2010, 11:22   #25
Air870, I think you got for 2 bucks what others pay 10 grand for
1. Pictures?
2. How about dyno'ing the car to gauge any increase in BHP, however marginal?
3. Do you have access to a G-tech to time the 0 - 100? If not, we can arrange for the same. Will be fun to time the improvement.
Am due in at KS on monday for a Dyno. Will post numbers then. however I cant give you the difference brought about by this mod as I had not measured the car before.
@Air870 : What & how did the readings change ?
What exactly is the difference in the performance ? How did you measure it ? And what ALL are the changes ?
Performance difference is purely by seat of pants feel as i ve no figures to compare. however the readings are reflected on VAG-Com in the respective measuring blocks.
HOW TO tamper with the fuel temp sensor like KERMA - TDIClub Forums
Adheesh Parelkar
Browser Warning
Last edited by Rehaan : 14th July 2010 at 13:54. Reason: Please use the EDIT or MUTLIQUOTE buttons rather than making multiple consecutive posts. Thanks.
air870 is offline   Reply With Quote
Old 11th July 2010, 12:18   #26
CPH
Thanked: 34 Times
The unburnt smoke partly penetrates the turbo bearings, where the hard carbon deposits slowly kill the bearings, which turn leads to turbo failure.
Adheesh Parelkar
In practical terms the stochiometric ratio is never applicable.
At idling the AFR is usually lean (17:1 or even leaner), not rich. Above idle the AFR decreases and varies depending on load factor.
On normally aspirated cars in most applications it goes as low as 13:1 in some applications even around 12:1.
On high performance turbos it can be necessary under full load to go as low as 9:1, but most turbos are above 11:1.
On cold start in cold ambient conditions the AFR can be as low as 8:1.
This article has got at least 2 dozend inaccuracies.
And you can't carry theses results over to any other engine configuration.
Last edited by Rehaan : 14th July 2010 at 13:54. Reason: Posts merged. Please use the MULTIQUOTE button instead of making multiple consecutive posts in the same thread. Thanks.
Old 11th July 2010, 19:36   #27
joshguy's Avatar
Thanked: 92 Times
What ! Rs 2 upgrade ? is this working fine,i mean will it not affect emission norms of the vehicle.
Hope there is no major install or workmanship required for this
joshguy is offline   Reply With Quote
Old 11th July 2010, 22:53   #28
Pls read the first post.
Old 12th July 2010, 17:18   #29
CPH
Thanked: 34 Times
Maybe a new turbo or in same cases a replacement engine. Nothing major really considering all the money you save on the resistors.
Old 13th July 2010, 02:05   #30
Dyno ed. 140Bhp/ 240 tq at 2600rpm. WMF file from KS. Cant upload.
DIY: Skoda Fabia Brake Disc / Rotor Change & 4th Service too! aayushnair DIY - Do it yourself 23 28th November 2015 13:26
Skoda Octavia VRS - H&R Springs Modification Query HAFI Modifications & Accessories 2 2nd November 2011 07:16
Skoda Octavia 1.9 TDI LnK, Ripped BUSA Test-Drives & Initial Ownership Reports 46 17th June 2007 12:18
