Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 11th August 2010, 10:52   #16
mayankk's Avatar
Thanked: 3,489 Times
@Mayankk, ...... Just asking out of curiosity, why is it difficult to fit a K&N for a Ford car?
just check out the pictures.there is no room in the bay.
helluva project trying out angles.
thats why the solution aint up to par,apparently.
mayankk is offline   Reply With Quote
Old 11th August 2010, 13:54   #17
CPH
Thanked: 33 Times
btw,for the experts here, with CAI, the enclosure for the filter looks to me as if the filter is considerably smaller than when we fit it a standalone conical.is that right?
If you refer to pipercross then it is a definitive yes. Pipercross is the worst of all induction kits. Simota Is better, but usually the remainder of the intake is rather poor. Same goes for BMC.
The Green, Jetex, JR and K&N 57i are better, but suffer from torque problems because of not utilising the full technical potential.
The only two products that are dedicated to each cars are GSR products and the K&N Typhoon. Both products can be installed without specialists. Both have a representation in India.
@CPH:it is much harder to find good fittings and a good mechanic here if you go off of the established installers.its all trial and error but eventually, you may get it right mechanically.
and the +/- percentage of error can be discounted on the learning curve here.
CPH is offline   Reply With Quote
Old 11th August 2010, 14:21   #18
mayankk's Avatar
hmmmm...food for thought.taking a 8 hour drive upto corbett next week.Ill keep the oe stuff as backup in the boot, in case my work goes into frankenstein mode.if there is even one glitch on the drive, then 57i it is(is that the same as apollo though??).
Old 11th August 2010, 15:52   #19
CPH
Thanked: 33 Times
I wouldn't advise to go for the 57i. Stock is about as good as 57i. Typhoon is much better if available.
Old 11th August 2010, 19:32   #20
rjstyles69's Avatar
Thanked: 789 Times
@RjStyles - Isn't that a conical setup on WagonR? Correct me if I'm wrong, as I'm planning to get one conical for my WagonR & ofcourse I like to do it myself. I hope I get the instructions when I buy K&N isn't it?
aargee that's the engine bay of a baleno. I don't think the WagonR has that much space in the engine bay.
Old 14th August 2010, 20:50   #21
mayankk's Avatar
hey, should i try and get a less taller filter to use the bay?
this one measures 7.4" from flange to top.
this is a double conical(i dont know if thats the correct term.all i mean to convey is there is some active surface inside the cone as well)
sort of like " /V\ ".......
Old 14th August 2010, 23:08   #22
CPH
Thanked: 33 Times
The added inverted cone is not only able to pass extra air. It also aids flow characteristics. Due to the inverted cone less turbulence means a higher pressure in the filter mouth, which looks only little but may gain you between 1 and 3% in peak power compared to a single cone filter.
We usually call them twin cone filters.
Old 31st August 2010, 12:28   #23
mayankk's Avatar
one other thing.
the highlighted bit, where the pipe's joining the block, its outer dia is 2.5" or 3"????
Old 1st September 2010, 14:20   #24
CPH
Thanked: 33 Times
one other thing.
It is neither.
It is 60mm.
Old 1st September 2010, 15:10   #25
mayankk's Avatar
Originally Posted by CPH View Post
It is neither.
It is 60mm.
umm,no.
in my car, the ID of the connecting pipe is 63mm.
thats 2.5".
got it now.
fitting a braided heat resistant hose dirctly, without going through the airbox.
(sheepish grin):as was done intially in thw 1st picture earlier, much neater this time!!
Old 11th December 2010, 12:43   #26
frankmehta's Avatar
Thanked: 2,231 Times
Default Re: DIY - Spectre Conical Air filter in Fiesta 1.6Sxi
Any updates? Please tell us if you got a solution
Old 13th December 2010, 10:52   #27
mayankk's Avatar
theoretically formulated as of now.....just cant find an aluminium pipe bender, or the pipe for that matter.
gonna be a DIY of sorts now, in january.
Involves a 3' 2.5" ID pipe,or a silicone hose, removing the airbox, sand, a blowtorch, and some flat steel bolt holders....will update.
currently its still as above, but not aesthetically pleasing or giving any peace of mind....
Old 14th December 2010, 19:24   #28
di1in's Avatar
Thanked: 66 Times
I've planning on trying out a DIY induction on my ohc, but im stuck as to how to make/bend those aluminium pipes. are there any alternatives for those?
di1in is offline   Reply With Quote
Old 14th December 2010, 20:29   #29
mayankk's Avatar
I've found a guy in gurgaon who bends aluminium.unfortunately, am just not able to source 2.5" ID pipes conveniently(lazy).
Alternative could be silicone hoses, but dont know if they would require the filter to mounted by itself and not take support from the hose end.
just FYI, it'll be much easier and cheaper if you buy the CAI kit,trust me.
also, mechanics familiar with OHC's bay would be much easier to come by.
Old 18th December 2010, 15:39   #30
di1in's Avatar
Thanked: 66 Times
Yea, scrapped that idea. Based on ideas coming up from here I'd have to find a place who use silicone instead of metal and flexible hoses.
http://www.team-bhp.com/forum/techni...-revision.html (Aspects of designing an Air Intake Revision)
DIY Conical Air Filter - Maruti Swift shibujp DIY - Do it yourself 1 8th May 2013 20:40
K&N Conical Extreme Air Filter for Sale Slash Shifting gears 5 26th November 2007 19:12
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 20:33
Fitting K&N Conical Filter. MexXxentric Modifications & Accessories 10 14th June 2006 12:37
