Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 4th September 2010, 20:02   #1
HAFI's Avatar
Default DIY Skoda RS Head Light Replacement And HID Upgrade
Recently my RS had to undergo a small accident which involved hitting a bikes rear Saree guard.Unluckily to say,it took away the glass covering of the right side head light.Shocked i was thinking about the huge cost involved to replace the head lamps at authorized service centers.
Some how settled the guy with 500 bucks as i was found to be the faulty one as i hit him from behind.Immediately i called up the skoda helpline and asked for the price of the head lamp.They told it costs a whopping 33k which include the xenon and the control unit.I dint require the xenon and the control unit as both of them where working fine.And also i intended to change both of the head lamps as it would look mismatching with one brand new and the other one pale yellow or else i will have to miserably sand the new one to make it pale.Hence it would cost 66k.I dropped the idea of getting new ones and looked for second hand ones.Saw many of them.but wasn't satisfied as most had huge scratches.Broken legs etc.
So i had to depend on other local dealers.They got me the new product,ie the two sets of head lamps without xenon,control units and the back cover.
i got it for 18 k.
I have seen all the work shop men working on the head lamps,they handle it so carelessly that all the small bits and pieces break and so causes scratched on the clear lens which later would be comes difficult to rectify.
Since my head lamps were brand new, i decided to do it up myself which could in turn save the some money given to the workshop men. I also bought a set of new HID's for my high beam.The low beam is already xenon.The high beam for skoda RS and L&K is of type H1.
Here is the detailed pictorial guide on how to change the head lamps and also install HID's.Sorry for low picture quality as all the pictures are taken from my phone cam.
The set of old head lamps.U could notice the broken piece.
My ride with no head lamps.
Here is the new set that i bought
Remove the screws on the control unit as marked in the image
The rear of the head lamp with the control unit attached The end i am holding is the control unit.
Take the control unit out.You could see the pins and the connector at the rear of the lamp.Its always safe to remove the control unit first as miss handling could break the unit connector leads.
Remove the screws as ,marked in the picture.Remember all the screws are of flower type.
Flip the cover side ways very carefully as the wires are brittle and could break.Reason being these are old wires and due to constant heat the plastic lamination could be brittle.Remove the connection from the fog lamp H4 bulb and the high beam H1 bulb.The pins are not that complicated.These are common male female pins and is easy to remove.
will continue soon.let me go have a cup of tea.
HAFI is offline   Reply With Quote
Old 4th September 2010, 20:17   #2
black12rr's Avatar
Thanked: 272 Times
Very good DIY . How much is new set single piece ?
black12rr is offline   Reply With Quote
Old 4th September 2010, 21:13   #3
HAFI's Avatar
new set single piece cost 9k.
Old 7th September 2010, 08:53   #4
HAFI's Avatar
The thread seems to be dead.Should i continue with the DIY?.
Old 7th September 2010, 08:58   #5
Manoj2268's Avatar
Thanked: 90 Times
Yes yes, please continue. It's very helpful.
Manoj2268 is offline   Reply With Quote
Old 7th September 2010, 09:26   #6
Thanked: 9,729 Times
Please, we are watching with baited breath!
Old 7th September 2010, 10:05   #7
naveen.raju's Avatar
Thanked: 3,133 Times
Great work. Please continue with the pics. This thread would really help us. Something that's really needed for all of us. Especially, ones who are planning for HID upgrades.
Keep us updated.
naveen.raju is offline   Reply With Quote
Old 8th September 2010, 00:08   #8
HAFI's Avatar
Thanks for the inspiration....ok ill continue now...
Old 8th September 2010, 00:31   #9
HAFI's Avatar
Default Continued
If you watch closely in the following image,you could see the holder for the hid(stock) xenon.It is similar to the normal bulb holder,but a little delicate.Gently rotate the holder in the anti clockwise direction.Be care full when taking it out.
And also notice the screws attaching the auto leveler motor to the unit.Remove that too.
I have taken some close shots of the holder so that the lock on the holder could be visible better
You could see the holder and the bottom end of the D2S bulb after the holder is removed
After removing the screws around the motor,we have to take of the motor.It is a little tricky part.The end of the leveling motor is bulb shaped.The bulb end gets into a channel and stays locked.What we have to do is slightly slide the lock upward so that the end can be slide out of the channel
Below shown are the photos of the channel and the motor.
Will be continued..
Old 8th September 2010, 02:07   #10
Awaiting Email Confirmation
Thanked: 66 Times
I did a similar DIY for my Octavia Rider. I did not have to install HIDs, rest everything was ditto. The leveling motor, low/hi beam bulbs, etc.
Great going. Keep us posted!
Akki_5 is offline   Reply With Quote
Old 8th September 2010, 02:15   #11
Thanked: 147 Times
That is a very Detailed DIY indeed. Good work there. BTW, Is this a sealbeam?
Cyrus43 is offline   Reply With Quote
Old 8th September 2010, 09:30   #12
This is brilliant. I hope you disconnected battery befroe removing headlight due to high voltages involved ?
Old 8th September 2010, 12:24   #13
gigy's Avatar
Thanked: 41 Times
Nice job done. helpful for me since i am yet to finger around the skoda.
I am also planning to replace the headlights but not decided if to go for the xenon ones or stay with the older h4 and put in philips 90/100.
gigy is online now   Reply With Quote
Old 13th September 2010, 10:53   #14
HAFI's Avatar
sorry people as i was out of net for few days,couldn't get the thread updated.sorry.
ill continue with the update.
Old 11th January 2012, 22:57   #15
Default Re: DIY Skoda RS Head Light Replacement And HID Upgrade
hi
jet wanted to know where did u pick these headlights from for 18000/-
sharukh is offline   Reply With Quote
DIY: RCD 510 head-unit upgrade for VW Vento and Polo moralfibre In-Car Entertainment 96 23rd April 2016 11:36
Problem with my i20 head-unit after installing HID's nikibusa Technical Stuff 24 28th February 2014 09:46
DIY HID Install in an Alto. SirAlec DIY - Do it yourself 21 2nd February 2011 00:19
