Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 9th October 2007, 10:56   #16
S@~+#0$#'s Avatar
Thanked: 37 Times
As much as I can, I try and do things myself. To be able to do this, I have a small collection of tools that varies from spanners, rachets, duct-tapes files to soldering-irons, drill-guns and blowers but have found it difficult carrying them when required. I am currently using an old military explosives box that I picked from the Chor Bazaar. But I need something more organised and lightweight. Any ideas on a good brand that makes toolboxes? Something like this would be great Craftsman Tool Case, Black - Model 59378 at Sears.com
IMO, another must-have is a Victorinox Multi-functional knife. It is very handy and has bailed me out of many a difficult situation.
S@~+#0$# is offline   Reply With Quote
Old 12th October 2007, 01:42   #17
clipto333's Avatar
thanks sam :-) yes it is SOLDRON. and its flux. sorry for that. i can imagine someone asking for wax and making a fool out of himself. and desoldering wick ofcourse. thanks again.
sam, isnt 15 watts more than enough? a 25 watt ca damage thing if used for too long. but for wires and stuff, the 25w iron will be fine.
and i have bought some power tools. sorry for posting it in three different threads but it belongs here. gota black & decker cordless drill, a jigsaw machine, a crew driver kit(to be used with the drill) a wood planer and some drill bits and jigsaw blades. these power tools have made my life a lot easier. i could remove my sub from the enclosure in 1 minute flat. :-)
cheers
clip
clipto333 is offline   Reply With Quote
Old 12th October 2007, 10:14   #18
navin's Avatar
Thanked: 3,924 Times
you do get solder wire with a flux core, at best you now need flux to clean the tips. Soldoron makes nice irons and interchangable tips too. They've been in the business as long as I can remember. :-)
Old 12th October 2008, 16:06   #19
nura's Avatar
I am thinking of buying a digital multimeter. Can someone help me choose between a cute orange Chinese one costing Rs 100 & a slightly bulkier Orpat costing Rs 160 or suggest something better that doesn't cost very much more?
My sincerest thanks in advance.
nura is offline   Reply With Quote
Old 12th October 2008, 20:21   #20
I have both - a DMM I use for checking voltages <20V and current <2mA, and a brand SANWA made analog multimeter (150Rs in 1992) used for major work. I care both of these babies very much. Still they have there own packing. Sanwa make MM is almost 15yr old. That's why they never fool me.
omishra is offline   Reply With Quote
Old 13th October 2008, 12:16   #21
DerAlte's Avatar
Thanked: 2,877 Times
I am thinking of buying a digital multimeter. Can someone help me choose between a cute orange Chinese one costing Rs 100 & a slightly bulkier Orpat costing Rs 160 or suggest something better that doesn't cost very much more? ...
Daktar babu, for your purposes the Chinese one will also do. Just check if it has a continuity check setting (usually with a beeper) under Resistance measurement. Care for it, it will last a long time - just make sure the knob is set to what you want to measure before connecting the probes, not AFTER the puff of smoke comes out.
Old 13th October 2008, 13:32   #22
shyamhegde's Avatar
Chinese DMMs costing Rs 100 come with a cheap 9V battery inside which gives away too quickly and also leaks to spoil the circuit board.
Change the 9V battery to a branded one and that should last longer.
shyamhegde is offline   Reply With Quote
Old 13th October 2008, 13:51   #23
Thanked: 18 Times
Hi guys ,
just my 2 cents we all know how crucial it is to use good quality tools.we now get the famous Stanley brand tools here in India.their address ;Stanley works india(P) ltd.,4/24 a,A.B.house , asaf ali road , n. Delhi 110 002 e mail:indiasales@stanleyworks.com
rallystar is offline   (1) Thanks Reply With Quote
Old 13th October 2008, 15:30   #24
nura's Avatar
Thanks for your invaluable suggestions.
@shyamhegde - Which brand(s) 9V battery would you recommend & how much do you think it would cost? Do you think the Orpat may come with a better battery? Is the seller likely to get very annoyed if I ask him to show me the battery inside the multimeter?
Since I didn't have the foggiest idea about using a digital multimeter, I was hunting for some information on the net. Here's the link to a wonderful flash presentation I found.
The Digital MultiMeter
nura is offline   (1) Thanks Reply With Quote
Old 13th October 2008, 16:30   #25
shyamhegde's Avatar
I used Eveready ones. Costed some 40 Rs. Duracell would be costier than the DMM itself !
Do not forget to turn the meter off after the use. I drained couple of them forgetting to turn them off before putting it in my tool box.
I hope Orpat uses good battery. That might be the reason they charge us a bit more than Chinese ones. If Orpat gives you warranty that is good. Please check. (Warranty might not help, if you burn the meter with wrong settings while using)
Seller might not be comfortable showing the batteries to you as opening it would void warranty.
That link is a good one for beginners. Thanks.
You can also refer to the manual/guide which comes with DMM in pack itself.
Old 13th October 2008, 17:14   #26
Default Great link
@nura, the link is a very good tutorial. I finally learnt how to take Current readings using a DMM. I was doing it wrongly all this time and wondering why I was not able to take Ammeter readings.
jreddy420 is offline   Reply With Quote
Old 24th October 2008, 16:41   #27
nura's Avatar
Hi! I finally got myself a DMM after parting with a princely sum of Rs 95 & was pleasantly surprised not to see the meter go up in a puff of smoke (it actually displayed 240 volts), when I inserted the test leads into a domestic socket.
Since it is not an "auto range" instrument, I need to have the switch in the correct position, before I take a reading. But let us say I want to measure an unknown resistance, what should I do then? Start high & turn the switch to the lower figures (removing the test leads each time) or vice versa? Or is it going to blow either way?
Thanks in advance,
nura.
Old 24th October 2008, 23:40   #28
shyamhegde's Avatar
Thanks in advance,
nura.
You need not worry of blowing the meter up in smoke when you measure resistance of a resistor. you can select any range and 'tune' to the optimum range in steps. To measure resistance, multimeter uses its internal battery and there is no chance of damaging it in any way doing so.
Old 25th October 2008, 10:24   #29
Unless you intrude into live circuit.
Measure current and voltage with due care, and always measure resistance with switched off circuit.
Keep in mind, if you get misleading reading then change the battery of DMM first.
Old 25th October 2008, 12:53   #30
DerAlte's Avatar
... But let us say I want to measure an unknown resistance, what should I do then? Start high & turn the switch to the lower figures (removing the test leads each time) or vice versa? ...
No, you need not remove the leads to do that. Of course, holding the leads in place with one hand and rotating the knob with the other can be quite tricky sometimes.
With DMMs the process is - start with the lowest range, and keep going up one step at a time. If the range is too low, the reading is usually E (indicating infinity or too high for the range). In one setting the E will change to a valid reading. You need not reverse leads, unless you suspect the component to be a diode.
Lower the range, more decimal places are indicated for the resistance.
Bangalore : Fantastic store for tools kartikkumar Shifting gears 22 27th September 2012 01:15
Amplifier Installation Help: For DIYer nitin.dangayach In-Car Entertainment 52 10th March 2010 18:59
Power tools dadu Gadgets, Computers & Software 15 16th June 2008 12:05
tools for bike garage bullboy Motorbikes 1 11th September 2006 12:50
