Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 18th July 2014, 11:38   #766
dre@ms's Avatar
Thanked: 186 Times
Default Re: Tools for a DIYer.
Update:
Took an off from work today to complete pending DIY works at home.
The wood from the churner has become so fragile being soaked in the water for almost couple of months. Once grabbed using the wrench, it started to shred off. Had a hard time clearing off the shreds from inside the pipe.
The plastic pipe had a metal inner which had threads in it. Over this metal is the pipe inner screwed and broken.
To my utter dismay, the length of the pipe is an inch long, due to which the hack saw was able to damage the inner thread for just quarter an inch.
Once the cut is done, started to chisel off the metal and after some hard beatings, was able to manage to remove quarter of the threaded metal from the pipe.
At this stage, an idea struck. With this quarter of a thread available, I was able to screw back the pipe which had same size of thread remaining. Voila!!! Mission accomplished. To finish off, applied m-seal on the sides of the tap. I am now a happy man. Thanks everybody.
dre@ms is offline   (2) Thanks Reply With Quote
Old 15th August 2014, 11:20   #767
dre@ms's Avatar
Thanked: 186 Times
My next need. Having a kid at home and that too in a rented house calls for lot of trouble(sweet though).
Honing his writing skills on the walls. How do we erase them. Its a combination of Crayon, Pencil and ball point pen markings. Will a thinner help?
dre@ms is offline   Reply With Quote
Old 15th August 2014, 11:56   #768
latentpotential's Avatar
Thanked: 380 Times
We buy crayons, pencils and paint from crayola. These are water soluble and dissolve rapidly. So walls, flooring, furniture, carpets and clothes are all back to normal with a sponge clean up or a simple wash. Amazon dot in is our source for this amazing stuff.
Note that they have the normal type as well, so ensure that you buy the right ones.
latentpotential is offline   Reply With Quote
Old 18th August 2014, 21:02   #769
dre@ms's Avatar
Thanked: 186 Times
Will keep this for my future purchases. But what should I do for the damages already done?
Old 19th August 2014, 09:56   #770
Prowler's Avatar
Thanked: 302 Times
Scrape a thin slice of the paint and take it to the hardware shop. Get a small tin of the same colored distemper paint. Paint a thin coat on the offending area. This will work with acrylic emulsions painted surface too - if you apply a thin coat evenly.
I had to resort to this method when careless servants scratch the wall when they move things around.
Prowler is offline   Reply With Quote
Old 19th August 2014, 11:52   #771
dre@ms's Avatar
Thanked: 186 Times
Will check on this and update. Thin coat? Will a normal brush server the purpose or need to use a specialized one?
Old 19th August 2014, 16:07   #772
Prowler's Avatar
Thanked: 302 Times
A normal thin bristled brush will serve the purpose.
Old 20th August 2014, 14:30   #773
DerAlte's Avatar
Thanked: 2,879 Times
... But what should I do for the damages already done?
Try a soft eraser first, most of it will come off with that. Then, use either a good detergent or a kitchen cleaner like Mr. Muscle or something Brain. Apply / spray, and wipe off. Hopefully the paint is a good water-based acrylic paint which will not come off.
If it does, ask the landlord what shade of paint was used (no one uses distemper nowadays). Paint shops will mix to that shade number. Get at least 0.5L of that shade - you should expect more such 'writing practice' in future. Best preventive is getting your kid waste paper and guide him in drawing on that, instead of on the wall. But ... kids will be kids!
DerAlte is offline   (1) Thanks Reply With Quote
Old 25th August 2014, 12:13   #774
Thanked: 61 Times
I just wanted to share the crimping tool i recently bought from ebay.in.
Its Jainsons Samrat crimping tool which is capable of crimping from 0.5mmsq to 16 mmsq
Its about 600 gms in weight and costs about Rs 900/-
BakyaBHP is offline   Reply With Quote
Old 26th August 2014, 17:24   #775
Abeer's Avatar
Thanked: 12 Times
I am looking to buy what is shown in http://www.ebay.in/itm/2pc-Circular-...-/380346377936
Have tried searching various online stores but it is not available anywhere
Abeer is offline   Reply With Quote
Old 26th August 2014, 18:37   #776
Thanked: 380 Times
Look for shops that sell bosch dremel kits and accessories in your region. They will have a catalog from which you can find what you need and order.
Also check flipkart? they had started keeping dremel accessories recently
Old 26th August 2014, 21:09   #777
Gannu_1's Avatar
Thanked: 10,403 Times
Got a bunch of Stanley bits from eBay. The present ones were showing some wear and tear and weren't gripping onto the screws properly.
Gannu_1 is offline   Reply With Quote
Old 29th August 2014, 21:55   #778
Safety is Param's Avatar
Thanked: 191 Times
Default Re: Bosch Toolkit: Opinions/Alternatives?
Requesting inputs for a BOSCH Power & Hand Tool Kit - GSB 500 RE
http://www.flipkart.com/bosch-gsb-50...mdtwyyqpqhsvvg
http://www.shopclues.com/bosch-gsb-5...AffiliateSales
Please suggest alternatives, if any. Max stretchable budget is INR 4000/-
Will be used for light to medium work comprising -
1) Photo Frames
2) Fixing a wireless router at a height
3) Multiple key-holder
4) Blender in kitchen, etc.
Safety is Param is online now   Reply With Quote
Old 2nd September 2014, 21:24   #779
Thanked: 22 Times
There's a discount offer on Bosch toolkit at Rs 3800 apprx against Mro of Rs 6400 at Chroma outlet at Saket mall, Delhi.
raja_ys is offline   Reply With Quote
Old 2nd September 2014, 21:50   #780
Thanked: 191 Times
Originally Posted by raja_ys View Post
There's a discount offer on Bosch toolkit at Rs 3800...Saket mall, Delhi.
Thanks! I will call up Croma tomorrow to check if they have similar offers in Bangalore.
Bangalore : Fantastic store for tools kartikkumar Shifting gears 22 27th September 2012 01:15
Amplifier Installation Help: For DIYer nitin.dangayach In-Car Entertainment 52 10th March 2010 18:59
Power tools dadu Gadgets, Computers & Software 15 16th June 2008 12:05
tools for bike garage bullboy Motorbikes 1 11th September 2006 12:50
