Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 2nd July 2015, 19:39   #1066
sagarpadaki's Avatar
Thanked: 1,271 Times
Originally Posted by unk9ja View Post
Check out at Azeez Trading Company on the SJP road. It is on the left towards KR market from Town hall side just as the Sirsi circle flyover ramp starts. He has a good variety of tools. Speak to the owner who is a Muslim, he will suggest you an alternate if they don't have a solution.
But these days they stay closed during afternoons and close early at 1730-1800hrs due to Ramzan.
Thanks. Will check them out this weekend if possible.
Originally Posted by adrian View Post
Why don't you use screw driver bits for power drills ?
regards adrian
Intent is to use existing bits with drill for those occasional high power use.
Old 2nd July 2015, 19:52   #1067
adrian's Avatar
Thanked: 587 Times
Default Re: Tools for a DIYer
OK, but please make sure that they can withstand the torque of the power drill.
regards adrian
adrian is offline   Reply With Quote
Old 3rd July 2015, 10:37   #1068
regards adrian
Shouldn't be a problem since i will using the drill in screw driver mode and not in impact mode. And i will be running at low speeds only since i need more rotating power(which i am not able to apply by hand) and not fast rotation.
Old 3rd July 2015, 10:42   #1069
audioholic's Avatar
Thanked: 5,275 Times
I had brought one from SP road too, but dont remember the name. Its of good quality and IIRC I paid 50 bucks or so. It is around three inches long and though I can directly plug the bits in the chuck, this allows for quick switching of bits.
And yes, it is used in slow speeds else the torque at high speeds is good enough to rip the thread smooth.
audioholic is offline   Reply With Quote
Old 3rd July 2015, 11:27   #1070
Did you get it from the main SP road lane which has lots of computer shops or some side lane over there?
Old 3rd July 2015, 14:49   #1071
DerAlte's Avatar
Thanked: 2,877 Times
Try the shops closer to the mosque side of SP Lane after the electronics shops end. At the Avenue road end you have the metal traders. The tools and tackle guys are on SP Lane (and the side gallies) between the metal traders and the electronics shops.
DerAlte is offline   (1) Thanks Reply With Quote
Old 3rd July 2015, 14:59   #1072
audioholic's Avatar
Same line of shops if you go, you will slowly find electronics shops after the IT shops. Following that you get only tool and hardware shops and I got it from one of the shops to the right side of the road.
audioholic is offline   (1) Thanks Reply With Quote
Old 8th July 2015, 08:16   #1073
dre@ms's Avatar
Thanked: 172 Times
How good is the deal, Skil 10mm power drill for Rs.999 in Metro Cash & Carry?
dre@ms is offline   Reply With Quote
Old 8th July 2015, 13:26   #1074
DerAlte's Avatar
If you don't see a need for using bits with shanks larger than 10mm, this is a very good deal.
Old 8th July 2015, 15:41   #1075
Thad E Ginathom's Avatar
Thanked: 7,460 Times
I just bought a Stanley ratchet screwdriver, here in London.
All the ratchet drivers I have are small and lightweight, but this is quite hefty. Hope it is as strong as it looks.
Also has 4:1 gearing option to speed up the easy bit.
Cost 17 GBP!
Old 9th July 2015, 07:54   #1076
dre@ms's Avatar
Thanked: 172 Times
Cant predict this. So better will stay away from this and get the Bosch kit.
Old 9th July 2015, 14:06   #1077
Thanked: 1,011 Times
Even I think that you should go in for a 13mm capacity drill. Apart from allowing larger shanks, it will have more power and in some cases built for longer drilling time.
Aroy is offline   (1) Thanks Reply With Quote
Old 16th July 2015, 08:05   #1078
Thanked: 25 Times
Hi Guys,
Showing off my small tool collection. This was taken a while back, since then I have added few more tools to my arsenal.
Besides this I have a Circular saw underneath a table. Due to the build quality you can really call it a tablesaw.
Besides this I do have couple of soldering Irons, crimping tools, UV Exposure box, PCB drill press etc.
I really wanted to get some router templates similar to once being sold by Mobile solutions. Any alternate and/or cheaper options to source these in India?
Cheers,
Venki
venki7744 is offline   (1) Thanks Reply With Quote
Old 17th July 2015, 04:44   #1079
Advice on soldering iron, please?
I want one suitable for a beginner to electronics.
The one I have is too big and, I suspect, too powerful. Something with a fine tip around 20W would be good?
I am on UK just now, and will be buying a handful of small tools. Or a case-full, if I get carried away!
Old 17th July 2015, 09:08   #1080
SunnyBoi's Avatar
Thanked: 2,794 Times
I have a Goot 30W soldering iron with a fine tip which I've been using since 9 years. Its just excellent, does its job well and hasn't given me any problems so far
SunnyBoi is offline   Reply With Quote
Bangalore : Fantastic store for tools kartikkumar Shifting gears 22 27th September 2012 01:15
Amplifier Installation Help: For DIYer nitin.dangayach In-Car Entertainment 52 10th March 2010 18:59
Power tools dadu Gadgets, Computers & Software 15 16th June 2008 12:05
tools for bike garage bullboy Motorbikes 1 11th September 2006 12:50
