Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 30th August 2015, 13:36   #1111
Thad E Ginathom's Avatar
Thanked: 6,878 Times
Default Re: Tools for a DIYer
Super! That sheet is a good idea for stopping the box sliding on the wood too .
Whilst it is out of harm[ing] way, under a table, now, I have stubbed my toe on my toolbox a few times in the past. Perhaps I should have coated the whole thing in soft rubber!
By the way, re the dewatering pump in my earlier post: I bought a couple of rubber doormats to stand that on, as it vibrates and tends to walk on a hard, flat surface. I think they will reduce noise too.
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 1st September 2015, 16:28   #1112
Jaguar's Avatar
Thanked: 141 Times
settled for a Stanley 19" Plastic Tool Box
More on that and pics when I get the box in hand.
Here are the pics. Still have loads of space to fill up.
Jaguar is offline   (1) Thanks Reply With Quote
Old 1st September 2015, 23:05   #1113
Thanked: 13,079 Times
Just got a combination spanner set from PayTm during the 50% cashback offer. Not finding the listing again as another friend needs one.
Same link on Flipkart. Not able to get the link I saw on SnapDeal.
On Flipkart
Crude packing but should last well for the average usage. Insulated Red Grip Double Sided Combination Wrench Set:
Contents:
6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm, 17mm, 19mm, 22mm
Here are the pictures:
Old 4th September 2015, 16:01   #1114
DerAlte's Avatar
Thanked: 2,868 Times
... settled for a Stanley 19" Plastic Tool Box The store had only a display piece ...
Which store was this? Commercial Street or NR Road?
Old 4th September 2015, 16:29   #1115
Jaguar's Avatar
Thanked: 141 Times
Goodwill Enterprises, SP Road.
Jaguar is offline   Reply With Quote
Old 4th September 2015, 18:23   #1116
Thanked: 983 Times
You can get it online also
Old 16th September 2015, 12:58   #1117
Thanked: 1,037 Times
Bosch is running an exclusive offer on flipkart for its GSB 500 RE home kit of drill gun today at 2999 INR only. This is for one day only. And to top it, a 9 LED glow ring is being given out free.
unk9ja is offline   Reply With Quote
Old 16th September 2015, 18:58   #1118
stanjohn123's Avatar
Thanked: 377 Times
I'm searching for a 27 mm Hex socket bit with T bar handle.
I'm getting confused when I search online for Hex bits because I'm able to see 27 mm bits which has too many teeth's in it i.e multiple sides. The Hex socket I'm looking for needs to have just 6 sides so that it matches the nut I'm trying to unscrew.
Can anyone help me identify this socket and where can I purchase it online ?
stanjohn123 is offline   Reply With Quote
Old 16th September 2015, 19:27   #1119
diyguy's Avatar
Thanked: 111 Times
Found a cheap alternate here. May not be exactly what you want. There are other kits there or on flipkart with the 27mm but it is a set, which you may not need.
diyguy is online now   Reply With Quote
Old 16th September 2015, 20:14   #1120
adrian's Avatar
Thanked: 585 Times
What type of screw are you working on ?
adrian is offline   Reply With Quote
Old 16th September 2015, 22:10   #1121
Thanked: 377 Times
Thanks diyguy , the socket size is correct but something like the T-bar with this socket is what I'm looking for. I don't mind buying the set if it's around 2,000 Rs.
Something like the below
Old 16th September 2015, 22:21   #1122
Thanked: 377 Times
I'm working on an External Hexagonal screw.
what I'm trying to unscrew is shown on the image below. It's the oil filter.
Last edited by Gannu_1 : 17th September 2015 at 14:07. Reason: Back to back posts merged.
stanjohn123 is offline   (1) Thanks Reply With Quote
Old 16th September 2015, 22:44   #1123
Thanked: 5,883 Times
Not a hundred percent sure, but usually a normal socket should fit? Or just invest in an universal filter wrench. http://www.ebay.com/bhp/universal-oil-filter-wrench
Jeroen is offline   Reply With Quote
Old 16th September 2015, 23:27   #1124
SunnyBoi's Avatar
Thanked: 2,389 Times
Attachment 1415523
Cheapest I found was below:
http://www.tolexo.com/taparia-hexago...are-drive.html
You'll need "Socket Set Contains: 8,9,10,11,13,14,17,19,22,24,27,30,32 Accessories 1753,1734,1763,1633" "S-23H X L" part.
My honest advice wold be to just go to the local tool store, buy a 1/2inch L bar, 10inch extension rod and a 27mm socket. Wont cost above 450rs for all 3.
SunnyBoi is offline   Reply With Quote
Old 17th September 2015, 00:06   #1125
diyguy's Avatar
Thanked: 111 Times
Default Tools for a DIYer
I have two of these universal wrenches that can take any shape. My dad had purchased them and I have found it very useful when I don't find the right tool size or shape.
The set sunnyboi pointed out is reasonably priced and will meet your needs.
Bangalore : Fantastic store for tools kartikkumar Shifting gears 22 27th September 2012 01:15
Amplifier Installation Help: For DIYer nitin.dangayach In-Car Entertainment 52 10th March 2010 18:59
Power tools dadu Gadgets, Computers & Software 15 16th June 2008 12:05
tools for bike garage bullboy Motorbikes 1 11th September 2006 12:50
