Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 20th January 2011, 15:39   #31
Hashim's Avatar
Thanked: 32 Times
Default Re: DIY: Steering mounted Audio Controls.
Superb!! I was thinking to do something similar in my car but didn't got time. For your IR sensor blocking problem with pen drive, you can connect another IR sensor to your Headunit sensor and mount outside headunit somewhere at an angle that it receives signal without any obstruction.
Hashim is offline   Reply With Quote
Old 20th January 2011, 17:42   #32
ACM
ACM's Avatar
Thanked: 2,456 Times
Superb job, the finish though it could have been a bit better, still is quite good by itself.
Even those who are not zero in electronics would have been proud of this work.
It should inspire many to do this to their earlier vehicles as well as get you a line of customers.
ACM is offline   Reply With Quote
Old 20th January 2011, 20:12   #33
Desmosedici's Avatar
Thanked: 407 Times
Can we get a company made steering with audio control buttons and then modify it to work with the HU installed in any car. E.g. Get a SX4 steering which has the audio control buttons and install it on a old Swift and modify the way the controls work.
Desmosedici is offline   Reply With Quote
Old 20th January 2011, 22:13   #34
Ripper's Avatar
Thanked: 21 Times
@desmo: Yes its possible. All u need to do is open up the wiring loom and see what buttons are connected by which wire, once done draw a circuit diagram to make things easy and just solder the wires onto the existing remote, and your done. Can say this with confidence coz i have just checked out an i20's steering wheel with all conections. The only question will be whether there's enough space for the remote, once u figure that out, it'll be pretty easy.
@ACM: Thanks dude, will improve the finish the next time i plan to get my hands dirty. Hell ive already got a close friend who wants me to replicate this for his lancer, let see how that goes.
@Hashim: I had thought of this option earlier but the thing is i really dont want to open the front panel as its still under warranty, and if i mess something, ill be trashed by my folks. Will be buying a flexi usb connector to sort this issue. Thanks.
Ripper is offline   Reply With Quote
Old 20th January 2011, 22:23   #35
Ripper's Avatar
Thanked: 21 Times
@Utopian: Thanks bro.
@New.novice: For an aftermarket solution you could get a steering remote thats available at any accessory shop depending on the brand of your HU. Some universal remotes have come also come into the market, check which suits your HU and buy accordingly. I doubt if these would work if your HU is company fitted.
Old 20th January 2011, 22:40   #36
Ripper's Avatar
Thanked: 21 Times
amitwlele: Thanks Bro. have completed many DIY tasks in the past but never posted here. Will update the DIY forum soon.
Old 21st January 2011, 14:39   #37
motomaverick's Avatar
Thanked: 864 Times
Nice DIY, pretty interesting. Your USB problem could be solved by using the mini HP pen drives, these are pretty small.
Old 21st January 2011, 16:11   #38
shyamhegde's Avatar
Note from Mod : You have way too many spelling & grammatical errors in your posts. This negatively affects the forum experience for other members / guests.
You are hereby instructed to proof-read your posts prior to hitting the "submit" button. Thanks
shyamhegde is offline   Reply With Quote Received Infraction
Old 22nd January 2011, 01:20   #39
krish_go's Avatar
This is a very interesting work... very nicely executed... Good on you ripper.
I would surely try it on my Old Alto. Just a question. Where does power comes to this remote from the horn connections?
krish_go is offline   Reply With Quote
Old 22nd January 2011, 19:42   #40
Ripper's Avatar
Thanked: 21 Times
@shyam: Thanks bro. I first cut the spare remotes, then cut the horn/steering center and fixed it in position. Then used some spare plastics pieces, made its hot (as good as wax) and plugged the gaps with it. Kept pressing the molten plastic as far as it would go into the gaps. Later filed the exess. Then used plastic putty wherever neccessary, wet sanded, primered and finally painted with flat black paint. No copyrights .
@krish go: The remote uses its own power ie its battery CR2032. Will post pics of the insides soon to help u understand the jugaad.
Old 22nd January 2011, 19:56   #41
greenhorn's Avatar
Thanked: 1,315 Times
for those of you who are weak of heart, but want to do this
http://classifieds.team-bhp.com/buy-...g-Remove.html/
PS: not associated with the seller, am just a happy MPR 999 owner
Old 22nd January 2011, 23:18   #42
adg_andy's Avatar
Thanked: 161 Times
@ Ford madhan: The thing is that even the extension cable has a long plug (black rubber/plastic covering the USB cable) and it does not serve the purpose coz its as long as a pen drive.
dude,you can even go for a HP pen drive which has a very short stem, or for that matter even a thumb drive, which fits into a USB slot.
adg_andy
adg_andy is offline   Reply With Quote
Old 24th January 2011, 23:39   #43
Ripper's Avatar
Thanked: 21 Times
Smile Re: DIY: Steering mounted Audio Controls.
Pics of the internals as promised
Old 25th January 2011, 12:41   #44
Ripper's Avatar
Thanked: 21 Times
Added a video on youtube.
Old 25th January 2011, 15:23   #45
pramodkumar's Avatar
Thanked: 857 Times
Infractions: 0/1 (5)
Universal steering Remove?
@ Ripper, nice DIY, but let me be the devils advocate here and ask you few questions i have in mind before i go DIY.
1. What happens when you decide to upgrade or change your HU to a different Brand?
2. Why did you try fabricating steering mounted controls from other cars like SX4(looks nice and is a good fit)
3. If i am not wrong some Head units (blaupunkt) Have wiring looms and additions like steering controls etc, did you think aboutr getting one of those connectors before doing a open heart on your present remote?
4. As others expressed, battery changing will pose a problem so thinking of powering that too with the car electricals?
5. Finally can you mark each button and say what it does for better understanding?
Pramod
pramodkumar is online now   Reply With Quote
DIY Solution: Fiat Punto after-market Stereo + steering mounted controls eagle_bush In-Car Entertainment 25 13th February 2017 17:07
Stock Steering Wheel with Audio Controls Connected to After Market Headunit? Epic In-Car Entertainment 34 24th July 2014 12:36
Audio controls on Steering? hrishig Modifications & Accessories 89 21st December 2012 19:52
steering mounted controls in the i20 prasadka In-Car Entertainment 12 6th August 2010 09:37
