Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 27th October 2011, 14:49   #16
Default Re: Cabin Filter for Swift : Want to do DIY
Cabin filter filters the air that is being re-circulated. It needs to be cleaned every 5000kms. Otherwise, the quantity of air flow is HUGELY restricted. I have it installed in my alto.
Philips Go-Pure System costs about 12k MRP and is available for about 8.5k I believe. It filters the cabin air of all the bacteria and dust. The filter needs to be cleaned at least once in a year and costs about 1.5k. Connect it to the 12v Socket once in a while and the red light glows. After few minutes, it will glow green, when you can disconnect it. It is not a permanent attachment. I could not find a place where I can fit it in my Swift. Dash board sweeps down. Anything placed on it falls down. More than that, when taken for service, the service boys will start playing with anything that they find new.
specialist1968 is offline   (1) Thanks Reply With Quote
Old 27th October 2011, 19:27   #17
goandude's Avatar
Thanked: 455 Times
Originally Posted by mtnrajdeep View Post
The outside air vent opens directly above the fan and all the dust that comes through it will be vented into the cabin by the fan if this filer is not present.
Confusion reigns. Does anyone have a service manual of this car?
goandude is offline   Reply With Quote
Old 27th October 2011, 21:15   #18
mtnrajdeep's Avatar
Thanked: 101 Times
Hi Goandude, please see this post in Jaggu's thread AC Fan Cleaning DIY. You can see this yourself easily in your car. Remove the glovebox as mentioned in that post. Once you do that, you will see something similar to the third pic in Jaggu's post. Just switch on your car ignition so that the AC controls are on and switch on/off the AC recirculation switch. You will see a flap that opens and closes as per the switch position. This is the flap that allows outside air into the car when the recirculation mode is switched off.
Just below this flap is the place for inserting the cabin filter and below it the fan.
Hopefully, now your confusion is cleared
mtnrajdeep is offline   Reply With Quote
Old 27th October 2011, 23:53   #19
Thanked: 16 Times
hello friends,
i was just browsing the posts,recently i was there at suraksha bommanhalli for my alto service,there was a small advertisement regarding BOSCH cabin filters recently introduced.it had the cars for which this is available in india ,but there was nothing for alto mentioned .i asked my service advisor rajesh he said bosch is very good better than oem .thanks
chetan5678 is offline   Reply With Quote
Old 28th October 2011, 17:13   #20
goandude's Avatar
Thanked: 455 Times
I found a good diagram of the HVAC System here http://www.team-bhp.com/forum/techni...ml#post2560343 (Maruti Workshop Manuals?) and can now understand the working of the filter and the flaps. BTW I was in the hunt for the manuals for a longish time and finally found it.
Old 29th October 2011, 11:44   #21
Thanked: 28 Times
Can some put a pic of how that looks and is this available outside too? or only in the Maruti service center
jaygeetee is offline   Reply With Quote
Old 2nd November 2011, 12:36   #22
ANUJ GEORGE's Avatar
Thanked: 23 Times
See the picture where the filter fits in: The Black plate is a dummy, filter goes in there.
Second picture is of the filter element. I paid Rs 800 for the filter installation at the Ernakulam.
ANUJ GEORGE is offline   (3) Thanks Reply With Quote
Old 2nd November 2011, 20:29   #23
SAS
SAS's Avatar
Thanked: 60 Times
There is no filter installed by Maruti at the time of manufacturing but they sell that filter as MGP/SGP. It is left to the customer to install it. The place to fit it is present in all the cars.
Is one available for the Alto? If yes, I shall definitely install it. Mumbai roads are ridiculously dusty and even with the AC continuously on, you can still feel dust enter the cabin area through the nooks and crannies. I'd say this is an excellent investment. Saves us from dirty air and pollution.
Does it look similar to the filter pictured above? Any idea on the part number?
Last edited by SAS : 2nd November 2011 at 20:32. Reason: Didn't see the posted pic
SAS is offline   Reply With Quote
Old 2nd November 2011, 22:02   #24
mtnrajdeep's Avatar
Thanked: 101 Times
I think it should fit any Maruti model. Part number was something like 95860-63J10 (for SGP) and very similar for MGP model. You can check this out with Maruti Spare parts dealer in Mumbai.
mtnrajdeep is offline   (1) Thanks Reply With Quote
Old 3rd November 2011, 12:06   #25
deetjohn's Avatar
Thanked: 8,008 Times
ANUJ GEORGE, thanks for the pictures. I have a few questions.
  1. Is this setup behind the glove box?
  2. Do we need to cut the face plate? (the Black plate on which you have written "filter goes here")
  3. And, is the filter pushed into the box horizontally like a video cassette?
  4. Did you source the filter from a MASS at EKM?
Some post installation pictures will be really appreciated.
Edit: Does anyone know the status of this filter on the new Swift? Is it factory fitted?
deetjohn is offline   Reply With Quote
Old 3rd November 2011, 16:34   #26
goandude's Avatar
Thanked: 455 Times
Good pictures. I wish you had added an "after" with the filter in place.
Is the airflow reduced in any way with the filter?
BTW the your first picture is so much different from Jaggus third picture here http://www.team-bhp.com/forum/long-t...ml#post1193006
Old 3rd November 2011, 18:00   #27
Thanked: 23 Times
The reason being, the picture I have posted is from "Zen Estilo"
Here is the picture with filter in place, I hope it helps. The filter goes all the way in, I have pulled it out to give a better idea about its fitment. This fits just above the blower, and works for both "recirculation" mode and "fresh air" mode. I haven't seen any reduction in the air flow, but I will expect that as the filter gets clogged up.
@deetjohn,
Yes, you will have to remove the glove box to see this slot.
Yes, the black plate will have to go.
Yes
Yes, it is available from Popular motors EKM
According to the service adviser, non of the maruti models come with a factory fitted filter. I havn't specifically asked about the new swift though.
ANUJ GEORGE is offline   (2) Thanks Reply With Quote
Old 5th November 2011, 14:03   #28
SAS
SAS's Avatar
Thanked: 60 Times
Originally Posted by ssreeni View Post
The SGP model is for Swift & SX4 & the MGP model is for Wagon R, Alto & Estilo.
No filter can be washed and reused. Please check the Product info.
Hi
I today went to the service center how they did not have the AC air filter for the Alto. The stores guy said such a thing did not exist. I tried to convince him otherwise but I failed. I need this for my Alto (2005 Lxi BS3 model).
I have the following 2 questions:
1. Has anybody fitted this in their Alto?
2. What is the exact part number for the Alto?
3. Anybody from Mumbai can suggest where I can get this from?
Thanks guys..
Old 5th November 2011, 20:37   #29
Dr.Vikas's Avatar
Thanked: 47 Times
Hi friends,
I don't think this as OT, but what you all are discussing about here, comes by default with Skoda.. It's specifically described as 'Pollen Filter' & I often use to clean it of my own while vacuuming my Fabia.
It is located below the Glove Box and doesn't require any special assistance, (except to 'slide' down under the Dashboard in the leg space on the passenger side).. I don't know about the cost factor, but might be a costlier affair as compared to that of Swifts'!
I have seen the same in my friend's Linea also, but that needs some technical support to remove & refit the filter element..
Thanks & regards,
Dr.Vikas is offline   Reply With Quote
Old 5th November 2011, 22:32   #30
SAS
SAS's Avatar
Thanked: 60 Times
Originally Posted by Dr.Vikas View Post
Hi friends,
Thanks & regards,
It comes default on several vehicles. Even the Tata Nano has it by default, forget the Fabia.
Maruti has taken cost cutting to a new level, hence this isn't present on most Maruti vehicles.
DIY: Adding a Cabin Air Filter to the Honda Brio / Amaze / Mobilio noelnelly DIY - Do it yourself 42 27th December 2017 13:31
Hyundai i20 DIY: Replacing the rear wiper arm and cabin filter RocketRaccoon DIY - Do it yourself 26 23rd December 2017 10:12
Exhaustive DIY: Cabin AC Filter cleaning of the Ford Figo Blow Horn Ok DIY - Do it yourself 45 20th January 2017 20:46
Mitsubishi Cedia DIY - Cabin Air Filter Installation Captain Slow DIY - Do it yourself 1 27th May 2013 10:14
