Go Back   Team-BHP > Team-BHP > Road Safety > Drive Safe
Old 3rd June 2011, 16:49   #46
libranof1987's Avatar
Thanked: 4,369 Times
Default Re: Emergency Driving - 'While' Driving
Originally Posted by ukderebail View Post
The showroom technician states that if the vehicle stalls than roadside mechanics cannot repair the car, in that case do we have to call for towing the vehicle or it can be set right by a authorised dealer mechanic at the spot.
A lot depends on the type of problem. If the issue is minor, you could have a road side mechanic do a stop-gap arrangement.
If the issue is complicated, like busted engine parts, then it's better you tow the car to a A.S.S.; especially if your car is under warranty.
libranof1987 is offline   (1) Thanks Reply With Quote
Old 3rd June 2011, 17:21   #47
dhanushs's Avatar
Thanked: 4,530 Times
There can be a lot of reasons for a vehicle to stall whist running. Starting from blown fuses, to clogged fuel lines, bad ignition, frayed wires, intake, sensors going kaput, overheating etc..etc.. and the list goes on......
The best thing to do then would be to call the helpline of the particular manufacturer. Those guys do know a bit or two about dealing with car specific roadside emergencies. You just need to explain the symptoms in detail. They even give us a step by step DIY technique.
Again, if that does not suffice, and the vehicle do needs to be towed, (like when overheating) do follow the guidelines given in http://www.team-bhp.com/forum/techni...ut-engine.html
Old 1st July 2011, 04:44   #48
dhanushs's Avatar
A fellow bhp'n posted a useful video elsewhere in the forum. I thought a link of that video would do justice to this thread.
Roadside emergencies: How to start a car with jumper cables.
Emergency driving - Without brakes sudev Drive Safe 83 21st September 2013 19:23
Emergency driving - Without clutch sudev Technical Stuff 93 24th April 2013 10:20
Emergency Driving - Without engine power sudev Technical Stuff 29 8th July 2012 08:41
First Aid box and Emergency ToolKit required major Modifications & Accessories 0 28th March 2006 18:39
