| | Thread Tools | Search this Thread |
![]() | #151 |
BHPian Join Date: Mar 2012 Location: New Delhi
Thanked: 203 Times
| ![]() An attempt at explaining the reason behind the Taj expressway accidents: One of the most common news concerning the newly constructed Taj Expressway are car tyres getting punctured, due to which many lives have been lost. The question arose in my mind as to why such incidents are happening so frequently in one of the most modern roadway in the country. The cause behind majority of the accidents were the same - tyres getting punctured while on high speed (which is common in the expressway). So what is the actual reason behind these occurrences, when it is not that someone comes every night and sprinkles nail on the tar ![]() We got the BMW X1 SUV from one of our team-members for the test. Please keep in mind, the original focus would be on the tyres. First, we checked the pressure of the tyres and set it to 25 PSI, in accordance with the international standards (cars in all developed countries maintain this pressure level diligently while most of the people in our country are either not aware of this or maintain pressure level as high as 35-45 PSI in order to get higher fuel economy). Now lets get on with the test at hand. Next, we left for the Taj expressay from Noida. We maintained high speeds. After driving the car in this manner for about 2 hours, we reached the periphery of Agra. On checking the tyre pressure before Agra, we were presented with startling results. The tyre pressure was 52 PSI. Now the question arises as to why the tyre pressure increased so drastically. We used a thermometer to check the exterior tyre temperature. The temperature highlighted it at 92.5°C. Now all the pieces of the jigsaw was before us along with the complete picture. Analysis: The heat produced as a result of the friction of the tyres with the road surface and the rubbing of the brake pads constantly, expanded the air inside the tyres to such an extent that the air pressure increased proportionately as a result. However our tyres, as an exception, contained air pressure in accordance with the international standards from the beginning. But for those tyres which had air pressure more (35-45 PSI) from the beginning itself or had cuts on the circumference, the probability of accident for such tyres increases exponentially. Hence it is submitted: Before driving on the Taj Expressway, get the correct air pressure for your car tyres and enjoy the journey safely. It is also requested of the Expressway authorities to create an awareness on this topic for all drivers on this route so that it is not their last journey. Credit: Translated from the originally article by Manoj Gupta in Hindi published in a social networking site. Last edited by Eddy : 27th June 2014 at 22:29. Reason: Editing the high speed reference. |
![]() | #152 |
BHPian | ![]() And no doubt pressure is the most important factor for not just this, but other concrete highways as well. Was the speed rating of the tires on the X1 checked? That could also affect the heating, and hence increase in air pressure. Last edited by Eddy : 27th June 2014 at 22:29. Reason: Original post edited |
![]() | #153 | |
Senior - BHPian Join Date: Feb 2010 Location: Wellington
Thanked: 1,761 Times
| ![]() Quote:
At the speeds you were doing, I would have checked pressure after something like 25-50km, just to be safe and aware of what is happening. You were doing really high speeds. I have seen a increase in the range of 2 psi on hot summer days, speeds in the vicinity of 80-120kmph. Its also down to ambient temperature. It is quite possible that tire bursts are observed more in summers than winters. I suggest a controlled environment if you want to do something like this. | |
![]() | #154 | |
Senior - BHPian Join Date: Oct 2008 Location: Bangalore/Pune
Thanked: 1,572 Times
| ![]() Quote:
PS: The Taj Expressway is a tyre eater. Cheers, Jay | |
![]() | #155 | |
BHPian Join Date: Jun 2014 Location: Bangalore
Thanked: 87 Times
| ![]() Quote:
Also lower pressure is suitable for good (smooth) roads only. If the required pressure is not met, the impact of going over huge bumps/potholes (rarity in developed countries) will be transmitted to the alloy, which may break. The pressure difference is quite high. Did you use the same guage both times? On a related note, if it is raining heavily out, I don't bother to check the tyre pressure. Less pressure on wet roads gives more traction. | |
![]() | #156 |
BHPian | ![]() Another option is using nitrogen gas, when travelling on highways. Its available in most cities now. The gas doesn't expand with heat and helps to keep the tires cool as well. |
![]() | #157 |
BHPian Join Date: May 2006 Location: Vadodara, IN
Thanked: 139 Times
| ![]() I think the OP has inadvertently found out the reason for the accidents - high speeds way above legal limits on tyres rated for much lesser speed. The heat - air expands - tyre bursts part is pretty obvious I suppose. I don't know why you need any analysis to find that out. Last edited by Eddy : 27th June 2014 at 22:30. Reason: Original post edited |
![]() | #158 |
BHPian Join Date: Dec 2012 Location: Chennai
Thanked: 252 Times
| ![]() Correct me if I am wrong. I believe that under inflated trye will cause more flex in the side walls. This flexing over a period of time may cause crack on the side walls eventually leading to a tyre burst. The flex will be minimal on a slightly overinflated tyre. Also speeds should be maintained as per the speed rating of the tyre. Last edited by rajivr1612 : 27th June 2014 at 22:21. |
![]() | #159 | |
BHPian Join Date: May 2011 Location: Noida
Thanked: 18 Times
| ![]() Quote:
The authorities have already done the heavy lifting by finding out a speed that offers a nice margin of error so I don't see why they should suggest a solution that does not address the problem at all - why violate the legal speed limit willingly for no reason? Last edited by Eddy : 27th June 2014 at 22:30. Reason: Original post edited | |
![]() | #160 |
Senior - BHPian Join Date: Jul 2009 Location: Emerging Metro
Thanked: 1,748 Times
| ![]() What is the speed rating of the tyres on the BMW X1 test car, the make of the tyres and what is the car manufacturer suggested air pressure? Ut would be interesting to analyse the rate of temperature rise on tyres inflated to 30 PSI. Last edited by rajeev k : 27th June 2014 at 22:27. |
![]() | #161 | ||
Thanked: 203 Times
| ![]() Quote:
It was a test, which wasn't conducted by me. But thanks, shall convey the same to the appropriate parties. Last edited by SJD@NewDelhi : 27th June 2014 at 22:30. | ||
![]() | #162 | |
BHPian | ![]() Quote:
Also, conducting such a test without appropriate permissions is not the best idea - for every road users safety, including the tester. That said, would really like to get more details if they're available. | |
![]() | #163 | ||||
Senior - BHPian Join Date: Jun 2013 Location: Noida (U.P)
Thanked: 1,844 Times
| ![]() Quote:
I highly recommend you to always keep the speed under control and also give you a friendly suggestion of not taking any car for granted. It's a machine at the end of the day and a slight human error can be far more dangerous. Quote:
Lastly, Correct me if I am wrong, BMW does not come with spare wheel and in the event of a flat Tyre it can still travel up to certain distance at some 50 kmph. You should have taken a less-advanced car which could have given you much better results about your experiment. Thanks. Last edited by ad3952n : 27th June 2014 at 22:51. Reason: Edited the quoted Opening post and the reply. | ||||
![]() | #164 | |||
Distinguished - BHPian ![]() Join Date: Mar 2011 Location: Back to Chndgrh
Thanked: 3,751 Times
| ![]() Quote:
have a look at BMW X1 pressures from a UK site http://www.puretyre.co.uk/bmw-tyre-pressures/ Quote:
![]() | #165 | ||||||||
Distinguished - BHPian ![]() | ![]() Quote:
Saying... Quote:
http://www.edmunds.com/car-care/shou...-nitrogen.html http://www.arb.ca.gov/cc/tire-pressu...lipr051308.pdf | ||||||||
Thread | Thread Starter | Forum | Replies | Last Post |
360 spin in swift after tyre burst - Phew!!! was close!!! | dreamdiesel | Street Experiences | 76 | 11th December 2014 14:39 |
How to handle (and prevent) a Tyre Burst / Blowout | GTO | Tyre & Alloy wheel Section | 0 | 7th November 2012 20:53 |
Montero Tyre Burst. 4 Killed ! | rahulsingh007 | Street Experiences | 53 | 8th February 2009 14:38 |
A burst Tyre | mentos | Street Experiences | 9 | 21st October 2008 02:09 |
Tyre burst! | zen | Street Experiences | 7 | 29th April 2006 18:50 |
