Go Back   Team-BHP > Team-BHP > Road Safety > Drive Safe
Old 12th February 2008, 12:19   #16
benbsb29's Avatar
Thanked: 4,326 Times
Originally Posted by spadival View Post
That barrier probably kept you on the road. Cant imagine what would have happened @ 120kmph if the barrier wasn't there.
I would assume the worst if the rear hadnt banged into the side barrier. Probably the vehicle would have flipped over. Thank your lucky stars, buddy.
A high speed run on an SUV and slamming the brakes is a recipe for disaster.
Old 12th February 2008, 12:24   #17
adc
adc's Avatar
Thanked: 2,103 Times
You and your family are safe and sound, thats a great relief.
Well what you experienced on the highway
Originally Posted by dadu View Post
As I approach them at a car's length to my horror the rear eicher truck suddenly attempts to overtake the bigger truck from the left and I could see his left nose starting to protuding out of the lane, no hand signal, no indicator.
is a situation that you will be facing somewhat often rather than rarely.
Well this is what I follow always [again after facing myself a similar situation and that on a M800] when I overtake a series of trucks at high speed in daylight situation:
1. Have all headlights on power beam.
2. A series of horn sounds in a rhythm pattern [like beep - beep - beep] as a I approach from a distance and increasing the intervals between the horns as i go past the trucks.
3. I look and keep an eye on the truck tyres and see its relation with the white divider mark line, by that you can make out early [rather than seeing the truck body] what the bugger is upto.
4. As you had no way on the right side, a left side overtaking does become necessary on the highway in some situations. These I do only when there is sufficient space on my left side also. i.e, a lane plus some space. Never when it just makes a tight fit.
Dont worry too much but definitely you will be carefull in such situations - let not this make you stop enjoying the Safari for what is meant to be - driving on the highways.
adc is offline   Reply With Quote
Old 12th February 2008, 12:26   #18
jkdas's Avatar
Thanked: 1,437 Times
High speed mean 100plus or 120plus? Curious.
Old 12th February 2008, 12:29   #19
Thanked: 245 Times
I was honking but stopped when I neared them since I was observing them from far away and they were driving their lane and were following each other closely. So started concentrating on the overtaking then.
There was no other way than braking with the truck nose on my right and barriers on the left. Everything happenned in a fraction and the reaction was instinctive.
But I learned my lesson, speed was high, should have honked and used the dippers, which I usually do, but perhaps confidence overtook me.
Old 12th February 2008, 12:31   #20
suman's Avatar
Thanked: 265 Times
If you don't have ABS, yes, it is a tricky situation; but he really didn't have a choice as he was already committed to the manuever
Very true
Old 12th February 2008, 12:31   #21
Thanked: 245 Times
Thanks theMAG , have sent a PM to vip3r .
You could try MotorSmith behind Ragigudda Temple. He either is/used to be an authorized Tata service station. PM v1p3r - who works there, for details.
Definitely ABS, in my next car.
Originally Posted by jaibir View Post
dadu, glad to hear everyone is safe.
I guess your experience would make you value ABS more for high speed driving.
Old 12th February 2008, 12:34   #22
Thanked: 64 Times
Dadu,
That was really close. Glad to know that you are safe. Take care.
hondadude is offline   Reply With Quote
Old 12th February 2008, 12:41   #23
suman's Avatar
Thanked: 265 Times
I don't believe that you are saying that, not after all our exchanges on other threads about the usefulness or applicability of ABS on our roads
But, a very wise decision as & when you do go for it
Old 12th February 2008, 12:48   #24
iraghava's Avatar
Thanked: 156 Times
Good to know it didn't mothball into a major situation & you escaped with mild damage to the Safari.
However, another thing that might help you are good tyres. Next time when you go in for a tyre change buy something better than the stock Dueler's & you might just be surprised with the difference they make to the braking & handling.
P.S. Suman - C3PO does indeed work at Motorsmith's.
Old 12th February 2008, 13:04   #25
suman's Avatar
Thanked: 265 Times
Oh? I stand corrected then - I thought it was one of Mahesh's usual gags
Hmmmm, the JW Red is still playing up, you mean snowball
Old 12th February 2008, 13:08   #26
Thanked: 245 Times
OT: I never had any problems with ABS, only had disagreement on where it will help and where not.
In my case, it would have helped in the manueverability.
Old 12th February 2008, 13:14   #27
akroy's Avatar
Thanked: 60 Times
dadu, thats a major accident averted, hats off to the safari !!
I strictly follow point 2 & 3 mentioned by adc, that helps a lot in the highways specially the multiple honkings before overtaking
I also sometime see the Rear View Mirror of the bus/truck, more times the driver do have a glance at you...
Abhi
akroy is offline   Reply With Quote
Old 12th February 2008, 13:22   #28
iraghava's Avatar
Thanked: 156 Times
Nahi nahi, it was Blender's Pride last night!
Old 12th February 2008, 13:25   #29
gd1418's Avatar
Thanked: 656 Times
The close-up shot of the big scratch shows how close it was to a bigger damage. All that thick steel from TISCO was a saviour. Actually should've stopped that errant truckwallah and knocked some sense in his head.
Didn't he know how to use his RVM? There are certain etiquettes of Highway that these truckers etc. follow. Seems he didn't.
Glad to know Dadu, that you & fam are safe. Drive safe..
Old 12th February 2008, 13:27   #30
rjstyles69's Avatar
Thanked: 796 Times
Well the inevitable never stops in its way. I don't intend to rub salt into your wound, but then this is very common on the GQ.
I think you should have been extra-careful and expected the worse.
I immediately brake hard and instinctively moved the steering slightly to the left to avoid a direct hit (my wifey told me speedo was at 120). Big screeching noise/ rubber burning and I guess that made the overtaking truck move back into his lane immediately.
If I were to see two trucks driving parallel to each other I certainly would slow down.Coz I know these nitwits are capable of a last minute mood swing and will change lanes.
Nevertheless all is well and thank god you and your family are safe. The beast can always be repaired.
Potentially Fatal Accident Averted ntomer Street Experiences 53 15th September 2010 13:24
My first major accident...! veyron1 Street Experiences 38 13th June 2009 12:49
My First major accident - In the U.S. and I wasn't driving lamborghini Street Experiences 31 11th June 2008 23:55
Major multiple vehicle accident on ring road Delhi tsk1979 Street Experiences 2 28th December 2006 15:30
Another major fatal accident on Goa-Mumbai Highway emkay456 Street Experiences 14 31st October 2006 18:18
