Go Back   Team-BHP > Team-BHP > Road Safety > Drive Safe
Old 13th February 2008, 13:30   #61
suman's Avatar
Thanked: 265 Times
Originally Posted by rks View Post
When you approach an overtake at much higher speeds than the overtaken vehicle, you have committed yourself to the overtake a lot earlier than necessary, especially given our erratic traffic. Then you should have enough margins to swerve and a maneuverable vehicle that can swerve at those speeds. In the absence of either, you are taking a big risk.
Just out of curiosity, how do you determine the speed of the vehicle you are overtaking so as to get that perfect 20 kmph difference?
Do you have some kind of software which does this for you every time you approach a vehicle on the expressway?
Also, why propogate the theory when you do not follow it yourself?
Old 13th February 2008, 13:46   #62
Thanked: 32 Times
Its good that nothing major had happened, But what made you to overtake from the left. This is simply a voilation of the basic driving norms. Just you cud have had little more patient and possibloy in a min the trucks must have been given you way thanks to your honking.
Never ever overtake form left Sir. If the truck would have not been moved backed right in its lane, the story could have been much difirent to share.
Drive Safe buddy, whaever car you are driving.
vipul_bscity is offline   Reply With Quote
Old 13th February 2008, 14:05   #63
gd1418's Avatar
Thanked: 656 Times
No I don't. My blaring twin Stebels & the blazing roof quadruplet lights make sure the errant truck, bus & hapless Sedans stay put on the extreme left side of the road..period.
Originally Posted by Steeroid View Post
Out of interest, Guruji - do you compute the speed of the vehicle you are about to overtake before you overtake him in your mad Scorpio?
Old 13th February 2008, 14:10   #64
finneyp's Avatar
Thanked: 176 Times
Does that mean off the road? And you own a Scorpio, rite?
finneyp is offline   Reply With Quote
Old 13th February 2008, 14:19   #65
tsk1979's Avatar
Thanked: 16,459 Times
Many Buses and trucks drive in fast lane at 40kmph and on being honked wave you on from left.
If you plan on overtaking from right only be prepared to drive at 40kmph all the way, and if you encounter a tractor, at 15kmph all the say
Old 13th February 2008, 14:21   #66
Thanked: 18 Times
Thank God Dadu , that your presence of mind prevailed and you avoided a major mishap and i recall a friend of mine (with family) in a santro had an accident involving a motorist who just merged onto the road without yielding and to avoid hitting him (with family) he swerved to the right and lost control of the vehicle and was off the road into the gravel track with the car taking a major beating in the process. Nothing major happened but i think this road is quite prone to such mishaps.
VJ_MAVRICK is offline   Reply With Quote
Old 13th February 2008, 14:35   #67
Thanked: 245 Times
I am aware of that and when I used to drive on the northern highways I would always overtake from the right only unless forced to from the left, in which case it wont go without a shouting at the driver.
But here in the south, things are different, you travel on any multilane highway (mysore rd, GQ) and you will find heavy vehicles taking the right lane and always keep on the right with smaller ones overtaking from the left and moving on. Unless they are already keeping a left lane they just dont move lanes for you.
I would say speed is a major factor in these kind of incidents, with lesser speed you have better control.
Old 13th February 2008, 15:10   #68
vnabhi's Avatar
Thanked: 1,343 Times
I suppose slow moving heavy vehicles stick to the right-most lane as it is more level than the left lane, and this makes a lot of difference to the stability of the truck when they are carrying heavy loads.
Waiting for such vehicles to move left is hopeless, as they would do that as the last resort, keeping their stability in mind. We are left with no option than to overtake from the left, but after honking all through the overtaking manoeuvre.
You are lucky Dadu, for getting away with minor damage.
Old 13th February 2008, 15:17   #69
rks
rks's Avatar
You should know the appropriate speed at which to perform an overtake through your experience. If you need to calculate the same then you are better off not driving at high speed.
I have lost count of the number of times I have swerved to avert accidents while overtaking on our highways, in both the M800 and especially in my Santro. On the Expressway there are wide margins and I have swerved quite a few times in the last 3 years to avoid lane-cutting and slow-moving vehicles. I am very scared of the slow-moving lane-cutters, much more so than those who cut lanes at 120+ kmph, for obvious reasons. In the absence of such swerving space, you should slow down, again for obvious reasons.
If I were driving an SUV anywhere other than on Expressways I wouldn't even be close to the sustained speed levels I am doing presently in my Santro. SUVs are less maneuverable and need a lot of road space for speeding and that doesn't exist on most of our highways.
Old 13th February 2008, 15:20   #70
finneyp's Avatar
Thanked: 176 Times
Now this is debatable, I am of the view that when we overtake from left, better not to honk and scare the driver to turn left or right, just pass through him.
Yes, when overtaking from right, we need to honk/dip at night just to alert him that we are overtaking.
Old 13th February 2008, 15:21   #71
suman's Avatar
Thanked: 265 Times
That doesn't answer my question at all. Experience, judgement etc are extremely subjective terms.
My experience tells me what fellow member Surprise had mentioned
While traveling at 120 kmph, one will try to maintain that speed until he/she is forced to slow down either by the road or by a vehicle traveling in their lane. So I guess its very difficult to follow this book rule (if its there)
It just reiterates my initial impression that you are touting an impractical & impossible business model which would hold good only in the utopian world. You are not even following it yourself else how do you justify "average" speeds of 100 kmph going up to top speeds in excess of 140 kmph?
Old 13th February 2008, 15:29   #72
vnabhi's Avatar
I agree it is debatable, but the thick-skinned drivers are not gonna be scared to sverve to the left. For all that I know, they would not even budge even if a battle tank was behind them. They expect you to overtake them from the left, and that is it.
Old 13th February 2008, 16:14   #73
rks
rks's Avatar
I simply do not agree with what Surprise mentioned above. If you do not have adequate margins for swerving and/or if your vehicle cannot swerve at high speeds, there is no way you should be doing sustained 120 kmph speeds. That is asking for trouble on our roads. I can understand that approach in foreign countries with a high level of lane discipline on their roads.
On the Mumbai Pune Expressway I do sustained high speeds, including high-speed overtakes, only because I have a relatively small maneuverable vehicle that can swerve at 140+ speeds and there is enough swerving space. Even then I watch the overtaken vehicles very carefully.
Old 13th February 2008, 16:17   #74
suman's Avatar
Thanked: 265 Times
On the Mumbai Pune Expressway I do high-speed overtakes only because I have a vehicle that can swerve at 140+ speeds and there is enough swerving space. Even then I watch the overtaken vehicles very carefully.
To each his own RKS but - is that the Santro you are referring to that can do supposedly safe swerves at 140+?, I'm outta here before I lose it altogether & crack up.
No offense meant.
Old 13th February 2008, 16:18   #75
Thanked: 1,714 Times
Bully! Now I understand why certain threads come up here.
@ suman - why do you bother????
Steeroid is offline   Reply With Quote
Potentially Fatal Accident Averted ntomer Street Experiences 53 15th September 2010 13:24
My first major accident...! veyron1 Street Experiences 38 13th June 2009 12:49
My First major accident - In the U.S. and I wasn't driving lamborghini Street Experiences 31 11th June 2008 23:55
Major multiple vehicle accident on ring road Delhi tsk1979 Street Experiences 2 28th December 2006 15:30
Another major fatal accident on Goa-Mumbai Highway emkay456 Street Experiences 14 31st October 2006 18:18
