Go Back   Team-BHP > Team-BHP > Road Safety > Drive Safe
Old 5th March 2009, 22:03   #46
Thanked: 158 Times
If you cannot avoid the puddle, Your best bet is to threshold brake before you hit the puddle.
your car should be perfectly neutral[/b].
By getting the vehicle into neutral the vehicle gets a free flow and could lead to nowhere, its better to control the car by shifting to the lower gear (eg - shifting from 4th to 3rd and leaving the clutch slowly) which slowers the vehicle.
gowda79 is offline   Reply With Quote
Old 5th March 2009, 22:14   #47
BlackPearl's Avatar
Thanked: 4,713 Times
I think he did not mean the gear to be in neutral, he meant no braking or steering while hitting the puddle.
BlackPearl is offline   Reply With Quote
Old 5th March 2009, 23:25   #48
Pseudosage's Avatar
Originally Posted by Atlblkz06 View Post
When you enter the puddle, your car should be perfectly neutral. Hang on to the steering wheel firmly and do not turn at all.
Last time I hit a puddle, although I released the gas & brakes and kept the car straight, it fishtailed (rear wheels probably lost traction, I don't know). I had to correct the steering both ways (like Spetnaz's zig zag). In the process, the car both straightened and slowed down significantly. I thank God I had room to get away with it! I agree, under these circumstances the 1st priority is to keep the car as slow and direction-neutral (if I can call it that) as possible. Not only do we have to worry about hydroplaning, but mudplaning as well, considering the almost perpetual state of work-in-progress on our roads.
Pseudosage is offline   Reply With Quote
Old 7th April 2009, 09:12   #49
Post deleted by the Team-BHP Support : Please do NOT SPAM the forum. One-liners that add absolutely no value to the thread are strictly prohibited on Team-BHP.
We advise you to visit our board rules section before proceeding any further.
binoyjude is offline   Reply With Quote Received Infraction
Old 26th May 2009, 10:25   #50
johnda's Avatar
Thanked: 11 Times
Default Monsoon Care!
Down South the monsoons have arrived and thus its slowly water everywhere!
No complains about it- just that our cars are going to be in the NEXT season for at least 3 months.
I have an OHC that is parked out in the open (no covered parking at home or at work)
Its impossible to keep the car dry. but there are thing that can be done to keep the car SAFE. with care related to:
rust, (places that water is always logged in)
slush scratches,
wiper and windscreen efficiency,
Paint and body,
driving in the rain,
flood care!
avoiding a wet interior and damp smell
and so much more...
I guess we'll all learn with input thrown in here.....
Mods: this falls in the car care section please move or merge if necessary
Joe
johnda is offline   Reply With Quote
Old 26th May 2009, 10:38   #51
hillram's Avatar
Thanked: 965 Times
Very important thread.Thanks Jon.
With Monsoons setting in,every car will be subjected to nature's fury.few tips from my side:
1.Check the wiper wear and tear and get replacement done if necessary.
2.Top up Wiper wash fluid.Normally all cars carry 2-4 litres.
3.Check the working of rear defogger as this is a necessity.
4.During a rainy day,switch on your fog lights/parking lights and drive on,so that the incoming car knows your presence on the road in misty and rainy condition.
5.Finally drive carefully in rain,avoiding pot holes,man holes and dont exceed great speeds.
hillram is offline   Reply With Quote
Old 26th May 2009, 10:47   #52
jesal's Avatar
i have an i10. 6 months old with sunroof. i want to make sure i have no leaking problems. should i seal off the sunroof for the monsoon with think tape ? or am i being overly protective ?
jesal is offline   Reply With Quote
Old 26th May 2009, 10:53   #53
Gagan.js's Avatar
Just go to the service station and ask them to inspect it.
Gagan.js is offline   Reply With Quote
Old 26th May 2009, 10:53   #54
prince_pervez's Avatar
Thanked: 32 Times
Good Thread! There is a thread which talks about car care during the rains, started by GTO. I think this topic should be appended there.
http://www.team-bhp.com/forum/owning...ing-rains.html
Anyway, my contribution:
For a car standing outside, one of the biggest threat is hailstones.
Dents on the roof and hood, crack windshields..you name it.
One more thing. Should the cover be on when its raining?
Will it affect the car paint when the rains stop and the hood is still wet and on the car?
prince_pervez is offline   Reply With Quote
Old 26th May 2009, 12:03   #55
amtak's Avatar
Thanked: 366 Times
I think for people living in coastal areas like Mumbai/Vizag etc, one should try not to park the car under the tree, as the chances are quite high that the tree might be uprooted due to strong winds. For that matter, I try to avoid it in all seasons!
Secondly, keep some emergency torch inside the car. It would be good if you can keep the ones that fit the cigarette lighters sockets as they are quite powerful and can prove to be helpful if struck somewhere on a rainy night.
amtak is offline   Reply With Quote
Old 26th May 2009, 12:15   #56
Thanked: 21 Times
Default Highway driving in rain
While driving on highways and long trips, we used to increase tyre pressure by 1-2 psi than recommended.
Do we need to keep following the same in rainy season also? or can we reduce tyre pressure by 1-2 psi so that we can have more grip in rain?
Experts can you please shower some info!
shabahmad is offline   Reply With Quote
Old 26th May 2009, 12:24   #57
asr245's Avatar
Thanked: 363 Times
Carry a couple of cigarettes or a pouch of tobacco in your glovebox. If visibility becomes a problem due to heavy rainfall, rubbing tobacco on the windscreen works wonders.
A bit confused.. do you mean from inside to prevent misting or on the outside?
asr245 is offline   Reply With Quote
Old 26th May 2009, 12:32   #58
Thanked: 32 Times
I think outside. I've seen truckers rub tobacco on their windshields from the outside. Improves clarity.
Old 26th May 2009, 12:52   #59
ACM
ACM's Avatar
Thanked: 2,652 Times
If sealing of the sunroof with tape were to be required then you might as well not have bought a car with a sun roof.
the sun roofs have a drainage system that is hidden below the actual roof and above the soft cladding that we see from inside. (At lease that's the way in my Laura).
There should be no leakage from above under any circumstances, but if the water drainage system is blocked with leaves then you could end up with water near you feet.
Dont bother about the roof till you see some water inside, and when you do take it to the service centre to rectify under warranty.
ACM is offline   Reply With Quote
Old 26th May 2009, 12:56   #60
rkbharat's Avatar
Thanked: 613 Times
before it arrive here in Delhi(and I wish it arrive ASAP), I need to switch to Bosch wiper. Current pair have already crossed an year.
rkbharat is offline   Reply With Quote
ARTICLE: Safe Driving on Indian Highways & Ghats GTO Drive Safe 284 21st February 2018 03:36
ARTICLE: Guidelines & Tips for Safe Driving in FOG SS-Traveller Drive Safe 72 16th November 2017 10:41
ARTICLE: Guidelines & Tips for Safe NIGHT Driving GTO Drive Safe 122 26th September 2017 04:54
Driving in the Rains - Tips normally_crazy Technical Stuff 210 20th April 2010 19:17
