| | Thread Tools |
| | #31 (permalink) | |
| BHPian | Quote:
![]() yes its great and finally all the points needed are in ONE place and not in my inbox of pm;s ! Thank you sir this post has been and shall be continued to look at by myself and many a potential buyer from t-bhp and outside as well
__________________ Chill Pill Blaze | |
| | #35 (permalink) |
| Senior - BHPian Join Date: Oct 2005 Location: Currently at Chennai. Originally from Blore.
| Hey RT, any tips for a first time SBK rider? I've always wanted to ride one but have been either turned down (as i have never ridden one before) or I myself have backed out (owing to the reason above) for fear of wrecking the bike due to the sheer power of the machine.
__________________ Avoid hangover's.... Stay drunk !!! Yella OK, Cool Drink Yaake ??? |
| | #36 (permalink) |
| Senior - BHPian | Superb. I'm dumbfounded, really. Very interesting read, Robin. This entire advice section has got me all blared up. Kindly allow me to add my 2 cents. On Riding A Superbike. For First Timers: The key is not to be intimidated by the girth of the machine. Remember, it's a machine. It reflects you and your thoughts. It shall do unto thou as thou shalt to it. 1) The first step is to get a feel of the bike. We're all used to Splendors, Pulsars & ZMA's. They all have an upright or tourer-type riding position. All SBK's are front-biased, and the first thing you'd notice on any superbike/supersport is the lean angle. You have to stretch to reach the bars, and the tank bulges up your belly. Sit on it, grab the bars, and feel the controls first; depress the clutch, brake, etc & feel the lever/pedal pressure. Raise one foot, rest it on the peg, and feel the riding position. 2) Start the engine. Remember not to open the throttle while cranking the starter. Especially in case of MPFI's. 3) Keep one eye on the tacho. Always. Never let it cross 3000 RPM. This is easier said than done, since the throttles are caliberated such that the first mm of throttle play plunges the tacho into the redline. Therefore, get a feel of the throttle at idle first before slotting into gear. Most SBK's have clutches actuating at the final 2-3 mm of lever play, so remember to release the clutch slowly. 4) For the first 500 km or so, do not accelerate above 7000 RPM. Bingo. You're there. Basic Riding Tips: 1) The first thing to get used to in an SBK is not the acceleration, but the braking. Strange? Yet true. Speed's no good if the anchors can't stop her on dime. Therefore, spend the first few hundred kilometres familiarizing yourself with the brakes. With most SBK's having four-pot callipers (and some having six) at the front, braking takes a little time getting used to. Try to bias your braking towards the front, until you're fully aware of the lever feel, suspension dive, front grip levels, etc. Ideally, your braking should be biased 90:10, to the front; on dry tarmac. Wet, 60:40. 2) Second is engine braking. These phenomenally powerful engines also have phenomenally powerful engine braking. How to utilize that? Here you go. This's advisable to be tried on a small bike first. Whenever you feel the need to shed speed, depress the clutch, blip the throttle, downshift, and release the clutch. The more urgent the situation, the more number of downshifts you can execute sequentially. In an ideal scenario, for perfect braking, you'd also utilise the front and rear brakes while doing this. 3) Now comes the acceleration part. An important point to note here is that in most SBK's, you don't need to rev the pants off the block to gain maximum thrust. Once you get familiar with the bike, try to find the "sweet spots". These are RPM's at which the engine shows power peaks. For example, the Pulsar DTS-i type 1 (idiotic example in an SBK thread, but nevertheless) redlines at 9,500 RPM. But it's pointless to revv her all the way in each gear. There's a sweet spot between 8200-8700 RPM, at which, upshifts produce maximum acceleration. 4) Cornering is one of the trickiest aspects in a SBK. For every corner, there's a rule. If you enter fast, you HAVE to exit slow. If you enter slow, you can exit fast. Make sure you calculate the corner well in advance. You should have braked to the cornering speed within 10 meters of the curve's entry point. Remember the SIFO (slow-in-fast-out) rule. 5) While cornering, lean angles are not as important as traction. Therefore, do not try to imitate Doohan. Or Rossi. Or Hayden. Street riding with hard compound tyres is a different ballgame. Watch ghostrider videos to see what I mean. Avoid mid-corner corrections as far as possible. While leaning into a corner, push the outer footpeg with the heel, and try to balance your weight inwards. The key is to try and keep the bike as straight as possible, (for maximum contact patch and traction) while gaining maximum speed. Easier said than done, and this takes practice. Especially with litre-class, where-in a mid-corner bump can upset you, and a mild throttle twitch could send you tramlining, wide outwards.. The quickest way to steer yourself out of trouble is counter-steer, but let's skip that. 6) DO NOT BRAKE MID-CORNER. This is a thumb rule. Never brake when the steering/handlebar is tilted from the straight position. Some General Tippanis. 1) Avoid riding in the rains as much as possible. If must, keep a cloth handy to wipe the helmet wisor every now and then. If riding in the night, carry an extra cloth to wipe the headlamps. A dirty headlamp can hamper the light throw drastically, and reduce your area of vision. 2) Always keep a first aid kit (basic kit includes cotton, band-aids, some surgical tape, antiseptic cream, and a swiss knife). You never know when it would come handy. 3) Golden rule. Always carry a basic tool kit as well. Again, you never know when it would come in handy. 4) Never fill the tank upto the brim. Always keep a little gap between the filler neck and fuel level. 5) A backpack/bag is a useful addition while touring, but not if you intend to apex the ghats. Shall add more as I remember...
__________________ DAD |
| | #38 (permalink) |
| BHPian | In our riding group we would use the SEE strategy its straight from the Busa riders forum. 1) Search for potential hazards - look as far as u can see better is if u r following a vehicle if possible try getting a look ahead of it. 2) Evaluate the situation, how are you going to handle it (speed up, slow down, wait for traffic to do its thing) 3) Execute, put it into motion The Search part 2 Second following distance (this is min. for ideal conditions - This figure will change very much for Indian road conditions). 4 Second Immediate path - couple of times I have cut from 1 - 2 - 3 and into breakdown lane to get back to 1st lane just did not want to slow down. This is bad and I am doing my best to get of this habit. 12 Second Anticipated path You should never follow closer than 2 seconds You should be able to respond to anything within 4 seconds from you You should be searching 12 seconds ahead at all times Always scan the road ahead, AND left and right for your immediate path incase of emergency. In India u will have to look at the shoulder room which can be very unstable.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN |
| | #41 (permalink) | |
| Team-BHP Moderator ![]() | Nice additions Veyron & 2fast. What you'll have stated is applicable for any sort of 2 wheeler, not just the big bikes. Quote:
At low speeds (upto about 15kmph), in order to turn the bike in the direction we want it to go, we turn the handlebar in that direction i.e. if we want to go right, we turn the bars to the right. However, as speeds gradually build up, you need to do the opposite to go in the direction you want. i.e. if you want to take that same right hand bend, you now turn the handlebar to the left. This causes your front wheel to lean to the right. Every single 2 wheeler rider does this whether he/she is aware of this or not. There is not other way to steer a bike around a corner at any reasonable speed. To demonstrate this effect, you can do a simple test. While stationary, turn the handlebar of your bike in one direction. The bike automatically leans in the opposite direction. That, in its simplest form is what counter steering is. Now start you bike and begin to ride at about 20-30kmph in an open area like a parking lot. Imagine that you have a right turn coming ahead. Consciously turn the handlebar to the right (as we assume that turning right will cause us to go right). Your bike will want to turn left. Now do it correctly. Image a left hand bend approaching. With you left palm, push on the left handle and pull with the right hand. Voila! while your handle bar is pointing ever so slightly to the right, the bike will lean to the left and guide you around the left hand bend. That's counter-steering for you. The sooner you understand this and consciously begin to notice this while riding, you will improve the way you tackle corners and also become a safer rider.
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ | |
| | #42 (permalink) |
| Senior - BHPian | Eh!! what was that RTech.. Now i am sooo confused.. Its been a while( more like 5 years) since i rode a bike.. and i have not understood the fact you have mentioned in the above post Godfather
__________________ I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer. |
| | #44 (permalink) |
| BHPian | Each curve is different and dont try to replicate the above at all the places.I believe most of them dont work here (our roads) . They could be gravel , cow dung , stone ,a bump ,2 cages coming towards you overtaking each other in a corner, a wet patch, and oil for worse, a broken truck with no lights standing in the corner ,some one going very slow ,some one crossing the road . All these can be avoided by experience. Also the comfort and handling of the bikes .Like a zma a light with the front end and easy to steer ,whereas a plusar is little heavy at the front and requires more stregth to pull it into a corner. Tyres have to great , a little wider tyres with more grip ,will a drop is mileage i can take. Go in for michelins for indian bikes .They stick like glue to road. You whole body + bike is one those 2 small contact patches from the tyres .Never be cheap on tyres . Also the riding gear is very import, a clear visor with good full face helmet.A drak sport glasses inside the helmet for cool riding effect. A riding jacket with adequate ventilatation ,mesh jacket in all the seasons along with outer rain liner. A textile jacket in case of cold to very cold areas (like himalayas) . A good water proof glove , keep pads , and ankle protecting shoes to go in for .Any thing not in order can be real pain .Extra care and protection is needed while riding in rain .Pheww biker life is complicated .
__________________ Do it your way ....... Last edited by black12rr : 9th July 2007 at 11:54. |
| | #45 (permalink) |
| Team-BHP Moderator ![]() | Don't try and replicate what 12rr? Everything mentioned here are the basics, regardless of where you are riding. A better understanding of how your bike responds to the inputs put in by the rider will only serve to make you a safer rider.
| Thread Tools | |
Similar Threads | ||||
| ARTICLE: How to buy a *USED* Car in India | adya33 | On buying a car | 42 | 8th April 2008 04:45 |
| ARTICLE: How to buy a *NEW* car in India | GTO | On buying a car | 22 | 14th December 2007 22:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
