Old 3rd June 2011, 14:50   #1
theragingbull's Avatar
Thanked: 612 Times
Default Help: Weird phenomena on my touchscreen!
I have a HTC Tatto that is more than a year old. Since the past 5 days, I am noticing a strange problem on my touchscreen. What you seen in the pictures below aren't scratches. Something is happening inside the screen and the thing is gradually getting bigger and bigger everyday.
On Day 1 it was a small thing but on the second day it looked like this.
Help: Weird phenomena on my touchscreen!-p1010601.jpg
Then Day 3
Help: Weird phenomena on my touchscreen!-p1010602.jpg
Day 4
Help: Weird phenomena on my touchscreen!-p1010603.jpg
Day 5
Help: Weird phenomena on my touchscreen!-p1010604.jpg
Does anyone have an idea what's wrong with the screen? The touch sensitivity is also not as good as before.
theragingbull is offline   Reply With Quote
Old 3rd June 2011, 14:54   #2
slicvic's Avatar
Thanked: 363 Times
Default Re: Help: Weird phenomena on my touchscreen!
I see that you have a scratch guard. Can it be moisture under it? Try removing the same.
slicvic is offline   Reply With Quote
Old 3rd June 2011, 14:57   #3
Thanked: 612 Times
Yes the scratch guard is there. But I had removed it for some time and still the problem persisted.
Old 3rd June 2011, 15:01   #4
mayankk's Avatar
Thanked: 3,507 Times
remove the scratchguard and clean the screen?
to see if its below/under the screen?
if not, get a new scratch guard maybe?
look like moisture.
maybe you had some invisible indents on the adhesive.
mumbai, yes?
it has just started raining over there, hasnt it?
could be.
mayankk is online now   Reply With Quote
Old 3rd June 2011, 15:07   #5
ghodlur's Avatar
Thanked: 2,203 Times
Smile Re: Help: Weird phenomena on my touchscreen!
Had you dropped the phone by any chance? If its not the moisture then definitley some issue with the display. You need to get it checked at the dealer or the service centre.
ghodlur is offline   Reply With Quote
Old 3rd June 2011, 15:32   #6
vikram_d's Avatar
Thanked: 937 Times
Looks like moisture inside the LCD layers. Does it go off if you remove the battery? If yes, then it is an issue with the LCD screen itself.
Old 3rd June 2011, 15:45   #7
srishiva's Avatar
Thanked: 837 Times
if its inside the LCD, it could be physical damage to the screen. I have had my laptop screen get bad like this. Did you press something against the screen?
srishiva is offline   Reply With Quote
Old 3rd June 2011, 17:31   #8
Thanked: 612 Times
No it doesn't look like moisture cuz I have removed the scratch guard and cleaned the screen too. It's something under the screen. Haven't dropped the phone in the past few days but has fallen down couple of times before. The phone is not even in warranty period right now. Still I'll check with the dealer or any phone repair shop.
Old 3rd June 2011, 18:02   #9
vikram_d's Avatar
Thanked: 937 Times
It may not be moisture between the scratch guard and the LCD screen. It may be moisture between the different layers of LCD itself. A LCD screen is normally made of 4 - 5 different layers all stuck together. But the way it seems to be spreading it may also be the the LCD layers are separating. This is highly unlikely but is possible.
Old 3rd June 2011, 20:42   #10
Thanked: 20 Times
It looks like adhesive from the pics posted. My guess is that the touchscreen layer is unbinding from lcd layer, but its just a guess.
edit: probably you could describe how the screen works when phone is switched on. Are colors visible? are they faded/off the scale? Is touchscreen working in the affected region? etc..
Comrade is offline   Reply With Quote
Old 3rd June 2011, 20:47   #11
Thanked: 612 Times
Thanks for the inputs guys!
When the screen is ON, all colors are clearly visible.
Old 3rd June 2011, 21:28   #12
Akshay1234's Avatar
Thanked: 6,727 Times
Has to be moisture. It just started raining here over the past few days. Thats probably why its started spreading.
Old 4th June 2011, 14:15   #13
Thanked: 612 Times
If it's moisture then what should be done to get rid of it?
Old 5th June 2011, 02:28   #14
ghpk's Avatar
Thanked: 192 Times
If you have Hair Dryer, use it carefully on low heat and attempt to dry it up.
If you are sure, screen is not acting up, it may be some external moisture only, Had it been LCD Leak, you would started having issues with display, as you say screen is fine, you can dry some of moisture using a hair dryer.
Edit: Just read your touchscreen is no longer sensitive, it can be the touch screen layer, which is loosing its hold from the screen and the moisture leak in-between the screen and touch panel is what you see,
please take it to HTC Service center before attempting the hair dryer solution.
Atleast they can give you a quote for free.
Old 5th June 2011, 14:01   #15
rajismine's Avatar
Thanked: 252 Times
the LCD has two layers with a liquid between them....Moisture passed in between these layers and they have got saperated....
The touchscreen should stop respondin on this area now and then
There is no solution except replacing the screen that may cost you Rs 500-750 i guess outside and about Rs 1500-2000 with HTC Service centre. HTC considers it a physical damage and wont replace in warranty unless you give them a good fight and escalate it
Its the most common thing with any HTC mobile
Rajeev
rajismine is offline   Reply With Quote
Adding an indash TFT TouchScreen in palio rishibravo Modifications & Accessories 23 25th March 2010 21:33
Touchscreen options for Carputer COUGAR In-Car Entertainment 11 25th March 2010 21:13
Indigo Center Console Touchscreen LCD Fabrication shldn In-Car Entertainment 95 13th August 2009 12:47
Urgent Need of 7 Inch Touchscreen sinner Gadgets, Computers & Software 1 15th May 2008 18:32
My experience with a Hutch touchscreen kiosk Sam Kapasi Shifting gears 10 29th June 2006 18:20
