| LinkBack | Thread Tools | Search this Thread |
| | #31 |
| BHPian Join Date: Apr 2008 Location: Bangalore
| As far as i know, it is BSNL. If you take the unlimited download for Rs.750 per month @ 512kbps; it is actually unlimited. There is no fair usage clause; which in my opinion is an unfair clause when the service provider says it is an unlimited plan |
| | #32 | |
| BHPian Join Date: Sep 2008 Location: Hyderabad
Thanked: 15 Times
| Quote:
But of all the customer cares that I experienced, Reliance should be the worst among the the private players. The issue was regarding cancellation of connection in the name of my sister, which was not done but the bills were generated. Every time I called some new executive would answer me and said that they don't have records of previous calls as they didn't record calls!!!. They would say that they would take up the matter afresh. And the worst was they didn't even issue a complaint number. So I had to go through the process every time. Fed up with this I recorded my call to the customer care once, when I insisted on specking to their regional head, and they accepted that it was their fault and would resolve the matter. Of course they didn't know that I recorded the call. You know what after all this they had the audacity to send a legal notice claiming payment of dues. I promptly sent a reply stating that I had recorded conversations where they had accepted that it was their fault. I was to slap a case of defamation but had to move to Mumbai for Job and didn't pursue the matter. Of late I heard that Beam tele is giving wonderful packages and the service is also very good. For around Rs. 1000 hey are giving 10mbps speeds with 30 gb limit after which the speed is reduced. Though I am not sure of this, one of my friends said that even after crossing the limit the speed is reduced to 1mbps or 2 mbps, which is very good. | |
| | #33 | ||
| BHPian | Quote:
This was with reference to sgiitk's post & some other posts that give a very vague explanation for hating airtel. I multi-quoted that posts but, it didn't appear in my original post. Though my broadband experience was intended to be read by you also. Quote:
BTW, which tariff plan are you currently using? | ||
| | #34 |
| BHPian Join Date: Jul 2009 Location: Good-Gaon
Thanked: 186 Times
| Oblate Airtel landline and broadband department has been acting like a PSU. The worst thing they have done is to hire incapable call centers. The quality has deteriorate considerably. Pity we do not have good options. Where people in other countries take 25mbps and higher speeds to be normal we are stuck at expensive low end deals. |
| | #35 |
| Senior - BHPian | ^^Yes, Airtel have been behaving like a languid PSU when they are anything but. Customer service used to be the group USP at one time. They managed to build a power brand with a customer-centric approach, but now they are just a massive marketing company that outsources most of its key functions. The IT side of things is completely handled by IBM, while the tower installation, contact centres and service personnel are also handled by third party vendor/contractors. One wonders if this method of operation has diluted some of their core brand values. |
| | #36 |
| Team-BHP Support ![]() | Finally the issue is sorted. Quota problem is gone now, and I am back to normal speeds! |
| | #37 | ||
Thanked: 186 Times
| Quote:
I would like to inform the uninitiated that Airtel changes it's plan quite often but will not tell it's loyal customers. I was paying higher than the normal for 1mbps 135 channel iptv that had cap at 15gb. The latest plan saves me 100+ bucks with 139 channels and 2mbps speed at cap of 10gb. But 14 July request still is pending meaning I continue to have slower speed and less channels for 15 days. Pathetic. If you speak to the guys at customer care they just give you a number and say the systems are down and that we should wait for two hours. What happened to the customer is king send I will make a note while the server is down and feeb in the entry? Quote:
| | #38 |
| BHPian Join Date: Nov 2009 Location: Bangalore
Thanked: 68 Times
Infractions: 0/1 (5) | I am using BSNL for the last 1.5 years in Bangalore. Speed and reliability is good. They also try to resolve issues, if any, as soon as possible, and follow up with calls to ensure everything is working. Server problems are rare. For that matter, I also did not have any problem with Airtel when I was using it in Kolkata, and I think it is one of the best broadband connections available in terms of reliability. |
| | #39 |
| Distinguished - BHPian ![]() | |
| | #40 |
| Senior - BHPian Join Date: Feb 2010 Location: Bangalore
Thanked: 348 Times
| I will chip in with data for TataIndicom Broadband. I have been using it since last two years. Its a 256 KBPS connection with 2 MBPS connection between 10 in night to 8 in morning. Rs 1213 per month. The fair usage policy is here also. Its 45 GB per month. I have received calls from them few times that I am nearing the quota limits and I can expect a downgrade in speeds when I exceed it. Point is that they kept me informed. |
| | #41 |
Thanked: 68 Times
Infractions: 0/1 (5) | I have been using Tata Indicom wimax connection. The downtime is on the higher side, as in 1.5 months they had downtime thrice. Finally I disconnected the connection. |
| | #42 |
| Senior - BHPian Join Date: Jul 2007 Location: Ask me, no?
Thanked: 701 Times
| I figured the issue. Their billing systems had planned downtime from 9-19 july (or so an email said, which i promptly deleted!!) - consequently, they have not even raised my June bill so far. Prolly something like that was what caused instability in your case. A misconfigured billing system |
| | #43 | ||
| Team-BHP Support ![]() | Quote:
I use a 1499 plan which has 512kbps speed instead of 1099/1199 plans which have 2mbps speed. This is an old plan, and should not have quote(or 25GB quote). But due to some error or something, there has been an error. Moreover, I cannot switch to the 1199 plans, as in Airtel, you can upgrade, but never downgrade, but as long as there is no quota I am happy! thanks for your support doc Quote:
| | #44 | |
| Senior - BHPian Join Date: Dec 2006 Location: Bangalore
Thanked: 271 Times
| Quote:
Talk to them about it! | |
| | #45 | ||
Thanked: 186 Times
| Quote:
Just for the sake of information for fellow members I can tell you that IPTV sucks at Airtel. Mum just likes the time shift else would have switched a long time back. If you have a heavy download the modem gets overwhelmed with LEDs going berserk and IpTv reception gets effected. Therefore no 4mbps connection with IPTV the ports are locked. The channel flip is terribly slow and you can not hide the channels you do not want to see. No mechanism. The advertised interactive tv does not change it's dynamic content. Thus your daily horoscope which my mother would rather see, is 1 year old the radio on interactive tv never sings, the movies if you hire them are not in HD. I was the first one to get IPTV ( had a good run with it in Denmark) but in our land with zero accountibiltiy it is a curse. | ||
Similar Threads | ||||
| Experience with Airtel Broadband Customer Care | Nikhilb2008 | Gadgets, Computers & Software | 53 | 11th January 2013 11:25 |
| Airtel 3G Billing Fraud | Samurai | Gadgets, Computers & Software | 126 | 19th May 2012 10:37 |
| Airtel Broadband Query | bharanidharang | Gadgets, Computers & Software | 2 | 18th February 2009 09:20 |
| Airtel broadband and my macbook pro | CaliAtenza | Gadgets, Computers & Software | 17 | 6th February 2009 00:02 |
