| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() | The problem i have is - When i want to transfer files from my pc (running XP ) to my Nokia 7610 via bluetooth - it fails - error says "The file transfer failed because the receiving Bluetooth computer or device did not respond. If you sent the file to another Windows XP computer, that computer must be running the Bluetooth File Transfer Wizard. If you sent the file to a Bluetooth device, make sure the OBEX File Push Profile is installed." I did not face this problem earlier - now suddenly for the past month I am facing this and the surprising thing is - when i transfer from the phone to the PC it works beautiful. Inbetween had transferred files to my friends SE K700 too. Has something gone wrong there ? I have removed and reinstalled the drivers of the bluetooth dongle but nothing seems to work. what could the problem be ? Also any solutions ? Thanks |
| | #2 (permalink) | |
| Senior - BHPian | Quote:
there can be two problems. First one of the bluetooth devices is hidden. Second you are not inputing the pass code in one of the devices. Secondly. remove any skins or mask software you are using. I had this trouble. With the alienware Guise on my bluetooth didnt work. It only worked under standard winxp environment.
__________________ boyracer.blogspot.com | |
| | #3 (permalink) | ||
| Team-BHP Moderator ![]() | Quote:
| | #6 (permalink) |
| BHPian Join Date: Sep 2005 Location: Earth
| normally_crazy If u're running on window Xp Service pack 2 then i recommend u to reinstalled the Software that came with Dongle & unplug your Dongle after that restart it then connect your dongle (Try on other usb port if possible)& sp2 will install it automatically ! |
| | #7 (permalink) | |
| Newbie Join Date: Jan 2005 Location: Kolkata
| Quote:
Few things that you can/should consider: 1. I'd assume you have XP SP2 installed. If so you better stick to the MS generic BT driver. 2. If you are using BT dongle just for file xfer or sync, it's better not to install the BT driver that comes with the dongle. The default MS driver should be good enough for use with Nokia PC Suite. Few 3rd party drivers (in most cases Widcomm or Bluesoleil hacks) ruins up the BT virtual port registry. 3. The old Nokia PC suite software (the one in 7610 CD belongs to this) had quite a few issues with XP SP2 (particularly mRouter component). You can try moving up to new PC Suite (v6.7 I think). 4. Did you install any SE software to xfer file to K700? If yes, that might be a suspect (it won't messup the BT driver, but would leave the mRouter confused). Else K700 has nothing to do with this. Bottomline, I see two suspects here (a) 3rd party BT driver or (b) broken mRouter (part of PC suite) in that order. Cheers, Indrajit | |
| | #8 (permalink) |
| Senior - BHPian | ok lets try it step by step. Turn on bluetooth on both the devices. working???? Yes/No COnnect both the devices and give passkeys on both. Woking??? yes/no Select the file you need to send to phone. Right click send bluetooth. select the device. working??? Yes/No Get into the device so that you should be able to browse files on your phone on the computer. WOrking???? Yes/NO Paste the file straight away. Working???? yes/No. THis is the simplest and sure shot way of transferring files. If this doesnt work. Lemme know I will letcha know a different way of transferring files.
| | #9 (permalink) |
| Newbie Join Date: Jun 2005 Location: Pune
| I had a similar problem with Bluetooth. The the whole thing didn't work for me with Windows Bluetooth driver. (HP nw8000, Windows XP with Nokia PC Suite and Nokia 6650) Use the WIDCOMM driver and everything was fine. - mvnk |
| | #11 (permalink) |
| BHPian Join Date: Jun 2004 Location: Chennai
| Need a help! I have O2 XDA mini. when I try to send files from O2 to PC thru Bluetooth works fine. But when I send files from PC to O2 thru bluetooth. I get a messsage saying that file has been transfered. I do not know where it writes. Tried thru search facility also. Is there any default file name or folder in O2? Can we set a default file/folder name? |
| | #13 (permalink) | |
Also try updating the phone firmware to the latest release.
__________________ I have often regretted my speech, never my silence. | |
| | #15 (permalink) |
| BHPian | Well sometimes, when I transfer to the N73 and it goes into standby mode it disconnects from the Pc while transfer...it was irritating until i finally realized it lost connection on standby for some reason...dunno whats you problem though
__________________ "Aerodynamics is for those who cannot manufacture good engines" - Enzo Ferrari |
| Thread Tools | |
Similar Threads | ||||
| Loan transfer | rahul_intlad | Indian Car Loans & Insurance | 7 | 11th July 2007 15:01 |
| Bluetooth Connectivity possible - iPod / HU / Mobile Phone | normally_crazy | Gadgets, Computers & Software | 15 | 2nd November 2006 10:22 |
| Transfer charges : KA to MH ? | Dippy | Shifting gears | 1 | 25th June 2005 11:16 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
