Old 21st September 2011, 11:14   #1
vu2pmc's Avatar
Thanked: 32 Times
Default Convert Google Maps driving directions to GPS tracks
I read quite a few posts which said google maps driving directions cant be converted to gps tracks/ gpx file format.
This is factually incorrect and there is indeed a way.
GMapToGPX Communications From Elsewhere
This is the webpage of a java script, and the method is self explanatory.
I have used this a few times and works almost always. ( at times, when google maps changes its coding structure, the script might not work.. in which case, visit the page and refresh your script)
This indeed is a brillaint tool.
Another tool that can be used it a program called TYRE.
Tyre
the link above will take you to the website.
While the first tool even accept modified google route, the second one might not let you modify the route by dragging on google map.
Cheers.
vu2pmc
vu2pmc is offline   Reply With Quote
Old 21st September 2011, 13:29   #2
tsk1979's Avatar
Thanked: 16,459 Times
Default Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
All you have to do is simply click on the "link" button after creating the route, and add &output=kml
For example Mumbai to BLR gives me this link
Mumbai, Maharashtra, India to Bengaluru, Karnataka, India - Google Maps
All I have to do is change it to
http://maps.google.com/maps?saddr=Mu...z=7&output=kml
KML files can be easily converted to gpx and then imported into many GPS software.
Old 21st September 2011, 13:32   #3
Thanked: 56 Times
Default Re: Covert Google Maps driving directions to GPS tracks
I have been using this GMAPToGPX and it works very well. Just remember to use the option "Full" to get all the points though.
alto99 is offline   Reply With Quote
Old 24th September 2011, 20:18   #4
Thanked: 172 Times
Default Re: Convert Google Maps driving directions to GPS tracks
Alternatively one can use mapmyride.com.
One can create / share / save routes there (just like Google) and also export them directly to gpx file.
I have used it for a few years till now and am satisfied with it.
I particularly like the ability to create routes manually for remote regions where map data is not available by referring to satellite view. (I am not sure whether one can do that with Google maps. Haven't tried.)
mayuresh is offline   Reply With Quote
Old 25th September 2011, 11:02   #5
Thanked: 56 Times
You can do it using Google map maker google.com/mapmaker.
Added/edited roads, if approved, are published almost instantaneously but the routing algo takes a bit of time to consider newly added roads.
Old 25th September 2011, 11:39   #6
Thanked: 172 Times
That seems like a workflow to make legitimate addition to maps.
Instead, one might want to just draw a track. There need not be a proper road there and I need not submit it to anybody's approval though still be able to draw/save/share it etc. Perhaps you can do that with Google. However, UI wise, for drawing custom-route, mapmyride seems far easier to me.
When map data exists, Google UI is a bit easier in choosing from alternative routes etc. But again saving gpx is easier in mapmyride.
Data Bank Of Tracks Across India (Go karting tracks included) dustDevil Indian Motorsport 70 10th April 2017 19:31
Google India added Driving Directions feature with facility to print detailed maps samdarshi.pali Route / Travel Queries 13 25th May 2009 21:12
Using Google & Yahoo India Maps on standalone GPS Device Haste Gadgets, Computers & Software 9 30th September 2008 19:59
Google maps mobile 2.0 - poor man's GPS tachobells Gadgets, Computers & Software 4 1st December 2007 11:19
Driving directions for India - Maps & Driving Directions informmaha Route / Travel Queries 1 15th October 2007 17:02
