Old 6th February 2013, 13:13   #16
Rehaan's Avatar
Thanked: 25,069 Times
Default Re: Home automation Thread
Interesting stuff guys...
Originally Posted by anekho View Post
Very cool indeed.
Originally Posted by bullock-Car View Post
Among the conventional system, typically require all wires to centralised distribution wires or in HAI systems from switchbox a cat 5 cable to controller.
Yeah! This is the biggest pain for people who aren't starting off with a new house!
Luckily for me i think i will be able to pull a set of relay control wires (am using a cat5 cable) from my main switchbox to another location where the arduino controller will be.
Though I consider this year will be an watershed with ZIgbee and zwave devices and low cost controllers making headlines
i.e http://www.kickstarter.com/projects/...art-home/posts
Wow... for $99 that is a cool one!
Finally I am thinking i will go for conventional electrical wiring and provide for some extra space for these modules,may be after 1 year, to integrate lighting with Control from phone.
Definitely a good idea.
cya
R
Old 6th February 2013, 13:47   #17
dgupta's Avatar
Thanked: 65 Times
cya
R
Rehaan, did you consider the Raspberry Pi instead of Arduino ? From what I read in general on the net, RPi has a cost advantage over Arduino, of course depending on the exact project objective and hardware requirement.
I just got hold of a RPi board over the weekend and I was thinking of embarking on a home automation project. Don't know much about it as of now, still in the research phase. Here are a few links I found.
http://www.instructables.com/id/Rasp...6/Install-App/
http://www.recantha.co.uk/blog/?p=1517
dgupta is offline   Reply With Quote
Old 6th February 2013, 19:10   #18
Sprucegoose's Avatar
Thanked: 40 Times
Guys,
Won't the simplest way be to use a powerline to ethernet adapter to control an ethernet controlled relay?
Powerline to Ethernet Adapter:
http://www.newegg.com/Powerline-Netw...ategory/ID-294
Ethernet Controlled Relay:
http://www.robot-electronics.co.uk/a...y_Modules.html
That way:
1> Where ever you have electrical wiring you automatically have the control wiring as well
2> If each relay module can be communicated with individually then just plonk in both of these into a switchboard, wire it up and your hardware will be ready to use.
Sprucegoose is offline   Reply With Quote
Old 15th February 2013, 10:03   #19
Thanked: 397 Times
nice thread , just came across this website, its a Bangalore based company .
http://www.silvanlabs.com/
How far are these things effective ? Is it affordable ?
girimajiananth is offline   Reply With Quote
Old 3rd July 2013, 00:41   #20
Rosso Corsa's Avatar
Thanked: 509 Times
Anyone tried getting a Raspberry Pi shipped directly to India? Any hassles?
Rosso Corsa is offline   Reply With Quote
Old 3rd July 2013, 01:36   #21
Thanked: 112 Times
Try this site? http://www.crazypi.com/index.php?rou...&product_id=57 Prices are quoted in INR & looks promising.
PS: I am not associated with them. came across this link in another forum earlier today.
null is offline   Reply With Quote
Old 3rd July 2013, 15:53   #22
Rehaan's Avatar
Sorry just saw your post!
I did NOT consider the Raspberry Pi, simply because i didn't think i needed the additional advantages it provides, i'm familiar with arduino, and i have no idea about programming a R-Pi (and didn't want to spend more time learning instead of executing the project).
Check out these SOLID STATE relay boards. I bought the 4-ch one. Its working well.
Amazon link (see the reviews etc here)
Buy from here, they ship to India: Sainsmart Site
Perhaps, though i've never tried one of these. There might be other problems with it : range? interference?
Forget getting it shipped from aboard. Why don't you buy from here:
http://www.rhydolabz.com/index.php?m...oducts_id=1217
cya
R
Old 17th February 2014, 12:04   #23
clevermax's Avatar
Thanked: 445 Times
Very informative thread.
I recently started looking into Home Automation. I plan to utilize my existing home media network eco-system, which consists of a WD MyCloud, which is nothing but a low power consuming Debian Linux with a massive hard drive.
Bit of a background, I am currently using MyCloud as the media store, torrent client, cloud storage for backing up my data from phone, PC etc. Since TV is also connected to home network, I can play movies directly from WD MyCloud using DLNA.
Have perl scripts which already automates everything from searching and adding proper subtitles, merge subs and movie into a new mp4 media file to make it ready to play in TV. (Thanks to bhpian nkg77 for the scripts)
Learned about X10 switches from several home automation sites in the internet. I have one question about them - are they compatible with 230V distribution system in our land? Anyone successfully using such switches to automate appliances or lights here?
I wish to interface them with this low-power Linux PC, and then figure out how to control them remotely. WD MyCloud consumes 4W when HDD is not spinning. It goes upto 8-9W when HDD spins. I can expect 15-19 hrs of sleep time (4W) per day.
clevermax is offline   Reply With Quote
Old 17th February 2014, 13:45   #24
::CMS::'s Avatar
Thanked: 470 Times
I would prefer cheap USB-Relay boards in host mode instead of aurdino (if the sensor/relay status is not required). Create a custom app in android to send commands.
::CMS:: is offline   Reply With Quote
Old 19th February 2014, 19:44   #25
shashi63's Avatar
Thanked: 240 Times
I'd just run CAT5 / ethernet cables all over the place. To every point you need a camera, switchboard, or any other control. This will do the trick for DIY stuff, but i don't know how well it will integrate with other solutions.
Also, leave a lot of room around the switchboxes for controllers, but once again i'm just talking about what i wish i had done in my room so i could get on with my DIY project
cya
R
Number of solutions.. one of the best if fro, Schneider - www.mysehome.com and another company which provides an advanced solution is crestron - www.crestron.com.
The C Bus concept is a Schneider speciality!
Plus ofcourse a company called Leviton.
Last edited by Rehaan : 4th March 2014 at 16:18. Reason: Merging consecutive posts. Thanks for the links, will check em out.
shashi63 is offline   Reply With Quote
Old 23rd February 2014, 12:39   #26
Thanked: 509 Times
Planning to get a ceiling fan remote control kit. Could not find anything about products catering to the Indian market. Has anyone tried this before ? How is the pricing/availability ?
Old 23rd February 2014, 12:56   #27
Akshay1234's Avatar
Thanked: 7,286 Times
Check the Crabtree site for this. I am using Crabtree I-sense which is basically remote control lights and fans all over the house since about 3 years. Works perfectly and is really convenient for lazy people like me.
Old 25th March 2015, 18:02   #28
abhi182's Avatar
Thanked: 205 Times
Default DIY: Home Automation
Some of you old timers may remember me as the guy who had setup a full fledged PC in his Corsa for Music/Nav etc back in the era when uttering the word Tablet would lead to a question on what your ailment is
Of course, that whole project is a pointless one now but it had been a while since I had done something substantial DIY-wise..
This time , I diverted the attention of my drill bits and wiring harnesses to my home (much to the chagrin of the lady of the house). Eventually though, she likes what it resulted in :
This was done for rather cheap using off the shelf components and supports any business logic combination you want to use - some examples I
- Send me an alert with Pics if there is motion in Porch but only if its a weekday and time is between 10AM to 7PM
- Switch living room lights 10 mins before sunset with a warm hue if temperature <24C or cool hue if temp >28C
- Dim living room lights to pale blue if a movie is switched on the media center, brighten if paused or stopped
abhi182 is offline   Reply With Quote
Old 25th March 2015, 18:14   #29
knp
Thanked: 18 Times
Default re: DIY: Home Automation
Interesting work and I believe, it's the right time we talk about home automation.
I'm thinking to do the same and would you please share more details on the hardware, etc?
knp is offline   Reply With Quote
Old 25th March 2015, 18:42   #30
abhi182's Avatar
Thanked: 205 Times
Here you go - Attaching scrshot as text formatting is getting messed up
DIY: Home Automation abhi182 Gadgets, Computers & Software 29 26th July 2018 14:53
Building a truck camper : Home away from home DKG Modifications & Accessories 141 14th June 2018 15:24
Automation: Game of designing & building cars vivtho Gadgets, Computers & Software 3 4th June 2016 18:30
Automation: Game of Designing & Building Cars adrian Gadgets, Computers & Software 0 19th February 2014 14:21
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
