Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Closed Thread
Thread Tools
Old 13th March 2006, 15:22   #16 (permalink)
BuRnT RuBbEr's Avatar
there is one issue with sony that nobody has pointed out as yet. the images are tad over-processed. esp the red regions of the gamut are sharpened a bit more than needed. may need to photoshop and decrease that. And it does not have a zeiss lens, reason being it' large lens size ( zeiss generally provides smaller lenses.) otherwise, h1 is above canon s2 IS in most of the reviews. It also has a viewfinder ( i am not sure if canon has it). You can also look for sony m2 if you are more about compactness.
[SIZE=2][/SIZE]
[SIZE=2]I would not suggest cams that have just arrived, because they generally undergo firmware updates and flaw removal. I myself have an canon digital rebel, but that would be more than twice your budget....[/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]hope that helps.[/SIZE]
__________________
in the world of tarmac, thou shalt be remembered for the rubber you burn, the motors you smoke and quarter miles you conquer...
BuRnT RuBbEr is offline
Old 13th March 2006, 15:42   #17 (permalink)
Gordon's Avatar
Another important issue in SD cards. The trasnfer rate is way too slow. Memory Sticks are known for FAST transfers, which is exactly why they can take high quality videos. Moreover, when I tried deleting all pics from a 256mb SD card in a Panasonic, it takes AGES!!! But in Memory Sticks (even the 512 MB), is done in a flash.
__________________
Team-BHP.com > Motorbikes > Yamaha Cafe Racer
Gordon is offline
Old 13th March 2006, 15:56   #18 (permalink)
hey! thanx...was not aware about this issue in SD. using memory stick anyhow.
__________________
Old 13th March 2006, 15:58   #19 (permalink)
ksethuram's Avatar
Originally Posted by dhirajs
Guys,which 1gb sd card should i buy?kingston or someother?for howmuch?
I like the DSC-N1 also,its damn sleek ,& has a 3.0"LCD.
My suggestion would be go for miniSD and use with SD adaptor. This will give you the advantage to use the same in latest mobiles to store MP3's.. Sandisk or Lexar would be a good choice. Go for High speed card. Also do not get a single 1GB, split into two 512's...This would help you in case of failures.
ksethuram is offline
Old 13th March 2006, 16:10   #20 (permalink)
ksethuram's Avatar
Hope the SD you had was a normal one. There are high speed SD's like Extreme III from Sandisk which has 20MBPS R/W speed..
Only external size of xD,SD,MMC mobile Card and Memory stick pro cards are different but more or less all of them share the same internal flash storage.
Old 13th March 2006, 16:31   #21 (permalink)
ksethuram's Avatar
My preference would be
Point and shoot
1) Canon
2) Nikon
3) Sony
SLR
1) Nikon
2) Canon
3) Kodak
Pro-SLR
1) Canon
2) Nikon
3) Kodak
Old 13th March 2006, 17:09   #22 (permalink)
SRK
SRK's Avatar
I've got a Canon A620. It is nice I got it for somewhere around Rs.23000(with 512MB sd memory card).Though it is a little bulky, it has some features available in SLR cameras.It works on 4 AA size battries and can take about 150-200 photos.It can be directly connected to your tv to view the pics.
It has 4X optical zoom.7.1 megapixel,enough for taking high quality pics by a novice (like me).The Auto functions rocks,you can even take pictures in a dark room, due to its flash.
It can also take small video clips with sound but of low resolution and can be viewed only in small size.
There are many other brands like Sony,Kodak,Nikon,Panasonic,etc.
Out of them Sony should not be the 1st preference because Sd cards cant be used in it, and i think it is a little expensive.
Better go for Canon or Kodak.
__________________
TEAMBHPIAN!!
I am Always Busy!!
SRK is offline
Old 13th March 2006, 19:00   #23 (permalink)
extreme_torque's Avatar
True for video recordings high speed SD cards are needed and those are available easily.
The fringing problem is a big draw back and the fact that sony dsc h1 doesnt has carl zeiss optics. Panasonic FZ 20 is a perfect high optical zoom camera if u arent into high megapixel resolution... even for that FZ 30 is there.
Panasonic has the fastest auto focus in its catagory.... all this talk of sony having a 2 inch LCD is rubbish coz bigger the LCD, lesser is the battery life, besides the LCD in Panasonic is bright and crisp. Even the image stabilization which is the one of the most important criteria in a high optical zoom camera, is the best on panasonic and fastest too.
extreme_torque is offline
Old 13th March 2006, 23:07   #24 (permalink)
There are too many options in 20k slot. one esp needs to decide on the form factor of the cam first!
panasonic wont appeal the ladies of the house. Nor will fuji. ( fuji is good for low end basic stuff....where there arent any much expectations).
The screen size can become an issue when we are using the menus. too small may not get approved with everyone.
__________________
Old 14th March 2006, 07:51   #25 (permalink)
Gordon's Avatar
Why go in for the H1 when the H2 is already out?! And it does have a Carl Zeiss lens with 12x Optical Zoom. I guess from the past one year, Sony has been adopting Carl Zeiss lens on all its new models.
__________________
Gordon is offline
Old 14th March 2006, 12:05   #26 (permalink)
Rehaan's Avatar
Might have just been a slow SD card reader in that panasonic yknow?
And with regards to purple fringing, the S3 IS might have helped that with some UD lens element(s) ?
cya
R
Rehaan is offline
Old 14th March 2006, 12:45   #27 (permalink)
H2 would be way above 20k's!
Old 14th March 2006, 19:54   #28 (permalink)
s0uljah's Avatar
I owned a few Digi's, canon, kodak, olympus and fuji.
Fav's : canon/ olympus.
Will be buying something shortly 5.1... if budget permits maybe even a 7.1
Dad's travelling through asia next month.
__________________
"I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson
s0uljah is offline
Old 14th March 2006, 21:04   #29 (permalink)
Just Bought Canon A530 for Rs15,500/- from Canon shop in Delhi at
S.N market.
It Includes
1. 256mb kingston SD.
2. Camera Support MMC and SD
3. Carry Case
4. Battery charger Uniross(with 6 battery of 2300 mah).
How is this??
THELUCKY is offline
Old 14th March 2006, 21:40   #30 (permalink)
Gordon's Avatar
Yup, it maybe a little more than 20k. Because Sony.Com says it costs $399 which is a little less than 20k.
3. Carry Case
How is this??
How much warranty?!
Sony offers 3 year warranty on its digital cameras. I think it offers it on all other products too. I'm not sure about the others. I think they offer only a one year warranty. Also, always buy any digital camera from a recommended dealer. Because other dealers who give it to you for cheap, will give warranty of only three months. If anything goes wrong with the camera, it may cost you more than the camera itself.
__________________
Gordon is offline
Closed Thread
Thread Tools
The Digital Camera Thread: Questions, discussions, etc. satish_appasani Gadgets, Computers & Software 2872 8th October 2008 01:40
New Digital camera v1p3r Gadgets, Computers & Software 117 3rd September 2006 13:22
Needed Suggestions On A Good 4 Channel Amp between 40,000-45,000 Rs Tool Ask the Gurus 19 7th June 2006 12:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
