| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| Thread Tools |
| | #1891 (permalink) | |
| Newbie Join Date: Jan 2009 Location: NOIDA
| CA and distortion in a lens is not just dependent on the size of the lens alone. A lot is also contributed by the lens design, arrangement and grouping of various elements and the glass composition. All other things being equal, if you scale down the design of a particular lens of a dSLR to the smaller sensor size of a P&S, both the lenses will exhibit similar CA and distortion characteristics. However, since you cannot fully follow the design principles of a dSLR lens in P&S due to design constraints of a compact form factor, a few compromises have to be made. Quote:
| | #1892 (permalink) |
| Team-BHP Support ![]() | Yes, what I mean to say is that if you take camera A, shoot a scene at 1/X shutter speed 1/Y aperture and Z ISO, and then do the same with a different camera with the same settings, you will get a similar histogram.
__________________ Reclaimed, wrung dry and recycled....! |
| | #1893 (permalink) | ||
| BHPian Join Date: Sep 2006 Location: Bangalore
| Quote:
![]() Quote:
Don't change it, my post was just to pull your leg. Sorry.Money matters, can't spend too much money on buying all those high end stuffs. BTW, most of the time sensor gathers dust while changing lenses, and at that moment no weather sealing will help I guess.
__________________ If there is a Wheel, there is a way.. If there is a way then it's the Highway.. | ||
| | #1894 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ Samurai The only Super Car in my book -Bowler Wild Cat | |
| | #1895 (permalink) |
| But SSWF is also a method of shaking off the dust from the sensor. So it's not preventing the dust to go inside the camera, right? In that sense many other Cameras have sensor cleaning system these days. If one is very careful while changing lenses than that itself is a good(probably the only) dust prevention mechanism.
| | #1896 (permalink) |
| BHPian Join Date: Jul 2006 Location: Chennai
| Guys I have a noob question: Keeping the ISO constant, a large aperture (small F value) with a fast shutter speed and a small aperture with a slow shutter speed produces similar results. I know it has changes bokeh, depth of view. But my question is how does one decide what to use? (Small F, fast shutter speed OR large F slow shutter speed)
__________________ Proxima 2009 Ikon TCDi 2008 Pulsar 180 |
| | #1897 (permalink) |
| BHPian Join Date: Dec 2008 Location: Delhi
| Reality check buddy! Its around 67 - 68K with 18 - 135 and that too with proper bill and warranty.
__________________ Vespa Select 1994 Royal Enfield Electra 5S 2008 Hyundai Accent GVS 2003 Hyundai Accent GLE 2005 Mahindra Scorpio LX 2007 |
| | #1898 (permalink) | ||
| Team-BHP Support ![]() | Quote: Quote:
__________________ Samurai The only Super Car in my book -Bowler Wild Cat | ||
| | #1899 (permalink) | |
| Newbie Join Date: Mar 2008 Location: Jalandhar/Melbourne
| Quote:
And if the dust does manage to creep onto IR cut off filter, well then first of all its out of focus till f8 and secondly its way easier and less risky to clean compared to a sensor. Its a shame such good design and such a beautiful sensor in one of the worst cameras ever produced. Nikon implemented a new dust removal-collection system in D60(i might be wrong about the model no. as its been a time and i don`t spend much time with base models). Its basically small tunnels inside the sensor box, particularily at the bottom of the mirror assembly. When the mirror slaps, it pushes air in a way that all the dust goes through these tunnels and gets stuck to adhesive piece of tape. This was meant to remove dust off the sensor and get it stuck to the tape. How effective it is/was i am not too sure. Maybe someone with a D60 can check it out. Also Dust is not only the problem, moisture is worse than dust. Fungus is the biggest nightmare you can think of (ofcourse other than shutter death). And fungus on a sensor is not an easy task to repair. | |
| | #1900 (permalink) |
| ![]() What are the places around Chandigarh/Delhi where one can sell/buy secondhand Photography equipment for decent prices. Thanks
__________________ A lot of things are done right but for the wrong reasons, worst being consumer DSLR`s and 50mm`s... |
| | #1901 (permalink) | |
| Quote:
Over this, you would use a higher shutter speed/ larger aperture combination if you want to catch motion photographs, or if you wish to keep the depth of field less. A lower shutter speed/ smaller aperture combination would be used if you want a larger depth of field. | |
| | #1902 (permalink) | |
| Quote:
I ran into a situation similar earlier this yr, for the required result I needed to have very slim DOF, so I was using f1.4 at 85mm but that meant some shots had blown highlights and pretty much everything was overexposed at 1/8000. Ended up using Nd400 filter with fill flash at 1/250 to rectify the situation. Point here is, thumb size changes with each scenario ![]()
__________________ A lot of things are done right but for the wrong reasons, worst being consumer DSLR`s and 50mm`s... | |
| | #1903 (permalink) |
| Team-BHP Support ![]() | Wrong, no matter what condition whether its snow, pitch dark, raining. india losing cricket match or whatever, if your shutter speed is below 1/focal length, chances of camera shake increase in non stabilized hand held shots. So if you are shooting at 25mm(35mm equiv), then you need a shutter speed of atleast 1/25 to get a non blurred shot. Of course you are free to use a faster shutter speed, for example 1/2000, 1/4000 or whatever, but if you use 1/15, chances of a blurred shot increase. If you are a surgeon and have exceptionally steady hands, then this may not apply to use. I know people who can shoot 1/100 with a 400mm lens, handheld, unstabilized, and still get sharp shots.
| | #1904 (permalink) | |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| I never knew how the sensor cleaning works in Canon and found out that it has 3 things incorporated in auto sensor cleaning, pretty interesting: Canon EOS 450D Digital SLR Camera - Canon UK Quote:
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #1905 (permalink) | |
| Quote:
In my particular case, i rarely take on assignments and when i do, i rarely get them out of studio or at day time, either way i end up using a tripod. Btw, don`t mind but here`s a handheld 8sec shot inside a moving car with nikon 50mm @ f6.5 at 1:15am and i am definately not a surgeon. And i was definately not the driver, my friend was driving at that time at around 100kmph. If you do 100% zoom its looks like blur but its bad JPEG compression as the original RAW file is a little over 50mb while JPEG is around 28mb.
« Dealing with courier / shipping / duty when buying from ebay abroad...
Buying a Flat Panel Display (LCD/Plasma/LED etc) »
| Thread Tools | |
Similar Threads | ||||
| On a Temple Visiting Spree! Returned with only 1 wish. Need a DSLR! | mclaren1885 | Travelogues | 23 | 27th July 2007 12:21 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
Sorry.
