Old 8th January 2010, 16:07   #2716
clevermax's Avatar
Thanked: 445 Times
Originally Posted by it_inspector View Post
No Cpl filter will reverse the effect by reversing it, simple reason being light is getting polarized as it passes from outside to inside. When you reverse the filter, it acts as a bad ND filter.
One can use 2 cpl filters stacked on top of each other with one filter reversed and it acts as a adjustable ND filter but it ruins hue and sharpness. RGB channel need major adjustments so, i am highly against it but people do what they want to. I would suggest getting welding glass and using it with custom white balance than stacking-reversing 2 cpl filters.
I didn't say it will 'reverse' the effect, but there is no desired effect (cutting reflections) when you flip the CPL and use it. It's just a glass which cuts some light then - it can deprive you off by may be 1.5 stops, which it does when used in the normal direction as well.
You say 2 CPLs stacked together make an adjustable ND filter.
You also said that the hue will change and the image requires major RGB channel adjustments. So it is no longer a Neutral Density filter. It is then just a filter which will screw up the colors and cuts some light.
clevermax is offline   Reply With Quote
Old 8th January 2010, 16:47   #2717
Calm down buddy, I meant no disrepect. I only shared what i know.
Any piece of glass/plastic at front will mess hue and Rgb channels, Its certainly not as bad as using uncalibrated LCD+Printer combo and if one knows what they are doing, its fairly easy to correct.
Again, I meant no disrespect mate.
it_inspector is offline   Reply With Quote
Old 8th January 2010, 21:39   #2718
Thanked: 57 Times
Default solar eclipse on 15th of this month
Guys, Hope you all know about solar eclipse on 15th of this month which can be viewed in/from south india. Im in bangalore and i guess there will be a lil eclipse which can be seen from BLR too. As this is the DSLR thread, how can i take picture of the eclipse without frying camera sensors. i have 1000D and i dont wanna buy any filters for 5 minute eclipse. so can someone tell me any type of DIY so that i can picturise the esclipse (SUN) ?
How about keeping 1-2 x-ray films n capturing? will it work?
I dont wanna be a guinea pig here, so only tried and tested comments please
livyodream is offline   Reply With Quote
Old 8th January 2010, 22:01   #2719
Check out MrEclipse Index
They have quite few guides on how to do it and are very good.
Also prepare yourself early for the kind of shots you want and appropriate lenses, e.g. for following thirds with just sun as the subject one would need around 700mm range.
Old 8th January 2010, 23:48   #2720
vivekiny2k's Avatar
Thanked: 184 Times
you can make it with various things like old Xray film, exposed camera films etc.
apart from that, here is what I did:
made a small hole in a cardboard and placed it on a mirror. put the mirror in sun and directed the the sunlight inside the house thru this set up. Got a clean image of sun along with accompanying clouds. try it, it's fun watching the eclipse sitting on a sofa in your house. do it beforehand to test the set up, you should see a complete sun. you can easily make a video of this.
vivekiny2k is offline   Reply With Quote
Old 9th January 2010, 02:06   #2721
sabret00the's Avatar
Thanked: 45 Times
very nice thread extreme helpful and lots of information
sabret00the is offline   Reply With Quote
Old 9th January 2010, 21:15   #2722
pramodkumar's Avatar
Thanked: 947 Times
Brought a sony A230 today, it came with a speaking instruction manual, clevermax
Pramod
pramodkumar is online now   Reply With Quote
Old 9th January 2010, 21:19   #2723
Hi, I am confused between the 1000D and the 500D. Any suggestions? I do not have any video capturing needs, and this is going to be my first DSLR.
I was contemplating the 1000D with the IS lens, but a lot of people seem to be suggesting that it is hardly an upgrade from point and shoot cameras.
e1t1bet is offline   Reply With Quote
Old 9th January 2010, 22:13   #2724
clevermax's Avatar
Thanked: 445 Times
Pramod
Hey congratulations from your speaking instruction manual (arrghhh...!) BTW where is that much anticipated first picture?
Alpha 200/230 is a great entry level DSLR. Get an old Minolta glass too and you have a wonderful setup with minimal spending. Wishing you so many happy clicks with it.
Old 9th January 2010, 23:25   #2725
Thanked: 947 Times
There you Go!!!
Stupid compression
Pramod
Old 10th January 2010, 05:20   #2726
ph03n!x's Avatar
Thanked: 120 Times
Am not sure which P&S camera you use. If you have a DSLR-style P&S (like the Canon SX1 IS or SX20 IS), then the major difference in going up to a 1000D will be the option of using multiple lens.
If you already know what each lens available out there for a DSLR means (yes, there is more to it than zooming ), what aperture, shutter speed and ISO do, et all, then you can skip the 1000D and go for a 500D (or a 50D - depending on your budget).
Else 1000D is a good start.
ph03n!x is offline   Reply With Quote
Old 10th January 2010, 05:57   #2727
Thanked: 154 Times
Default best place to buy nikon dslr
where can i get d90 at lowest price?
its a big investment for me, so dont want to pay too much
OT can we have a thread where we can discuss best prices of dslrs?
if there is one kindly redirect
TIA
vikramvicky1984 is offline   Reply With Quote
Old 10th January 2010, 07:47   #2728
500D is a step higher than 1000D, it feels much better in your hands and build quality is a tiny bit better.
People going to argue with me but i suggest leave both aside and get a 450D if you want to go Canon way and spend rest of the money on the lenses.
Just from a P&S is huge, doesnt matter what is everyone saying. Biggest change is the response time, doesnt matter what kind of P&S there is always a delay in taking a picture while DSLR's have almost no delay (i say almost not no). Then comes the ability to go Wide and Ultra Wide angle lenses and obviously the ability for faster lenses. Then the ability to add a grip and increase battery life significantly on the go. There are other things which are quite obvious when you go from a P&S to DSLR.
Old 10th January 2010, 07:48   #2729
clevermax's Avatar
Thanked: 445 Times
There you Go!!!
Attachment 261337
Stupid compression
Pramod
It took me few minutes to guess where this place is. Seems very much not like Kerala isn't it?
Old 10th January 2010, 09:57   #2730
Nutty Nair's Avatar
Thanked: 38 Times
Pramod
Congrats, buddy on your buy! Wishing you lots of happy clicks.
Ranjith
Nutty Nair is offline   Reply With Quote
DSLR Video Discussion Sankar Gadgets, Computers & Software 129 18th August 2017 19:07
On a Temple Visiting Spree! Returned with only 1 wish. Need a DSLR! mclaren1885 Travelogues 23 27th July 2007 11:21
