| LinkBack | Thread Tools | Search this Thread |
| | #9586 |
| Newbie Join Date: Apr 2011 Location: Bangalore
| I own a canon 550d and i am begineer photographer . I am wondering if we need to take any extra precautions while changing lenses to avoid dust getting into the sensor region . Also, Whenever I swichoff the camera I see "sensor cleaning" message. What kind of cleaning does it do? When using at water bodies , does it pose a severe risk if slight mist creeps into the body when changing lenses? What is the risk if Sensor region is directly exposed to Sun light ?What kind of precautions do we need to take generally? |
| | #9587 | |
| Senior - BHPian Join Date: Nov 2009 Location: Bangalore
Thanked: 155 Times
| Quote:
Whatever lens change has to be done, do it inside your house/hotel room. I would never risk changing my lens outside. Water body or coffee shop, its a strict no-no. | |
| | #9588 |
| BANNED | |
| | #9589 | |
| BHPian Join Date: Oct 2011 Location: Bangalore
Thanked: 158 Times
| Quote:
Mist entering cam: the mist will not land on the sensor. The mist (spray) may fall on reflex mirror. Never touch this mirror - its a first surface mirror (reflecting coating on top surface). Let the droplets evaorate in a dust free environment. Below the mirror you will find shutter curtains in closed position. So usually mist spray will not reach the sensor unless mirror is locked up and shutter is opened. I have used my 400D in some really bad rains in Bandipur (caught unprepared) and the cam survived, despite not being weather sealed. Reinforced my trust in Canon. Sensor exposed to sun: No issues as long as you dont have a lens fitted, and focussing the sun, and using slow shutter. Just sunlight falling directly on sensor for few seconds does no harm. I have used my Canon 300v (film), 400D, and 7D in really harsh conditions (-40©) and the cam n lenses worked very well ![]() | |
| | #9590 | |
| Senior - BHPian | Quote:
| | #9591 | |
| BANNED | Quote:
How to check this?Are you telling the lens is faulty? So how can I get this checked? I took this one with same lens,but used flash Last edited by white-rabbit : 6th April 2012 at 17:37. | |
| | #9592 | |
| | #9593 | |
Where the professional lenses excel is in the wide range of minimal distortion and better performance wide open, some thing which lower cost lenses compromise on, but for the price you pay, the low cost lenses are perfect if you know their limitations. | |
| | #9594 | |
Thanked: 158 Times
| Quote:
White-rabbit, I read your previous posts now - UV filter is a good protection for the front element of the lens, but a poor quality one can degrade image quality. Please stop using it on kit lens. Use a good UV filter on expensive lenses in dusty conditions / near beaches where you might get salty sea spray. Dont forget to remove the UV filter for important shoots. Commercially available macro lens kits may not provide good results, esp. higher magnifications. They produce visible chromatic aberration and focal plane distortion. Get a set of lens reversal rings and adapters that help you fit the lens reversed on your cam. You need to judge and use manual exposure as there is no aperture control on electronic lenses. Need to have a still subject and camera. You will be amazed at the results you get by reversing a 50mm lens ![]() Last edited by autocrat : 6th April 2012 at 21:30. | |
| | #9595 | |
Anyway, silly me thinks that I've got a better kitty here because never have i seen so much distortions with it; wide open, closed down, or somewhere in between. Gonna post some samples when I fix my router :( Last edited by clevermax : 6th April 2012 at 21:24. | |
| | #9596 | |
Thanked: 158 Times
| Quote:
| | #9597 | |
In general the low cost lenses are designed for mass production and use plastic barrels where the lense elements are fixed once and for all, extremely difficult to adjust the elements. Hence you get a wide variation in quality/performance. In case you are particular, you should test a few lenses (if the shop permits) and then choose one which gives the best performance. There are a number of articles on the net on this particular topic which you can peruse. | |
| | #9598 | |
| | #9599 | |
Thanked: 158 Times
| Quote:
| | #9600 |
Thanked: 158 Times
| Wish to share some pics. 1) Shot in the Basilica Notre Dame in Montreal - one of the oldest in North America. Its interiors are completely built of wood. I attempted several times to get a good image and was not satisfied with the results. I got frustrated and started walking out, and just when I was about to exit - I just turned around, took this pic and left. I realized that I got a good image only after I reviewed this image on my lappy at home - lesson - never delete a pic until you see it on your comp ![]() The original RAW file was about 17MB, and its compressed to 679kb - so lot of detail is lost - but you can still see the beauty of this basilica. ![]() 2) Macro of a Ball Point - the ball is of just 0.5 mm diameter! achieved with 50mm f1.8 lens mounted with lens reversal ring. ![]() 3) A spider that was about 6~7mm long was captured with a 100mm Macro USM lens. The spider was extremely difficult to spot - blended well with tree bark. The scene was lit with a Canon EX520 II Speedlite (off camera). The green ones with orange legs around this spider may be the young ones - not sure though. ![]() 4) How important is a high end cam to get a decent pic? Debatable point - but like some members have mentioned earlier in the thread - there is a sweet spot for every lens - and cam. If we understand the limitations of our devices and operate with in their "sweet spot" zone, we can still get decent pics I think. Here is a pic from my Nokia 5800 Xpressmusic post processed on Gimp: ![]() I am thrilled to see so many BHPians sharing info on photography ![]() |
Similar Threads | ||||
| DSLR Video Discussion | Sankar | Gadgets, Computers & Software | 111 | 21st October 2012 20:45 |
| On a Temple Visiting Spree! Returned with only 1 wish. Need a DSLR! | mclaren1885 | Travelogues | 23 | 27th July 2007 11:21 |
