Old 29th July 2012, 23:10   #10261
clevermax's Avatar
Thanked: 419 Times
Default Re: The DSLR Thread
I am planning to buy an ND filter(s) so was doing my research, came across variable ND filters (fader), which allows you to increase or decrease the transmittance and go from 2 to 8 stops with just a turn of the ring.
Anyone here using such a variable ND filter? feedbacks appreciated.
clevermax is offline   Reply With Quote
Old 29th July 2012, 23:37   #10262
Parthasarathig's Avatar
Thanked: 489 Times
Originally Posted by honeybee
And don't expect great results from day one. Won't happen even if you bought the most expensive DSLR. It's what the man behind the machine does that matters more than what the machine is capable of.
Thanks for the advice sir. Now my first objective is to get the camera tested tomorrow.
Next is to acquire one tripod. Ive seen some trilods in the Whizz camera store. Will that fit with this camera? Or are the tripods going to be specific fits for specific company cameras?
Managing my expenses is the key here; since ive another expensive hobby i.e scale models.
Sir any recommendation of good tutorial books for learning basic things like aperture, shutter speed, iso and differences in film and digital shooting.
Also i see these days that the basic kit comes with 18-55mm lens. Now do i need that? Or is the one im having 35-70mm ok? Just for beginner skills.
Thanks once again.
Partha.
Parthasarathig is offline   Reply With Quote
Old 30th July 2012, 03:06   #10263
You can use 2x CPL filters stacked to do the same, just the second filter needs to be reversed. Although every vari-ND will give a color cast.
rajb3125 is offline   Reply With Quote
Old 30th July 2012, 05:43   #10264
geeash's Avatar
Thanked: 129 Times
Originally Posted by thalavoy
Has anyone in Chennai checked out the image Expo at Ctc? Any thing interesting?
Yeah i did go there and splurged on gears. Nothing too interesting but usual stuff s were there. I got a Canon macro 100mm f 2.8 for 29k (way cheaper) a nissin di622mkii a couple of memory cards uv filters and few ebay stuffs like flash diffusers. The highlight was all these cheap flashes called Sonia and pico which everyone was getting for 2.5k and studio kits. Was looking for some company.... But went all single
geeash is offline   Reply With Quote
Old 30th July 2012, 09:32   #10265
rameshnanda's Avatar
Thanked: 814 Times
I have reading the tutorials in this link for sometime and found quite useful. Try this out.
Cambridge in Colour - Photography Tutorials & Learning Community
rameshnanda is offline   Reply With Quote
Old 30th July 2012, 15:23   #10266
mayankjha1806's Avatar
Thanked: 820 Times
Originally Posted by nilanjanray View Post
What aperture/ F value when you shoot at 1/100? I am not familiar with 28-300, so asking.
Here is the info from NX2,
4. See if by mistake you have negative exposure compensation dialed in.
How do i check that?
I am uploading the picture that i took, although i had to strip down to fit 1mb size limit still you can make out the blurriness and lack of brightness this after using 3200 as ISO and Shutter speed of 100.
mayankjha1806 is offline   Reply With Quote
Old 30th July 2012, 15:43   #10267
nilanjanray's Avatar
Thanked: 2,404 Times
Use a tripod - increase exposure time - reduce ISO
And how would increasing exposure time help in shooting sports? Any decrease in shutter speed would lead to motion blur e.g with humans/ball/shuttle.
nilanjanray is offline   Reply With Quote
Old 30th July 2012, 16:14   #10268
StarScream's Avatar
Thanked: 633 Times
check white balance. your camera is probably set to auto. I assume the lighting here is fluorescent, change WB to that (or tungsten if that's the lighting source). Auto WB can't handle all lighting types and understanding white balance will dramatically improve your pictures.
I see a color temp setting in the NX2 data - is that default or is that a setting change you made?
StarScream is offline   Reply With Quote
Old 30th July 2012, 16:16   #10269
Thanked: 19 Times
I had ordered Canon EF 40mm f/2.8 STM Lens from Flipkart and was delivered couple of hours ago. I'm little concerned with the packaging. This box was not sealed.
Could someone clarify if this is how the canon lens are packaged.
bkishore_77 is offline   Reply With Quote
Old 30th July 2012, 16:22   #10270
Thanked: 820 Times
No, it was not on Auto, i set it to Shutter priority program and played around with shutter speed till i got clear non-blurry shots. The shots looked dark hence than changed the ISO settings to increase the sensitivity.
Color temperature, i did not change that, that's by default recorded by camera i guess.
Light source was Tube Lights (Not sure if that's what you meant), How do i fiddle around with White Balance (Through software?)?
Thanks a ton for the response.
Old 30th July 2012, 16:28   #10271
download2live's Avatar
Thanked: 387 Times
Easier solution will be to carry a grey card with you. And calibrate the camera by pointing to it.
I have heard of some people pasting the grey card on the inner side of the lens cap so that it is always available.
EDIT: Your lens is not very bright starting at f3.5 at 28mm. This pic is taken at 170mm if I am not wrong and hence f6. Under such less lights the ISO will be jacked up resulting in grainy images. You can use bright portrait prime lens.
TIP: In such conditions going for Black and White is more sensible. Somehow the grainy black and white is more acceptable to me than a grainy color picture.
download2live is offline   Reply With Quote
Old 30th July 2012, 16:40   #10272
StarScream's Avatar
Thanked: 633 Times
I don't mean the exposure mode. At the back of the D90, to the left of the screen is a column of buttons. One of them is white balance (it says WB). You press that and use the rear and front command dials to change between WB types and the hue (warm, blue) within that. Tubelight is fluorescent (the tubelight icon). Change to that setting and see if it helps.
Old 30th July 2012, 17:01   #10273
Jaguar's Avatar
Thanked: 148 Times
Infractions: 0/1 (5)
Good catch! I missed the sports photography part.
Jaguar is offline   Reply With Quote
Old 31st July 2012, 16:50   #10274
gd1418's Avatar
Thanked: 656 Times
Reference Post #:10175, yesterday received memory cards for the D800 that I had ordered online from DeltaPage..
Old 31st July 2012, 18:04   #10275
clevermax's Avatar
Thanked: 419 Times
Usually there will be a hologram seal or something... It is not seen in this package. Some sellers open up the package to put a seal on the warranty card, when I bought my camera, they called me up from smartshoppers and asked me whether it is okay to open it up to seal the warranty card.
DSLR Video Discussion Sankar Gadgets, Computers & Software 129 18th August 2017 19:07
On a Temple Visiting Spree! Returned with only 1 wish. Need a DSLR! mclaren1885 Travelogues 23 27th July 2007 11:21
