| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian Join Date: Apr 2005 Location: Pune
| Hello friends Today evening after coming back from collage when I tried to start computer it refused completely. There was no response when I pressed power button on CPU. So called computer guy he thought since its with power SMPS must have gone bust. So he came replaced SMPS but still same thing. Then next guess was CMOS battery. Tried replacing it but no luck. This is where really interesting and weird part starts. After removing power cord and removing battery, if I put battery into its place first and then attach power cord computer starts directly. And it works just fine. Only I have to adjust date and time and it works like there is nothing wrong. The computer guy is gonna take CPU tomorrow to check motherboard. So I wanted to ask is there anything which I can do which will solve this problem? Will I have to replace motherboard ? Waiting for reply. |
| | #2 (permalink) |
| BHPian Join Date: Dec 2005 Location: bangalore
| after it starts normally ..if u shoutdown and restarts wat happens ? If it starts properply ....then how come MB is gone ? ..it could be bios settings ..cpu clock seetings might be problem ...if u have more than one memory cards (RAM) ...try starting with only one card and isolate the problem...aslo check the grounding ..if the case is giving u small shocks if u touch it..? |
| | #3 (permalink) |
| BHPian Join Date: Feb 2006 Location: Bangalore
| Hmmm very weird case. Doesnt look like anything's gonna be wrong wit ur motherboard or processor. Might be some problem with the power supplu ( the box with the cables n fan etc)... Give it for check up and see. How old is the comp??? |
| | #4 (permalink) |
| BHPian Join Date: Nov 2005 Location: New Delhi
| Most likely it could be a problem with the BIOS on your motherboard. Or, like it happened in case of my dad's comp, there was a certain capacitor on the motherboard which used to get overcharged at times, and used to shutdown the system abruptly, after which it would not come up. Removing all sources of power used to help get it out of deadlock. If it is something like that, then a professional h/w engineer will be able to replace that faulty part for you at a low cost. Though make sure that your service guy is really trustworthy and doesnt fleece you with the wrong reasons.
__________________ Too much work, too less play - seems like I need some BHP |
| | #5 (permalink) |
| BHPian Join Date: Sep 2004 Location: NO IDeA/Madurai
| Dude - post your config - it'll help us. 1. check the battery voltage with a multimeter - IIRC - it should be ~3v 2. swap out your sticks of ram - try running with only one stick which works for sure. 3. any error beeps on bootup ? - if you have the d-bracket with the LED's , whats the light config ? 4. remove the power switch connector from the mobo and try starting by shorting the terminals with a screwdriver - for all you know, it's just a loose connection in the power switch 5. are you overclocking anything - run the bios on fail safe defaults first My money's on your mobo gone bad but you never know.... (I can feel your pain - ive been experiencing a run of problems over teh last one year - omne mobo dead (gigabyte km400vm rev 2.0) , 3 6800GT's PCI-E.....2 hdd's , and one mobo - MSI neo4 ultra showing the infamous battery drain problem now- I'm going to get the earthing done again and see if it helps - and put a big stabilizer on the mains)
__________________ Six Hamburgers and Scotch all Night, A drive in a Mustang just to put me right |
| | #6 (permalink) |
| Senior - BHPian | 1)if there is a CMOS jumper,set it to clear position after removing the battery.return the jumper to the old position and reinsert the battery. 2)reinstall your ram modules.
__________________ No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz |
| | #7 (permalink) |
| BHPian | make sure the ups is off...put the switch behind the cpu off ..then put the ups on..then put the switch behind the cpu on ..n power up!
__________________ Lexus GS300 | Mercedes S320 | Honda Accord 2.4 AT | Mercedes E 220 | Skoda Octavia 1.9 TDI | Honda City ZX VTEC |
| | #8 (permalink) |
| Hello friends, thank you for your quick response. I finally managed to trace problem. No its not BIOS its not Mother Board its no RAM its faulty power switch (literally the button which I push on CPU)I remembered having feature in BIOS which starts the computer as soon as mains power supply is switched ON (in my case its UPS) so thought to give it a shot & walla it worked. I switched off computer again & it worked again. and it is still working. It seems that once battery is removed for next reboot computer starts when mains is ON and then previous settings are restored. Thank you for offering help everyone. Really appreciate it. Last edited by adya33 : 28th March 2006 at 23:52. |
| Thread Tools | |
Similar Threads | ||||
| Help - Laura AC weird problem | vipul_bscity | Technical Stuff | 3 | 20th November 2009 13:53 |
| RSS Feeds Problem in my computer | Abes | Shifting gears | 7 | 4th March 2009 15:49 |
| Weird problem - Ikon | madhunm | Technical Stuff | 11 | 15th February 2009 21:55 |
| Weird temperature problem | teknophobia | Technical Stuff | 4 | 26th August 2008 23:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
