Old 23rd January 2013, 00:49   #31
k2max6's Avatar
Thanked: 130 Times
Originally Posted by black12rr View Post
Excellent ,this came at right time . Thanks for putting it up .
Guys if you can also recommend the brands of the products used it will be better .
1. Can I just have video display without recording(recording HDD can be added later) ? . Just if some one opens the gate, I just switch the video input on remote of TV and the video of camera opens up on TV .
2.How costly at IR video cameras of good resolution compared to normal video cameras ?
Yes its possible.
You can buy any CCTV camera as per your budget and need to connect its video cable to the TV.The CCTV will continuously provide video to TV so whenever you select the input the feed would be available.
IR cameras are available as low as 800 bucks. You should get a decent one around 2.5k.
If you want high definition video then ip camera is the way to go.That would cost you atleast 6k with motorised pan and tilt.Would also provide you anywhere access.
k2max6 is offline   Reply With Quote
Old 24th January 2013, 00:42   #32
BuildUpGypsy's Avatar
Thanked: 49 Times
Default Re: A step by Step guide to setting up a Home security system
Gurus, any recommended reliable free DDNS service? Static IP is not affordable.
BuildUpGypsy is offline   Reply With Quote
Old 24th January 2013, 06:48   #33
nkg77's Avatar
Thanked: 141 Times
https://account.dyn.com/
http://myq-see.com/
I am using the above 2 for sometime now without any issues.
nkg77 is offline   Reply With Quote
Old 24th January 2013, 11:08   #34
dutta_d1's Avatar
Thanked: 35 Times
Just my 2 cents...
For people looking for a quick and cheap alternative (maybe temporary) for a surveillance system, can now use their android phones as a complete unit. There are various applications available from the Play Store like "Motion Detector" , "Surveillance", etc. which act like a complete motion sensing unit which can send mail and notification to another cell whenever it detects a motion.
I used such a setup using a cheap phone when I needed security for my car parked outside in the lawn by setting the phone on a window with the camera side to the car and it worked ok.
I guess it is worthwhile when going on a trip outside to have the app installed on your phone for car security.
dutta_d1 is offline   Reply With Quote
Old 7th March 2013, 13:45   #35
Behemoth's Avatar
Thanked: 1,742 Times
Some recent updates / upgrades to my system in the past few days:
1) Upgraded my LCD monitor to a proper 15.6 Inch one from LG - E1642C , which I got from Flipkart at a good price of around 4700, now I can see all camera feeds with good clarity. Connected it with a VGA cable to the DVR unit
2) Also had an old Belkin Laptop Cooler unit lying around, kept it underneath the DVR, to keep the HDD cool, as the DVR unit did not have any inbuilt cooler fan and to keep it cool. It runs off the USB on the DVR. (Thanks to Sohail99 for suggesting that HDD cooling is required with small DVR units)
3) Added a fourth Cam in the front of our house 480TVL, with 40 M range and 48 IR Leds, which has decent night vision.
4) Got the Remote view finally working and am able to remotely view all my cameras from anywhere, both on my android phone and my Android Tab.
The client side software which I am using is Asee+, which works fine.
I also took a Dyndns (Paid) account as my Belkin router only supports Dynamic DNS only from Dyndns!
There were two vital settings which I had missed earlier, which I figured out now and have got it to be able to work.
My DVR actually needs three ports to be forwarded! One for server, one for HTTP and one for Mobile. Forwarded all these ports and was able to access it fine.
The other setting which I had missed earlier was on the user privileges for the remote login user, which needs to be enabled for "Remote view" which I had missed earlier as it was embedded in a dropdown menu.
The user guides which came with the DVR are not much help as they are typical English translations of the Chinese guides!
Overall the system is running fine and the new upgrades have made it more effective.
Behemoth
Behemoth is online now   Reply With Quote
Old 6th April 2013, 18:05   #36
Jaguar's Avatar
Thanked: 151 Times
We are planning to install a security system in our apartment complex. Though I would love to, DIY is not an option since I don't want to deal with the people in case of any hiccups .
The need is for a system that can support some 20 cameras including weather proof ones. Recording is needed. Web access is not mandatory. Can someone point me to any company/person in Bangalore who would be able to set this up? Any known brands I should be looking for in Cameras and DVR?
Jaguar is online now   Reply With Quote
Old 6th April 2013, 19:10   #37
Warwithwheels's Avatar
Thanked: 1,028 Times
You may need to buy a 24 channel DVR. Depending on the volume of data you want hold i.e to hold a week's or month's recording you need to choose your storage media.
2TB Hard disk drive would be the bare minimum in case you want to store the data in a decent resolution. Go for AV hard drives which are specifically designed to be run 24X7.
I have been using HIK vision, US based company. The equipment is pretty robust. And hard disk drive is Western Digital AV HDD.
Remote view (web access) is available across most models. Just that you need a static IP or some tweaks to enable it.
Have you've got a inhouse dedicated security team who can constantly do the video surveillance?
Warwithwheels is online now   Reply With Quote
Old 6th April 2013, 19:44   #38
Behemoth's Avatar
Some brands that you can consider based on your budgets:
Mid range: HikVision, Qsee, Samsung, Sony, Panasonic
Professional: Bosch, Honeywell, Pelco
Find a good local system integrator who can install the system professionally for you.
You will need at least 24 channels like warwithwheels also suggested. Also be sure to get a good high capacity Ups (I can recommend Apc) for the whole setup, to protect againt line surges and power changeover (assuming there is a generator backup). In case there is no generator backup, go for at least a 1.5 Kva pure sine wave UPS with 2*200Ah external batteries.
Old 13th April 2013, 17:09   #39
bj96's Avatar
Thanked: 130 Times
Inspired by this thread I have started a DIY project to install a surveillance system for my home. I am right now sourcing different components- have already purchased a 4-ch DVR and outdoor IR camera. I have a question regarding HDD for DVR.
How critical is to install a HDD geared for AV applications like WD AV-GP (Flipkart http://www.flipkart.com/wd-av-gp-2-t...c-24df8d77a1bb ) in the DVR or any normal Desktop SATA HDD is just fine?
Tia,
-BJ
bj96 is offline   Reply With Quote
Old 13th April 2013, 21:55   #40
Behemoth's Avatar
Tia,
-BJ
Good to know that you are setting up a system.
For the Hdd, it is better to get a higher duty cycle SATA drive as it will run 24 hrs and can get damaged if it is not suitable for 24 hr use. You can buy WD Blue if it is available. Also good to get some additional cooling for the Dvr.
Old 19th April 2013, 19:13   #41
R2D2's Avatar
Thanked: 2,207 Times
A very useful thread. I plan to install a similar system at home.
Thanks Behemoth!
Old 13th September 2013, 15:30   #42
abishek2222's Avatar
Thanked: 162 Times
Very usefull stuff and a nice write up, how ever just wanted to know did you think of getting an IP camera instead. how different ins the view from an ip camera compared to your setup.When you connect to the stream from the net to your DVR.
abishek2222 is offline   Reply With Quote
Old 13th September 2013, 15:49   #43
Behemoth's Avatar
Thanks Abhishek,
In fact, before this setup, I did have a single IP camera which I was using for monitoring my home.
But a single IP camera setup has several disadvantages which this system overcomes:
1) An IP camera is typically standalone and cannot record (unless it has a built in SD card which too will have limited time recording due to small space)
2) If you have to keep a large number of angles in surveillance you will need multiple IP cameras, which will be a more costly arrangement compared to the setup.
But if you just need 1-2 angles, then IP cameras are ok. Only the recording part you will need a separate media server to record the feed if you would like to have recorded surveillance.
3) Technically IP cameras are digitally communicating versions of analog cameras with a built in Media streaming, for easy access. But they are downspec-ed in terms of the Image quality to make them cheap. Good IP cameras which are used in professional applications like city surveillance are really expensive and can exceed almost 80k per camera.
4) Also most commonly available IP cameras do not have Ingress Protection (for protection from rain/ dust) and also have very limited Nightvision capability
Behemoth
Old 14th September 2013, 07:38   #44
Thanked: 162 Times
Thanks Abhishek,
what do you feel about this dvr
http://www.ebay.in/itm/4CH-Channel-C...#ht_2422wt_987
Old 19th July 2014, 11:06   #45
Thanked: 59 Times
Originally Posted by sohail99 View Post
I would recommend an acrylic dome for it if you're placing it outside to protect it from dust etc.
link - http://www.amazon.com/Foscam-FI8910W-Network-Camera-Two-Way/dp/B006ZP8UOW/ref=sr_1_1?ie=UTF8&qid=1358048628&sr=8-1&keywords=foscam
I have it placed near my car and can talk through it to ward off miscreants! lol
Hi sohail99,
I am planning to buy foscam for outdoor monitoring. Did you buy it in India or US? do they provide support here? I checked Amazon.com review for Foscam outdoor camera and see lot of comments on reliability issues.
venks is offline   Reply With Quote
ARTICLE: RTO Hypothecation Removal Process - Step by Step Guide Technocrat On owning a car 387 26th July 2018 19:31
Step by step guide to restoration Ricky_63 Post-War 21 2nd June 2010 10:52
DIY - Step by Step Guide on Replacing Timing Belt in Camry ssanjeev DIY - Do it yourself 14 6th September 2009 01:40
