Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 15th August 2007, 21:17   #736 (permalink)
unknown's Avatar
Originally Posted by amitoj View Post
If you dont mind paying a li'l extra for the brand, then its a good enough spec, otherwise i think you will get better specs in other brands like acer, hp, lenovo etc at a lower price.
For Dell, you have to customise your order on the web and then leave your phone number or email id and someone from Dell India's sales team will get in touch with you. They say it takes 4 to 7 weeks for delivery but depending on your config, the sales guy will be able to give you a more "accurate estimate".
Thanks for the info, i'll see some acer,hp laptop tomorrow then make the final decision .
unknown is offline   Reply With Quote
Old 15th August 2007, 23:07   #737 (permalink)
vabs78's Avatar
Hi All,
I am planning to buy a Apple MacBook 2.16GHz 1GB RAM 80GB HDD. Its available for $1299 at Apple stores in US.
Buying Apple was a big decision for me as I did everything on Windows till now. But now I am fed up with windows so want to try Mac.
If there are any MacBook owners on the forum can I get some real feedback from them? Is it worth taking the risk of going to a completely new brand and OS?
Thanks in advance.
__________________
If everything seems under control, you are not going fast enough!
vabs78 is offline   Reply With Quote
Old 15th August 2007, 23:39   #738 (permalink)
devarshi84's Avatar
Hi vabs78,
Macbooks are an excellent product. mac OS is new to you but wont take much to get accustomed to it.
there may be compatibilty and software prolems on a large scale, but that's about it. plus there is an offer where you get an ipod for free(do check out on details)
If you are going to use it in US, give it a shot, their service and support are very much active.
__________________
boyracer.blogspot.com
devarshi84 is offline   Reply With Quote
Old 16th August 2007, 00:08   #739 (permalink)
Amey's Avatar
@ vabs78, If getting a brand new Macbook, you should be able to install Xp or Vista on it, theoritically cos Macs use Core 2 Duo CPUs now
Amey is offline   Reply With Quote
Old 16th August 2007, 01:53   #740 (permalink)
vabs78's Avatar
Thanks for the replies.
I am going to bring it back to India. Will use is US only for couple of months.
I searched on the net and found a lot of problems on MacBook. I don't know if its because of high expctations or are real issues. I will really appriciate if I can get first had feedback from someone.
I am planning to do just that but not Vista. I will install XP SP2.
__________________
Old 16th August 2007, 12:21   #741 (permalink)
unknown's Avatar
vabs78
You can install Xp on mac via Bootcamp & it works flawlessly ,why not get the macbook pro ?
Old 16th August 2007, 14:02   #742 (permalink)
jkdas's Avatar
Originally Posted by unknown View Post
vabs78
forget warranty and support from apple or microsoft or anyone if you get it wrong.
__________________
~ I n d i v i d u a l l y , we are one drop. Together, we are an ocean. ~
Old 16th August 2007, 17:35   #743 (permalink)
vabs78's Avatar
vabs78
I have heard that iSight doesn't work in XP. I am not sure if this is fixed in Bootcamp updates.
Macbook Pro is not VFM at all. If you compare the configurations of Pro
and 2.16GHz Macbook there is not much difference except the graphics card. But there is a diff of $700 in price.
Yah thats true. But I cant resist messing up my PCs for any reason.
__________________
Old 21st August 2007, 00:51   #744 (permalink)
abhibh's Avatar
hey i just check my laptop battery today and it wont go beyond 70% charging.
Is it some bug or something happened to battery
__________________
tinypic.com/player.php?v=35mo01l&s=4
Old 21st August 2007, 10:05   #745 (permalink)
devarshi84's Avatar
you need to recalibrate your battery. Google and you will find more info on this.
__________________
Old 4th September 2007, 19:42   #746 (permalink)
abhibh's Avatar
Default Charging Battery ?
Some people have suggested me that i should not always plug in the laptop charger and use my laptop on AC power. It can overcharge and damage battery and stuff etc. Is it true ??
Also good steps to charge laptop battery and taking care of battery ?
__________________
Old 5th September 2007, 00:35   #747 (permalink)
devarshi84's Avatar
that's the biggest baseless info I have heard. my laptop is close to 3 years old now. Battery wear is 30%. I keept it on ac power 80% of the times.
batteries today dont need much care but here are somethings you can do to keep it in good shape.
1. recondition your battery every 3-4 months.
2. Only recharge them when its fully empty. Whenever you recharge them, recharge them fully. THe computer reads from the battery too and such a process will help the pc read the information properly.
3. Notebook pc's usually tend to get hot. You will know when fans start rolling. Heat is bad for the battery, to help this please see that the air vents are fully open and not blocked by any objects and also that the base is elevated on the stands.
to get more batterylife on a single charge,
1. Underclock the cpu
2. Undervolt the cpu (only recommended if you are a pro)
3. Underclock a dedicated gpu (if your notebook has one
4. Lower the brightness.
5. Close programs at startup and those which consume cpu usage.
__________________
Old 10th September 2007, 14:34   #748 (permalink)
Question Laptop memory upgrade
Need some info on the Laptop memory upgrade front. My present laptop has a single 512MB (533MHz) module. Is it ok if I upgrade (add) another module of 1GB (667MHz) OR should I add another module of 512MB (533MHz)?
Though the manufacturer tech support said that thelaptop's recommended 1GB module is the 333MHz one, but the reseller said it's no problem if I add the 1GB@667MHz module.
Please shed some light.
noviceDriver is offline   Reply With Quote
Old 10th September 2007, 14:53   #749 (permalink)
hkanitkar's Avatar
Default HP dv5118TX acting crazy at windows installation
I have a HP dv5118TX laptop, bought abt an year back. I was trying to re-install Windows XP today, just to ensure a clean system. This is where the problem starts.
After loading up the setup files, it shows 3 options : Press 'R' to repair the previous installation, Press 'F8' to install new copy or Press 'Esc' to exit setup. At this, if I choose any of the first 2 options, it is giving me error stating that no hard-disks are connected, and system must reboot. On the other hand, if I run the previous Windows XP installation, it runs absolutely fine. I am just not able to understand whats wrong.
My lappy did not come with any cds. There hasn't been any problems with it so far. But now this.
Can somebody please help me out ?
__________________
एक सात पाच पाच
hkanitkar is offline   Reply With Quote
Old 10th September 2007, 17:45   #750 (permalink)
devarshi84's Avatar
Originally Posted by noviceDriver View Post
if one of your sticks is 512mb 533mhz and running well, I would advice you to go for the same stick.
Re-seller is taking you for a ride. 667mhz stick is usually expensive but wont work above 333mhz if the tech support says so. In that case even your 533 mhz stick is running at 333mhz.
__________________
Thread Tools
The Digital Camera Thread: Questions, discussions, etc. satish_appasani Gadgets, Computers & Software 2896 10th October 2008 23:04
The Playstation 2 Thread: Questions, tips, prices etc. Sheruken Gadgets, Computers & Software 278 23rd July 2008 23:49
Help in configs - Gift Laptop Jr Godzilla Gadgets, Computers & Software 3 13th January 2008 10:20
Best Baleno deals in Mumbai Boom Shiva The Indian Car Scene!! 3 17th December 2005 17:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
