Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 1st July 2008, 11:58   #1051 (permalink)
trrk's Avatar
Hi aza,
> I have 2 Acer with me on is 4710 and the other one is 4720 and my official
My office has 3 acers, a 4310 11 months old, another 4310 5 months old and a 5315 about 4 months old.
Noe of them have heating problems and are on for at least 11 hours or more everyday.
They were specifically bought to replace the other low end (Sahara) which had heating problems especially with our DOS application.
__________________
Rajesh
-Marina LS, Oct 05, 45803 (46450) kms, 13.98 kpl, 45km/day
-City CVT, Sep 07, 16226 kms, 13.24 kpl, 50km/day
trrk is online now   Reply With Quote
Old 1st July 2008, 12:43   #1052 (permalink)
Guys, Dell launches the Studio series. I think it is inbetween the Inspiron and XPS series. Looks good.
Dell Studio Laptops / Notebooks: Personalized laptops, light weight laptops with multimedia features
__________________
Proxima
2004 Safari LX
2008 Pulsar 180
Proxima is offline   Reply With Quote
Old 2nd July 2008, 09:23   #1053 (permalink)
vinayvtec's Avatar
Cool
Originally Posted by trrk View Post
Hi aza,
Hey Bro, try flashing the BIOS it should fix the issue.
__________________
I live my life a quarter mile at a time. For those ten seconds or least I'm free nothing else matter
vinayvtec is offline   Reply With Quote
Old 2nd July 2008, 15:03   #1054 (permalink)
trrk's Avatar
Hi Vinay,
The Sahara has been sold. But I do have an LG which also does the heating trick. The common feature between the Sahara and the LG are that they are 14 inch square screens. None of the wide sceen 14 / 15 laptops have heating problems.
Any pointers as to how go about the BIOS flashing part?
Thanks in advance!
__________________
Rajesh
Old 3rd July 2008, 00:10   #1055 (permalink)
Swiftron's Avatar
Hi Vinay,
Thanks in advance!
You should either get a executable file which can be run within Windows. Once you run the file it will restart and flash the BIOS upon restarting. Or certain versions require you to create a bootable flash disk, either using a floppy or some can be on a CD too. Depends on the manufacturer and the version. Almost all latest versions of BIOS come with executable files. They can be run from within Windows and it will flash the BIOS during restart.
__________________
I believe God made me for a purpose, but he also made me fast. And when I drive, I feel His pleasure.
Swiftron is offline   Reply With Quote
Old 3rd July 2008, 00:20   #1056 (permalink)
aZa
aZa's Avatar
Thanx for all your suggestions people! I'm gonna be checking out Nehru place for acer this weekend.
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
Old 3rd July 2008, 01:53   #1057 (permalink)
Swiftron's Avatar
Keep us posted when you buy one and pictures will be good too. Ask them for a demo and see if you can go online and see how it performs on multiple applications and multiple websites at the same time. Should give you a better idea about its performance atleast a fair idea about how it would fair when you use it on daily basis.
__________________
Old 3rd July 2008, 03:33   #1058 (permalink)
vinayvtec's Avatar
Cool
Hi Vinay,
Thanks in advance!
Generally over heating is caused due to the air vents getting blocked by dust. Also it depends on where you use the notebook on. If you are using on the table then it should not get heated up, but when you use in on your lap top there are more chances of notebook getting heated up.
Flashing BIOS is done by downloading the BIOS from the computer manufacturers support site and installing it, by doing this most of the time over heating issue is fixed.
If your computer has some high end graphic card and if you are using some advanced programs, there are possibilities of overheating. Also some when you connect the AC adapter to the notebook when you are working and if it’s kept on the lap then you can feel more heat.
Swiftron.. can add some points if I have missed any.
__________________
Old 3rd July 2008, 04:36   #1059 (permalink)
Swiftron's Avatar
I guess you have summed it all up vinay. There was an instance when a guy found that his laptop was heating up a lot and when an onsite tech went over to inspect he found a lot of dog hair clogging the heatsink and fan assembly. Cleaning up the air vents regularly should help, but be aware not to use vaccum cleaners since they induce static on the computer. Its better to use a can of compressed air.
__________________
Old 3rd July 2008, 12:49   #1060 (permalink)
My 4 year old Compaq laptop heats up a lot. It does not matter whether I keep it on the table or on my lap. In fact the fan makes a lot of whirring sound on continuous running or if I open multiple applications at one time. The RAM is 512 MB but the laptop seems a lot slower. What could be the reason for overheating?
Should I increase the RAM or get the fan checked/cleaned?
__________________
Never let anyone know what you are thinking
nishantgandhi is online now   Reply With Quote
Old 3rd July 2008, 13:26   #1061 (permalink)
Swiftron's Avatar
Is the laptop under warranty? If so then i would definitely tell them to replace the heatsink and the fan assembly. If it is not under warranty take it a local tech shop whom you know can handle the system well and ask him to clean up the insides for you, that should take care of it. You can use a laptop cooler. There are 3rd party applications which lets you take control of the system fan and you can have the fan run oh higher speeds to keep the system cool.
I would suggest a RAM upgrade, atleast 1GB is a must with the kind of applications that we use these days. More over it wouldnt cost much either. And RAM would not cause any sort of heat related issues.
__________________
Old 3rd July 2008, 13:48   #1062 (permalink)
Just now ordered for Dell XPS M1530 Laptop. The configuration is:
- Intel(R) Core(TM)2 Duo Processor T7250 2.0GHz, 2MB Cache, 800 MHz FSB
- Genuine Windows Vista(R) Home Premium 32 bit SP1 Edition (English)
- 15.4" Widescreen WXGA+ (1440x900) TFT Display with TrueLife(TM)
- Midnight Blue LCD display with Integrated 2.0 mega pixel web cam
- 4GB ( 2 X 2048MB ) 667MHz Dual Channel DDR2 SDRAM
- 200GB SATA 7200RPM Performance Hard Drive
- Hard Drive Partition, Primary Size 60GB in C Drive, Remainder in D Drive
- Internal 8X DVD+/-RW Combination Drive with dual layer write capabilities
- 256MB NVIDIA(R) GeForce(R) 8600M GT
- Palmrest with Fingerprint Reader
- Intel(R) 4965AGN Wireless-N Mini-Card
- Integrated Sound Blaster Audigy ADVANCED HD Audio Software
- Dell(TM) Wireless 355 Bluetooth Module
- 9-cell Lithium Ion Primary Battery
- 90W AC Adapter
- 1 Year Priority PC User 24x7 Support (Round-The-Clock Technical Assistance)
- 1-year XPS Premier Service with 1-year CompleteCover
- 8-in-1 media card reader
- Integrated 10/100 Fast Ethernet
- Dell(TM) Travel Remote Control
- Noise Isolation Ear Buds
- External USB modem (WW)
- RJ-11 Modem cable (AP)
Total cost: 73,051.94 INR
Discount (VAT knocked off): 2,809.69 INR
Final price: 70,242.25 INR
Expected time of delivery - 10 days.
Seems like the Dell Employee purchase scheme has been stopped since day before yesterday.
Had initially thought of the T5250 processor (2GHz with 2MB memory & 667Mhz FSB) but then a in-house geek told me that is the old model and take atleast the T7000 (800MHz FSB) series. The best would have been the T9000 series, but $$$!!!
But then I guess the 4GB RAM and the 7200rpm hard disk should help me with the performance.
HappyWheels is offline   Reply With Quote
Old 3rd July 2008, 14:22   #1063 (permalink)
motorheadinc's Avatar
@ Happywheels
Thats one hell of a system you have ordered.
May I know what kind of applications you plan to run on the system.
Cheers and Congratulations
__________________
The Identity awishcar.co.in
If there's not a car to satiate me, I will make one.......
motorheadinc is online now   Reply With Quote
Old 3rd July 2008, 14:50   #1064 (permalink)
jubin's Avatar
hey guys i'm an animator
what laptop what wud u suggest for me ?
money is no issue
i mostly work on MAYA and MAx and couple of editing softwares
currently i've got a HP Laptop Special Designer edition
__________________
Team-Bhp.com: 0-100 in Just one click ! !
jubin is offline   Reply With Quote
Old 3rd July 2008, 16:22   #1065 (permalink)
gopz's Avatar
money is no issue
You will need a good GPU, atleast a 256MB (DDR3) nVIDIA 8600m GT that comes on a Dell XPS 1530
Also get a higher resolution screen (1680 x 1050) and a faster hard drive (200GB 7200RPM or 320GB 5400RPM)
gopz is offline   Reply With Quote
Thread Tools
The Digital Camera Thread: Questions, discussions, etc. satish_appasani Gadgets, Computers & Software 2738 20th August 2008 11:43
The Playstation 2 Thread: Questions, tips, prices etc. Sheruken Gadgets, Computers & Software 278 23rd July 2008 23:49
Help in configs - Gift Laptop Jr Godzilla Gadgets, Computers & Software 3 13th January 2008 10:20
Deals on cars gonna be better this Deepawali? guyonblackybx The Indian Car Scene!! 23 7th November 2007 10:43
Best Baleno deals in Mumbai Boom Shiva The Indian Car Scene!! 3 17th December 2005 17:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
