Old 30th October 2013, 21:17   #241
Thanked: 2,132 Times
Default Re: Google Maps making MapMyIndia (and similar products) obsolete?
Then I typed the persons name into googlemap and up came her exact adress on both map/satelite view. Tried it with several other names. They certainly haven't map all of the Dutch population, but they have certainly mapped more than just celebrities. Who would have thought.
No privacy issues?
I think celebrities would be vocal in their opposition.
Sutripta
Old 30th October 2013, 21:31   #242
Thanked: 6,845 Times
No privacy issues?
Sutripta
No, apparently not. I spoke to her about this and she did investigate but found, essentially there is nothing she could do. In this particular case, the person in question is a well known Dutch writer and she now has fans and lunatics showing up at her doorstep at regular interval.
I checked a few more names, and it is really amazing who shows up. I checked a few and none of these individuals were aware or had asked Google. I mean I can understand if you're running a company you want it to show up on Google map, maybe you would be willing to pay a little.
Jeroen
Jeroen is online now   Reply With Quote
Old 30th October 2013, 21:43   #243
No, apparently not.
Well, I guess Google can get away with it in curtainless Holland.
Sutripta
Old 30th October 2013, 21:57   #244
Sutripta
Good one, but I must admit it probably does hold some truth.
Mind you it is truly amazing what you can find about yourself in public sources or by simply googling your own name.
Jeroen
Old 30th October 2013, 22:07   #245
Careful. You might be introducing your friends to dangerous practice!
I believe it is addictive enough and widespread enough to be given its own name as a disease needing therapy!
Wonder what Calvin's thought would have been regarding Google.
Sutripta
Old 21st December 2013, 19:09   #246
Default Should I repair my MMI device or start using Google Maps ?
Folks,
I had purchased the top end MMI device from Danew with a 5 " screen, Bluetooth and reverse camera for Rs. 17,000 two years back. Last month the touch screen got damaged and the cost to repair it is Rs. 7,000. My questions are:
1) Should I spend the money to repair this device or continue using Google Maps on my smart phone ? Assuming each time I go on a trip, I will spend couple of hundred rupees for data charges for using Google maps, Google maps still works out to be cheaper than spending Rs. 7k in addition to what I already spent for the MMI device.
2) Smaller screens from Garmin or Tomtom without Bluetooth and reverse are available for around Rs. 9k. In case, I decide to go for a GPS unit, should I then buy a new Garmin or Tomtom without bluetooth and reverse camera for Rs. 9k instead of spending Rs. 7k to repair the MMI device ?
Please advice.
Thanks.
Please advice.
golfdude is offline   Reply With Quote
Old 22nd December 2013, 12:10   #247
Thanked: 2,388 Times
Default Re: Should I repair my MMI device or start using Google Maps ?
Originally Posted by golfdude View Post
Folks,
Please advice.
Thanks.
Please advice.
Sygic is free now - and it uses MMI maps. Download the app and the states you are most likely to visit. No restriction on how many you can download - if you wish you can have whole India. These are offline maps, so you don't need a active data connection.
Some more free offline map solutions - OSMAnd, NavFree - both of these use openstreetaps.
While in your home city, you can still use Gmaps with data, on outstation trips any of the above 3 will be good.
Dry Ice is offline   Reply With Quote
Old 22nd December 2013, 12:13   #248
Thilak29's Avatar
Thanked: 355 Times
I personally feel, Smart phone / tablets are way forward and maps like MMI are thing in past. Dont waste your money on repairing.
My experience with Nokia Drive/ Here Drive been exceptionally good.
Thilak29 is online now   Reply With Quote
Old 23rd December 2013, 10:19   #249
IshaanIan's Avatar
Thanked: 3,166 Times
Unless you are the kind who can devote time to updating your maps, and taking care of a seperate device, I suggest sticking to your smartphone. Either way, maps can never be blindly followed at all times and always require a certain amount of alertness and common sense. Google maps has come a long way and while it still might be a little behind MMI or other services, they do not justify their lead over using google maps and the conveniences of having it on your phone that is an integral part of your life
IshaanIan is offline   Reply With Quote
Old 25th June 2014, 15:54   #250
Thanked: 336 Times
Default Are Google Maps losing their credibility?
I have now seen two instances where they do not tell the shortest and best possible route.
Instance one is here: http://www.team-bhp.com/forum/route-...ml#post3453329
And instance 2 is my Amritsar-Manali route query, which it showed me three routes except the most obvious one.
So is it time to hunt for a more reliable alternative?
HyperRetard is offline   Reply With Quote
Old 25th June 2014, 15:58   #251
Raccoon's Avatar
Thanked: 105 Times
Default Re: Are Google Maps losing their credibility?
Routes aside, it has let me down a few times with regards to places/establishments also. For eg. the last time I had to visit a Titan showroom, there was no such showroom where it was marked. And from the look of it, and from my memory, there never was one, anywhere in that area. Waste of time and trip.
I'v learnt not to trust Google maps much. But is there a better alternative?
Old 25th June 2014, 16:47   #252
adarsh.n's Avatar
Thanked: 18 Times
I have had a strange experience. I was using google maps to locate a colleague's house from where I new the route to a place that i was heading to. Once reaching the colleague's house i observe the navigation in google maps suggesting me a wrong direction. The worst part is that it was suggesting the exact opposite direction in which i had to travel. I doubt if it was just a bug!!!
adarsh.n is offline   Reply With Quote
Old 25th June 2014, 18:07   #253
arnabchak's Avatar
Thanked: 1,085 Times
Adarsh, completely agree with you.
I was off to a meeting in Mahalaxmi yesterday and going to the place after a long time, all the directions by Maps were pointing wrongly.
Not only that, for the sake of a check, I decided to do a random check of office to home. There also, there was a deviation which was pretty sad!!
arnabchak is offline   Reply With Quote
Old 26th June 2014, 07:42   #254
F150's Avatar
Thanked: 649 Times
Which version of android are you all using ? Did you all switch the location settings to high accuracy when you were driving to your destinations?
F150 is offline   Reply With Quote
Old 26th June 2014, 08:17   #255
phamilyman's Avatar
Thanked: 3,454 Times
Friends, crap happens but no point being worked up. Other alternatives just don't have as much information at all. It may be a bit crappy but its far better than others!
You can always do a quick google to confirm the address, and then put the address in.
Infact GMaps also returns the phone number of POIs such as showrooms so u can call them before you start. MMI etc just don't have that kinda stuff - e.g bakeries etc.
Google Maps on Mobile sharathjeppu Gadgets, Computers & Software 70 9th May 2016 12:29
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Using Google & Yahoo India Maps on standalone GPS Device Haste Gadgets, Computers & Software 9 30th September 2008 19:59
Google maps mobile 2.0 - poor man's GPS tachobells Gadgets, Computers & Software 4 1st December 2007 11:19
Autocop and such similar products are of limited use! Zappo The Indian Car Scene 21 20th February 2007 20:31
