Old 26th June 2014, 18:46   #286
NetfreakBombay's Avatar
Thanked: 352 Times
Default Re: Google Maps making MapMyIndia (and similar products) obsolete?
Originally Posted by DerAlte View Post
Looks nifty with it's UI, but it is *terrible* at the moment. They have a very limited PoI database (limited to well known businesses), and are unable to return known results that Google Maps would
Yes, all it shows is that there are a lot of legible signboards. That data can result in a good POI DB if combined with image processing systems like the one Google has.
Old 26th June 2014, 21:27   #287
TheTeacher's Avatar
Thanked: 322 Times
Default Re: Are Google Maps losing their credibility?
Unlike first world countries, our road addressing system is highly unscientific.
Many cities in the US will have odd numbered buildings on one side of the street and even numbered buildings on the other. Makes them so much easier to find.
They also number adjacent buildings with gaps of 30 or 40 in the building numbers, so if something comes up in between, the new building gets a number in the middle. No renumbering every few years like India loves to do, "New No. 10, Old No. 33" in the address. I know a chap who's an IAS deputed to the Postal Dept., and he was fascinated with this concept when I explained it to him. This was about 5 years ago, and of course nothing has changed. I know buildings which have been renumbered twice within a few years.
TheTeacher is offline   Reply With Quote
Old 29th June 2014, 19:30   #288
Thanked: 24 Times
With so many gmaps bashers around. did we correct the maps post having the bad experiance. Google realized they did not had good information and had a crowd source event last year called mapathon. unfortunately mapathon had prizes for a number of edits and people just put any marker anywhere nearby (read: not zoming enough to pin point and draw correct boundaries). please goto www.google.com/mapmarker , login with your google account and correct.
the problem for selecting the slip roads over highway is that person who marked the small roads / sliproads forgot to update the type of road. so is a single lane is marked as a 4lane concrete road google will think its worth routing to.
btw, i too had my bad experiances however those are usually last mile routing for which i rely on other GPS called General Public System. mind you sometime its worst than the global positioning system
amit_arya is offline   Reply With Quote
Old 1st July 2014, 11:38   #289
Thanked: 702 Times
Infractions: 0/1 (7)
Looks like MapMyIndia have pulled up their socks and improved their maps. Just back from a short trip in Goa. Had taken a car on rent, and used the MapMyIndia GPS all through the way. Starting from Bogamalo, I could reach the Naval Museum, Dona Paula, Regis Magos Fort and Fort Aguada. ashkamath Team-BHP-ian had suggested a scenic route via the Goa University, and the device was able to plot the route accurately. The device saved our time considerably, as we could just move on quickly rather than taking directions at every road intersection. Especially on our return journey our baby daughter had got visibly upset and had started whining, so reaching back at the base was important. And the device guided us through very accurately.
If maps are getting more and more accurate, I feel devices like MapMyIndia etc. would really catch up. Google Maps may gaining, but I find them very tiresome to use in a small mobile phone. As it is my phone is Samsung Duos whose battery backup is pathetic.
sachinpk is offline   Reply With Quote
Old 27th December 2015, 13:37   #290
petrol_power's Avatar
Thanked: 154 Times
I have been using a Garmin from 2013 and from my experience suggests google maps is faaaar better than the Garmin. When I do a cost analysis, The Garmin device costed me approx 18k in 2013 and I guess a decent Samsung tab will cost only 12k now, insert a SIM and we have google maps in our cars. But like Garmin, this device also will be an extra protruded accessory.
Anyone using a dedicated tab/phone in their cars for using google maps? And if so have you found a solution to neatly integrate it to the car?
petrol_power is offline   Reply With Quote
Old 27th December 2015, 14:51   #291
rajivr1612's Avatar
Thanked: 248 Times
I have installed Navimaps on my Lenovo A6000+. Tried a few mobile holders but was not satisfied. The main problem of windshield mounted holders is that mobile is exposed to sunlight as well as charging cable snaking around.
So I had to find a solution, a jugaad solution.
I have an Etios Liva known for its spartan interiors. The music player is a humble 1-DIN Pioneer unit. The vacant slot below the unit gave an idea. I also had purchased a silicon cover for the mobile earlier which I was not using.
Last Sunday afternoon got about with the work. Items required was some cardboard, mobile cover, glue & cable ties. Used an old piece of black cloth for covering purpose.
I also purchased a USB charging cable from Amazon.in. The brand is Bluerigger. It's a charging only cable and in its coiled form is only 1.5 feet long, hence is clutter free.
I am not covering the step by step process since the work only involved making a box (matching the dimensions of the vacant slot) and attaching the mobile cover to it with cable ties.
The pics below is self explanatory:-
The mobile cover attached to box using cable ties. Looks ugly for sure. But does the job well. The box is a tight fit with all degrees of freedom well arrested.
Unfortunately this jugaad will be useful for folks having similar vacant slots. Newer cars do have factory fitted music systems in it's place.
Thanks for reading.
rajivr1612 is offline   Reply With Quote
Old 27th December 2015, 16:39   #292
Thanked: 154 Times
Thanks for reading.
This is good, , neatly done and very functional. Thanks for sharing the same.
Mine is a Polo having a double din set, in which there is no vacant slot available. Now since there is off line maps also possible with google maps, its high time that we should find such solutions to get a functional google map in car.
There are android head units, but first of all it will cost 30k min. plus no sim card slot for it, we have to connect via wifi using another mobile.
Old 28th December 2015, 18:02   #293
TheTeacher's Avatar
Thanked: 322 Times
Very interesting, thanks for posting! Curious, though, if the device is where you have positioned it, will it pick up signals from multiple GPS satellites as required? Always wondered about this.
Old 28th December 2015, 18:47   #294
rajivr1612's Avatar
Thanked: 248 Times
Thanks. Yeah, not had any issues so far with GPS lock. Have made multiple trips within Chennai with this setup and found that it works flawlessly.
Old 24th April 2016, 11:13   #295
Thanked: 249 Times
I just bought a mapmyindia device and realized it doesn't have any Bhutan maps. The interface is very difficult to use, and it also doesn't show the entire route. Can I download Bhutan map to my device?
Oreen is offline   Reply With Quote
Old 25th April 2016, 10:15   #296
Thanked: 702 Times
As per their web site, they do not seem to have Bhutan maps at all.
http://www.mapmyindia.com/navigator/...rnational-maps
Old 5th July 2016, 14:36   #297
ampere's Avatar
Thanked: 8,759 Times
So finally multiple destination feature has made to mobile version of Google; a long wanted feature. Just saw this news piece
http://www.pc-tablet.co.in/google-ma...feature/35260/
Google Maps on Mobile sharathjeppu Gadgets, Computers & Software 70 9th May 2016 12:29
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Using Google & Yahoo India Maps on standalone GPS Device Haste Gadgets, Computers & Software 9 30th September 2008 19:59
Google maps mobile 2.0 - poor man's GPS tachobells Gadgets, Computers & Software 4 1st December 2007 11:19
Autocop and such similar products are of limited use! Zappo The Indian Car Scene 21 20th February 2007 20:31
