Old 13th April 2009, 10:09   #16
Thanked: 294 Times
Samuri try contacting Sam Bhai or Ajay Bhai for the same..they will hook you up..
And if possible try sourcing Belden. Our fellow BHPIAN Harsh87 used the same for his house. He might give you some contacts.
Old 13th April 2009, 11:21   #17
sk456's Avatar
Thanked: 7 Times
Kimber would be another excellent cable choice. A2V ( i guess its at Juhu in Bombay ) deals with Kimber. QED.Chord are other brands available in India. All excellent cables/IC's. Although Kimber Is my personal favourite and what I use . Reasonably priced and excellent VFM IMO.
sk456 is offline   Reply With Quote
Old 13th April 2009, 11:35   #18
karankapoor's Avatar
sk what are the prices for different size kimber/chord cable in India
karankapoor is offline   Reply With Quote
Old 13th April 2009, 11:39   #19
Bass&Trouble's Avatar
Thanked: 71 Times
What are the common HT speaker wire makes with decent performance and available in most electonics shops in India?
I can't try for the best brand of cable because I don't live near any cities. My house in under renovation, the painter is waiting to start his work, but I need to finish the cabling first. So, I don't have much time on hand.
The most common speaker wires available in India are unfortunately, the worst. Please don't buy speaker cable from electrical shops. They sell very pathetic cables.
A good VFM speaker cable option that will work with even upto mid-end HT setups, is a Chinese brand called Showa. I think it costs about Rs. 55-60 per meter for 16 AWG and is totally worth the price.
Old 13th April 2009, 11:50   #20
sk456's Avatar
Thanked: 7 Times
I dont know Chord prices off hand.. but Kimber varies from 155/running ft ( 4 PR) to 1000/running ft ( 8TC) for speaker cables depending on speaker gauge and quality. Interconnects are from 4000/meter ( Tonik 1 mtr ) to 24000/mtr for the SSE 147 i Mtr. Pretty nice cables for the money.
Prices could be higher now due to currency hikes . These are about 1 yr old prices.
Chord should be similarly priced +-10-20%
IF one is on a budget he could compromise on cheaper speaker cables but I would not compromise on Interconnects . Try going for a good brand ( definetly avoid out of the box interconnects which are available free from shops ).
Old 13th April 2009, 12:50   #21
Samurai's Avatar
Thanked: 14,538 Times
Yikes, my budget is not above 200bucks a meter.
IF one is on a budget he could compromise on cheaper speaker cables but I would not compromise on Interconnects.
I already have both optical and coaxial interconnects from acoustic research.
That eliminates the local option I guess.
Old 13th April 2009, 13:19   #22
navin's Avatar
Thanked: 3,924 Times
Originally Posted by low_bass_makker View Post
Samuri try contacting Sam Bhai or Ajay Bhai for the same..they will hook you up...
Samu, Get the Sommer cable. It sells for about 150-160/meter. I think the list price is 190/meter. I use it for all my long distance less critical applications (my sister's HT - KEF KHT3005 is wired with this).
"Sam Bhai's" company sells vdH. I dont think vdH is in your price range unless you get some very nice discounts.
Another option is Belden's PureAV Silver Series but I dont know anyone in India who stock it yet.
Old 13th April 2009, 13:24   #23
Samurai's Avatar
Thanks Navin, I think Sommer should do fine, it fits nicely into my budget. Since I am no audiophile, mine can be considered non-critical setup.
Old 13th April 2009, 13:50   #24
Thanked: 71 Times
For his equipment, Sommer's entry level speaker cable which is in the range of about Rs. 100/- a meter will also suffice.
Or he could get something like Supra for the fronts and center and run cheaper cable to the surrounds. vdH, Chord etc are too high end for the application.
Old 13th April 2009, 16:02   #25
shuvc's Avatar
Thanked: 283 Times
How about DAC? Do they make decent cables for entry level applications?
Designer Audio - Products
As of late last year entry level speaker wires prices:
12 gauge was around Rs. 102/m
14 gauge was around Rs. 76/m
16 gauge was around Rs. 46/m
Interconnects around Rs. 800-1300
You could mail them, ask for a price list and order.
Old 13th April 2009, 16:22   #26
navin's Avatar
Actually I found the entry level cable a bit thin. For longer runs I'd prefer a heavier gauge.
Old 13th April 2009, 18:33   #27
Samurai's Avatar
I have decided to go with Showa cable. It is 16 AWG, i.e. 1.3 sq. mm. It is pure OFC copper, not CCAW. And corrosion resistant.
Old 13th April 2009, 21:29   #28
What is CCAW and how does it differ from OFC?
I am doubtful whether the word "resistant" really means anything at all (generally speaking, nothing specific to cables)
santosh.s is offline   Reply With Quote
Old 13th April 2009, 22:33   #29
i am not sure but but : ccaw wires are bit different from OFC,ofc wires are made of pure copper and ccaw wire are made of alminium with copper coating on them.
may be i am wrong guru can help.
Old 13th April 2009, 23:40   #30
Thanked: 294 Times
Quite close but the copper is not coated it is cladded.
Cladding - Wikipedia, the free encyclopedia
Copper-clad aluminum wire - Wikipedia, the free encyclopedia
Designing a Home Theatre System Samurai Gadgets, Computers & Software 47 26th February 2014 12:56
good rca and speaker wiring makanaka In-Car Entertainment 2 15th August 2008 19:22
Good RCA Wires low_bass_makker In-Car Entertainment 42 10th June 2006 23:37
Locally available HT speaker wires Samurai Gadgets, Computers & Software 4 26th April 2006 13:45
