Old 14th April 2009, 00:12   #31
karankapoor's Avatar
almost the same but used the wrong word to describe.would have googled it.
Copper-clad Aluminum Wires (CCAW, HCCAW, UCCAW) | Special Magnet Wires | Magnet Wires | Products | TOTOKU
karankapoor is offline   Reply With Quote
Old 14th April 2009, 01:10   #32
Thanked: 295 Times
I did not get you here. What are you saying ?
Old 14th April 2009, 10:57   #33
i used the wrong word coated.
Old 14th April 2009, 14:13   #34
Bass&Trouble's Avatar
Thanked: 74 Times
Originally Posted by santosh.s View Post
I am doubtful whether the word "resistant" really means anything at all (generally speaking, nothing specific to cables)
It does from the point of view that:
1. There is a jacket
2. The jacket is impervious to outside air
3. Jacket is flexible and will serve for the application without developing cracks or faults over a period of time, which could thus allow air and/ or moisture in and cause the conductor to corrode.
As such, there is no "corrosion-proof" copper, obviously. New element would have to be invented.
It is recommended that further corrosion-resistant precautions be taken when terminating the wire ends to ensure that the wire remains corrosion free for a long time in service.
Old 14th April 2009, 15:46   #35
Like applying solder on bare conductor ends (tinning) and sealing with heat sleeves before making connections, right? I plan to do that for my ICE installation.
santosh.s is offline   Reply With Quote
Old 14th April 2009, 16:10   #36
Samurai's Avatar
Thanked: 15,927 Times
How does one ensure that? My AV Receiver has screw type connectors which doesn't allow for any banana plug.
This is my AVR: Yamaha RX-V1400 7-Channel Receiver
Look at the back-side.
Old 14th April 2009, 16:15   #37
Sam Kapasi's Avatar
Thanked: 1,474 Times
Attachment 125082
Samu!!
The banana plug fits in there perfectlySpeaker Wires and RCA for Home Theatre-avr.jpg.
Old 14th April 2009, 16:37   #38
Samurai's Avatar
Been there, tried that. I bought 14 high quality gold plated banana plugs 5 years believing exactly that. It didn't fit, and the shop didn't take it back. Total waste.
Old 14th April 2009, 16:48   #39
Sam Kapasi's Avatar
You bought the wrong plugs. Guaranteed. The sizes of the terminals are standardized. Or you're putting it in the wrong hole, lol.
I'll wait for Ajay to come by and make a ripe/unripe banana joke.
Old 14th April 2009, 16:54   #40
Thanked: 74 Times
There should be small plastic caps on the speaker terminals where the banana is to be shoved in. Did you remove those?
And do the banana pins you use have some sort of springy mechanism running along their length? If yes, pushing a bit harder could help.
If its still tight, maybe you could use spades. But I dont know where one can buy inexpensive spades.
Do use heat shrink tubing at the joints of the termination and cable jacket.
Old 14th April 2009, 16:55   #41
navin's Avatar
Thanked: 4,345 Times
Sam has marked the right hole in green.
navin is online now   Reply With Quote
Old 14th April 2009, 16:56   #42
Samurai's Avatar
The shop I bought them from had only one size, and that was in Bangalore. I don't suppose I can get the right size locally.
Old 14th April 2009, 16:58   #43
Thanked: 295 Times
Sorry guys but could not stop myself.
Old 14th April 2009, 17:02   #44
Samurai's Avatar
Navin, I am not a total noob when it comes to electronics, I once got a degree in it.
Since I couldn't find the banana plug that fits, I gave up on it, that was 5 years back.
Old 14th April 2009, 17:03   #45
A question here. Would one require In Wall Speaker wires if the wires are going to be concealed?
Best regards
Deepu
deepug is offline   Reply With Quote
Designing a Home Theatre System Samurai Gadgets, Computers & Software 47 26th February 2014 12:56
good rca and speaker wiring makanaka In-Car Entertainment 2 15th August 2008 19:22
Good RCA Wires low_bass_makker In-Car Entertainment 42 10th June 2006 23:37
Locally available HT speaker wires Samurai Gadgets, Computers & Software 4 26th April 2006 13:45
