Old 6th June 2006, 14:10   #1
khanak's Avatar
Thanked: 128 Times
Default HELP needed for o2 mini
i have an o2 mini and have a small problem with it. the signal indicator which is a green light and is supposed to be blinking is now continous. i tried resetting the device but it hasnt helped......can someone please help me.
khanak is offline   Reply With Quote
Old 6th June 2006, 14:14   #2
satish_appasani's Avatar
Thanked: 45 Times
Do a hard reset. You might have done a soft reset. If it's not fixed, then it's an hardware issue.
Remember to have a backup before hard reset.
satish_appasani is offline   Reply With Quote
Old 6th June 2006, 16:13   #3
khanak's Avatar
Thanked: 128 Times
how do u do a hard reset
i pressed the reset button and the power button
Old 6th June 2006, 17:14   #4
captainsokhi's Avatar
try this:
To do a hard reset tap START = SETTINGS = SYSTEM = CLEAR STORAGE
then follow the onscreen instructions
If your phone becomes unstable and will not start up past the bootscreen and you are not able to do the above step, you can do this
PRESS AND HOLD BOTH THE COM MANAGER AND VOICE DIAL BUTTONS AND PRESS THE RESET BUTTON WITH THE STYLUS
captainsokhi is offline   Reply With Quote
Old 6th June 2006, 17:19   #5
khanak's Avatar
Thanked: 128 Times
how do i do a hard reset?
Old 6th June 2006, 17:24   #6
Thanked: 1,503 Times
1. Do a FULL backup to either your SD Card or to your PC.
2. Do soft reset while holding the power button down.
Warning: You will lose all your data and will have to reconfigure your device entirely if you dont do a backup.
I doubt if a hard reset would do the trick as it sounds like a hardware issue. However, it doesnt cost anything so why not give it a shot?
Steeroid is offline   Reply With Quote
Old 6th June 2006, 17:25   #7
try this:
Old 15th June 2006, 03:02   #8
Sounds like a Hardware problem but might also be a software error just HOLD the soft reset key ( the one you put the stylus in) and the power button and hold them both for 10 Secs after which ure o2 will change to the default sealed straight ( however beware all dad on the mini not the storage card is lost ) and captainsokhi what u r talking about is for the latest O2s which support windows 5.0 ( like mine and atom).
irulee is offline   Reply With Quote
Old 15th June 2006, 09:35   #9
killjoy's Avatar
Thanked: 180 Times
there is a new ROM upgrade on the official site, download and install it, all problems solved.
killjoy is offline   Reply With Quote
Old 15th June 2006, 12:00   #10
khanak's Avatar
Thanked: 128 Times
i dont have access to any rom upgrades cos my phones bought from the grey market.
Old 15th June 2006, 15:34   #11
ksethuram's Avatar
khanak, you can register all phones in O2 site, even the one purchased in greymarkets. login to www.seeo2.com , register and get it downloaded. You will just need the IMEI number.
ksethuram is offline   Reply With Quote
Old 15th June 2006, 23:38   #12
killjoy's Avatar
Thanked: 180 Times
yes true and if you still cant get it, give me your mail id and i will mail it to you.
Old 16th June 2006, 11:43   #13
For all your ROM requirements, go to the xda-developers FTP site . You need to know the HTC model name for your device, and since you have an O2 mini, that would be 'Magician'.
ROM dumps for the Magician (from VARIOUS brands - O2, iMate, Qtek, T-Mobile MDA, etc) are available HERE
You'll find an assortment of ROMs here. Take your choice. If you're unsure about what you're about to do, search www.xda-developers.com for help - there's plenty there.
Old 17th June 2006, 11:22   #14
navin's Avatar
Thanked: 3,924 Times
What is the HTC code for the Atom?
navin is online now   Reply With Quote
Old 17th June 2006, 12:17   #15
The Atom is not an HTC device. It was made by Quanta. You will find Atom dumps as 'Atom' under the FTP listing.
1st ever Mini meet in Calicut. Post here for all future Calicut mini meets.. MaserQ The Team-BHP Meet Section 17 8th August 2017 04:32
Mini Cooper S and Mini Convertible : Driven suhaas307 Test-Drives & Initial Ownership Reports 62 24th October 2016 15:17
New Mini "Mini/ Minor" CARDEEP The International Automotive Scene 0 17th July 2010 10:46
Help Regarding O2 XDA Mini II nikibusa Gadgets, Computers & Software 11 28th December 2006 17:23
