Old 27th June 2016, 16:12   #31
sagarpadaki's Avatar
Thanked: 1,337 Times
Default Re: Remote CCTV viewing
NVRs don't always have POE ports. The NVR I bought has just one ethernet port to connect to the network. I use a separate POE switch to drive the IP cameras, in the last mile run. For example, the closest RJ45 jack for the remotest IP camera is at the guard room. So I a placed the POE injector at the guard room. NVR with POE ports assumes you can reach every camera within reasonable distance.
The max length is dictated by the Ethernet specs. About 100 meters is the practical limit.
Thank you. Few more doubts
1.If NVR has one single I/P from the switch, how can it identify each camera individually?
2. So the number of cameras that one can install is dependent on the number of Ethernet ports on the switch?
3. Can the Ethernet port on the Switch provide enough juice to power up the camera?
sagarpadaki is online now   Reply With Quote
Old 27th June 2016, 16:52   #32
Samurai's Avatar
Thanked: 15,769 Times
Each IP camera has its own IP address. Cameras can be powered via POE switches.
DIY: Adding a Remote level control/ Bass remote to your Amplifier HimuraKenshin In-Car Entertainment 8 11th April 2012 16:59
F1 viewing in Ahmedabad redrage Shifting gears 6 19th September 2006 07:08
Need help in importing and viewing videos on Ipod 30Gb Video S@~+#0$# Gadgets, Computers & Software 9 27th August 2006 11:23
image viewing problem in I.E a4_attitude Shifting gears 11 20th January 2006 14:14
