Old 29th December 2010, 00:50   #451
dhanushs's Avatar
Thanked: 4,504 Times
Default Re: The DATA Card and USB Modem discussion thread (Reliance/Airtel/Tata)
Originally Posted by akshay1234 View Post
Just saw the ad today. I think ill get it by next week. 21mbps seems really, really good. Will keep you updated.
21mbps should be the max speed of the equipment. The real speed should depend upon the network. I guess its 7mbps. Not sure.
Old 29th December 2010, 01:20   #452
Akshay1234's Avatar
Thanked: 7,242 Times
Well they offer 3 different types of plans, for 3.2, 7.2 and 21mbps. I guess if they are charging for 21 then it will certainly be faster than 7. Anyway will try and get a trial from Docomo and update here on the speed.
Old 29th December 2010, 01:23   #453
khoj's Avatar
Thanked: 1,258 Times
Do not fall for their adverts blindly. Even Docomo has TATA written before it.
Old 29th December 2010, 01:25   #454
Akshay1234's Avatar
Well im using Photon + and im getting a download speed of 230+ kbps usually. Thats pretty quick. And my dad is in the Tata's, if we dont like it well return it.
Check it -
Old 29th December 2010, 02:06   #455
khoj's Avatar
Hello, my just found, newest, bestest friend can you get your Daddy to get some one to get my photon+ connection mended
Old 29th December 2010, 03:26   #456
dhanushs's Avatar
Yes, do keep us updated.
I'm sure you're having a lot more TATA's in your daily life. Starting from the morning tea.
Old 1st March 2011, 00:17   #457
recshenoy's Avatar
Thanked: 104 Times
bought a photon plus from my colleague. it worked decently at my office premise (E-city BLR) but now when i try at home its pathetic.
look at the speed they offer :( very bad. i feel as if i am in stone age. the dial up used to be faster than this
Download Speed: 81 kbps (10.1 KB/sec transfer rate)
Upload Speed: 122 kbps (15.3 KB/sec transfer rate)
Tuesday, March 01, 2011 12:05:03 AM
recshenoy is offline   Reply With Quote
Old 1st March 2011, 09:34   #458
abdriver2000's Avatar
Thanked: 24 Times
Whats the cheapest deal one can get? I am planning to provide a connection at my inlaws and the monthly downloads wont exceed 500MB. I am looking for speed of 1mbps
abdriver2000 is offline   Reply With Quote
Old 2nd March 2011, 02:03   #459
khoj's Avatar
Well I am not a tea person but I do have TataSky
It seems someone reported my above post to the powers that be in TataTele and things started to move. I had a flurry of calls and lo and behold one fine day a guy landed up with a replacement USB stick. Well the new one came with a microscopic crack but it also brought with it much much better speed and stable connection. I am now and waiting for them to come forth and keep their promise of adjusting my bills for all those months when I was paying for Photon+ but the connection was permanently stuck on Whiz.
@abdriver2000
If this is in Bombay, look no further than You telecom. I have found their connection to be the fastest, most stable and very competitively priced. The only other company that does better is our very own MTNL.
@recshenoy
Check what signals you are getting Whiz or Sky.
Old 5th March 2011, 12:31   #460
recshenoy's Avatar
Thanked: 104 Times
Hi Khoj,
I had checked signal type. some times its photon+ some times whiz. today i am at my native (mangalore) here its working very well. at my office it works very well but my home which is 3 kms from office, its pretty slow :(
Old 6th March 2011, 03:42   #461
khoj's Avatar
@recshenoy,
If you have a photon + connection that is the service you should get and not Photon+ / Whiz.
In your dialer window see bottom right hand, there is a logo of a gear wheel and it reads 'settings'. Click on that and in the sub menu click on network. You will get a window which gives the options of Photon+ only, Hybrid (+ and Whiz) and Whiz only. Select Photon + Only and click Apply, click OK and exit the settings.
This will ensure that your device will catch only photon + signals. If you have problems connecting etc in this mode, then it is definitely time for you to get your USB stick replaced by the company.
Old 7th March 2011, 16:23   #462
recshenoy's Avatar
Thanked: 104 Times
Thanks Khoj, Yes had done that last week. Once i did that my photon plus signal went to ZERO and only when i changed back to HYBRID, some times whiz some times Photon came up.
Today morning after returning from native, tried using the device. it worked decently on photon plus signal. let metry again in the evening before calling customer care
Old 25th March 2011, 16:19   #463
nishantgandhi's Avatar
Thanked: 151 Times
Guys - I'm in the market for a USB mobile internet / data card.
However, I need some plan with unlimited downloads and with no FUP. I'm fine with 512 kbps speed. This data card will be for home/personal usage (i.e. music+movie downloads via torrents).
I was previously using MTNL Triband (over WiFi) and was paying Rs 999 for a 1 MBPS Unlimited (without FUP).
So the data card needs to be as close a replacement as possible.
nishantgandhi is offline   Reply With Quote
Old 26th March 2011, 01:24   #464
khoj's Avatar
Exactly what was happening with my stick. You too need your USB stick to be changed. Tell them you are a regular paying connection and got the connection coz of the TATA name and blah blah In my case it worked, actually that isthe truth too. Between the Reliance and TATA brands it was easy to make the choice.
Now as I said before the connection is a snap and speeds very good. Claims 3.1 Mbps every time I connect but the speed check test does not run any more.
Old 5th April 2011, 17:11   #465
Mr.Boss's Avatar
Thanked: 2,541 Times
Anybody using Idea Data Card in Tamil Nadu (more specific in Chennai / Coimbatore)
What is the speed you are getting?
I am getting around 30~40kbps download speed.
Mr.Boss is offline   Reply With Quote
Reliance Broadband on Data Card !! emkay456 Gadgets, Computers & Software 2 12th March 2009 13:54
Reliance data card goes kaput ! Help needed emkay456 Gadgets, Computers & Software 10 6th January 2009 15:29
Anyone tried connecting both USB and ethernet interface to Beetel 220 modem ? joecherian Gadgets, Computers & Software 6 14th August 2008 19:40
Found a Tata Indicom USB Modem. How do I use it? Dippy Gadgets, Computers & Software 21 7th December 2007 11:38
