Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 1st April 2008, 14:01   #91 (permalink)
Transfer rates on any data card is not that satisfactory. Only reason to use data card instead of wired broadband should be portability of data card.
sukiwa is offline   Reply With Quote
Old 1st April 2008, 14:55   #92 (permalink)
phamilyman's Avatar
use wifi in home, and subsist on data card outside. There is no solution.
Reliance USB modem tho did give some truly amajhing speeds recently in BLR 'burbs. YMMV
/tata indicom user here
Old 1st April 2008, 15:02   #93 (permalink)
Understood. Looking for the better of the lot.
BH
BurningHeart is offline   Reply With Quote
Old 1st April 2008, 15:13   #94 (permalink)
spadival's Avatar
Try BSNL EVDO. I believe EVDO service has already started in TVM. It will be much faster than Tata Indicom and Reliance put together.
This site has some reviews -> BSNL EVDO - UnOfficial Portal
spadival is offline   Reply With Quote
Old 1st April 2008, 16:28   #95 (permalink)
NetfreakBombay's Avatar
Yes EVDO is best in terms of speed (1 or 2 mbps claimed, 500 - 700 kbps actual).
Second is any GSM (EDGE + GPRS) based data card (Airtel, BSNL, MTNL etc). It can support max ~200 kbps, actual speed would be ~50 kbps.
CDMA based data cards (reliance-CDMA, TATA) are worst. Since max possible speed is ~140 kbps and actual speed would be ~30 kbps.
Reason of abysmal speed is due to poor spectrum available to telecom operators. Since voice traffic gets higher priority over data, wireless cards can give you full speeds only when call traffic is very low on network.
Old 2nd April 2008, 08:33   #96 (permalink)
Yes, I had called them up last afternoon. They seemed least bit interested in making a sale. I think I have to go in person to get this moving.
Thanks NFreak. Very useful to know this.
Old 2nd April 2008, 13:37   #97 (permalink)
Originally Posted by kuttapan View Post
There should not be much of a difference in speed between USB and PCMCIA from Tata Indicom. I chose the PCMCIA for the reasons carboy mentioned + it has an external antenna(better reception where the signal is weak).
Does this PCMCIA card works out of Bangalore? I'm looking for a way to access my mails and office intranet while I'm on the move and have no access to a broadband accent point.
Rex
rex_varghese is offline   Reply With Quote
Old 2nd April 2008, 13:57   #98 (permalink)
Originally Posted by BurningHeart View Post
Need to work from home (in Trivandrum) for the next four months. Looking for a data card with good xfer rates.
Have a home broad band from Asianet Data Services already. But I would like a data card for my laptop (to keep the personal and professional lives separate!!) as it gives me flexibility to move about.
Reliance would have been my choice. But after reading mouthshut reviews on Reliance and Airtel, both seem to be offering dismal performance.
Has anyone here used/bought a data card in the past? What do you recommend?
BH.
I use Reliance (CDMA 1x) and AirTel (GPRS/EDGE) when in India. I find Reliance speeds to be consistently better than those of AirTel. In any case CDMA (1x or 2x) speeds will always be higher than those of GPRS/EDGE based networks. 3G/HSDPA is another matter altogether.
EVDO from BSNL will also be some flavour of CDMA 1x or 2x so it cant be very different from Reliance except that their network may initially be less congested and may therefore show better speeds.
__________________
It is no measure of health to be well adjusted to a profoundly sick society.
- J Krishnamurti
Steeroid is offline   Reply With Quote
Old 2nd April 2008, 14:10   #99 (permalink)
redfire's Avatar
All,
I am working from home in trivandrum for the next two months. Looking for a data card to stay in touch with the project team abroad. Has anyone bought/used a good data card? What do you recommend?
BH.
BH - Airtel, TATA and Reliance provide Data cards / USB modems, cost 3-3.5K. I found reliance slightly better in terms of network coverage and connectivity. I am using one when I am in transit, and most of my friends in IT industry are using reliance. But none of these have speed to keep a VPN connection stable and work smoothly, if that is your purpose, though they are not bad for browsing. If you need net access for extensive support (like VPN, FTP, some remote desktop /session, etc) I would advice you to go for a Asianet cable / BSNL broadband. Asianet has some temporary connection schemes like renting a modem so that you dont have to own which will be a waste when you return.
EDIT: Sorry I have not read your mail fully. So you already have Asianet BBand and looking for a datacard only, then reliance is better.
__________________
jay
It’s really quite a simple choice: Life, death or Los Angeles
redfire is offline   Reply With Quote
Old 2nd April 2008, 14:21   #100 (permalink)
CDMA 1x has a max capacity of 144 kbps (as deployed in India by Reliance/BSNL/MTNL/TATA Indicom)
While GPRS has max capacity of 296 kbps if phone/modem supports EDGE (Class 32).
Its possible that you got better speeds on CDMA but that would be if Airtal did not have good network in that area.
I am using MTNL's EDGE connection in Mumbai and speeds at ~90 kbps during day and ~180 kbps early mornings / late night.
GPRS plans are cheaper as well if you buy a SIM from MTNL (400 Rs per month for unlimited usage)
Welcome to MTNL VAS
Old 2nd April 2008, 14:31   #101 (permalink)
The GPRS/EDGE speeds you are talking about are the theoretical max rates. Actual data transfer rates are slower on GSM Packet Data Transfer than on CDMA - this has more to do with the carrier service (GSM/CDMA) than with the technology (GPRS/EDGE/EVDO) itself. The difference between theoretical and real-time data rates is much higher on GSM, basically because GSM is Time Division multiplexing.
Therefore the observation that:
Is not true in real life. Reliance/Tata Indicom/BSNL/MTNL will always be faster, until 3G arrives in India.
Welcome to MTNL VAS
I use AirTel unlimited - Rs.1,500 per year. Thats about Rs.125 per month even though I pay upfront.
__________________
- J Krishnamurti
Old 2nd April 2008, 14:40   #102 (permalink)
spadival's Avatar
Yeah.. I wonder why they spend so much money hiring Priety Zinta and all, if they dont bother to sell their products.
EVDO is a 3G technology and is much faster than any CDMA 1x network, Reliance included. Speeds can go as high as 2 mbps, which isnt technically possible with a CDMA 1x network or with GSM EDGE.
Only drawback is BSNL hasn't implemented EVDO all over the country, just a few cities for now. Either way, you will be able to access BSNL's CDMA 1x network with the same EVDO card. But, there is very little info on coverage and even lesser support from BSNL folks for those who want to buy this product !!
Old 2nd April 2008, 14:42   #103 (permalink)
Use EVDO if possible. It operates on a separate data only frequency carrier and does not have the voice component.
srishiva is offline   Reply With Quote
Old 2nd April 2008, 15:00   #104 (permalink)
EVDO is a CDMA2000 standard. 3G is a GSM standard.
However, some flavours of 3G do use EVDO (N America) while most others use WCDMA (most of the GSM world) or TD-CDMA (the chinese, mostly). EVDO is mostly used by the North American operators in 3G implementations as North America has been the stronghold of CDMA.
However, EVDO is ALSO a standalone CDMA standard unlike WCDMA which is 3G (CDMA over GSM). This is why you do not need a 3G license in India (none issued yet) to provide EVDO. A proper 3G implementation will require 3G licenses (and spectrum) and it is very likely that India will go the WCDMA way and not EVDO or TD-CDMA.
Yes you will have better speeds with an EVDO only network, but how feasible is it to roll-out a data-only network without Voice Support? Voice is the bread and butter for a wireless operator - data is still very much on the luxury list. Therefore your EVDO-only network is also likely to be very localized - you stand a better chance of remaining connected with CDMA 1x if you're travelling around.
All this is until 3G truly arrives. Then you have the best of both worlds - availability and speed in one shot.
__________________
- J Krishnamurti
Old 2nd April 2008, 15:09   #105 (permalink)
spadival's Avatar
Slight correction there - CDM2000 is a hybrid 2.5/3G standard (according to wiki). 2.5G part of this is the CDMA 1x standard and 3G part of it is the EVDO standard. So you can have broadband speeds where EVDO is available and CDMA 1x speeds where its not. So you get the benefit of broadband speeds without losing out on wider coverage that CDMA 1x networks offer.
However, If I were a business user, I would opt for the reliablity of Reliance 1x over BSNL's EVDO/1x. You never know when you will be left in the lurch with BSNL.
Thread Tools
Reliance Broadband on Data Card !! emkay456 Gadgets, Computers & Software 2 12th March 2009 14:54
Reliance data card goes kaput ! Help needed emkay456 Gadgets, Computers & Software 10 6th January 2009 15:29
Anyone tried connecting both USB and ethernet interface to Beetel 220 modem ? joecherian Gadgets, Computers & Software 6 14th August 2008 20:40
Found a Tata Indicom USB Modem. How do I use it? Dippy Gadgets, Computers & Software 21 7th December 2007 11:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
