Old 5th January 2007, 12:51   #151
Thanked: 91,591 Times
Got Tata-Sky installed in my room and hooked up to the entertainment system. BIG PROBLEM : The pic quality is too blurry....so bad in fact that it leads to an eye sore. Literally.
I switched back to regular tv and things were fine. But the Tata Sky reception is harsh on the eyes. Are there any settings / fine tuning etc. that I am missing out on?
Old 5th January 2007, 12:56   #152
Samurai's Avatar
Thanked: 14,524 Times
All channels or some channels? I have viewed Tata Sky on both 100Hz Flat TV as well as Plasma. Looks Great! May be setup issue.
Old 5th January 2007, 13:02   #153
Vid6639's Avatar
Thanked: 19,549 Times
Which TV GTO? Is it an LCD or plasma or normal CRT.
Old 5th January 2007, 13:07   #154
@Samurai : All channels.
@Vid...: Sony 32" LCD
Old 5th January 2007, 13:26   #155
tsk1979's Avatar
Thanked: 15,683 Times
@GTO, are you getting the same problem with high action DVDs too? If thats the case the problem is your TV settings, contact service center after tweaking sharpness etc.,
Make sure you connect your DVD player to same AV input used by your STB.
This is a known problem with LCDs in case of Analog input when the scene has horizontal movement with vertical fixtures like buildings etc.,
Since Tata SKY STB does not have a digital out, analog connection is your only way of hooking and to verify its not a TV issue but Tata SKY one you have to connect a DVD player by the same connection point.
Old 5th January 2007, 13:43   #156
sk456's Avatar
Thanked: 7 Times
Originally Posted by esteem_lover View Post
sk456. are you using dish or tata ?
on the contrary things will look even brighter this year. i heard trai has proposed to do away with the boquet systems & let customer choose the channels at a minimum price per channel
Im using Tatasky...
IF one can choose on a per channel basis then i guess it should not be that bad..
sk456 is offline   Reply With Quote
Old 5th January 2007, 13:56   #157
esteem_lover's Avatar
Thanked: 447 Times
@GTO . what is the response time of your LCD. you might want to read this.
http://www.team-bhp.com/forum/gadget...-lcd-tv-5.html
when did you buy your LCD ? f you can, check the signal strength in your STB.
@tsk1979.... dvds will look absolutely fine, i am sure. All STBs are analogue. we still dont have digital STBs. but i think gto is getting weak signals from the dish too. i
Old 5th January 2007, 14:16   #158
w 12's Avatar
Thanked: 26 Times
GTO,
Check the signal strength to your STB.
press 'organiser' button on tata sky remote and then select signal strength.
you should see 2 bars, signal strength and signal quality , ideally at more than 80 %.
if not , then either the dish is out of alignment or some problem with dish hardware.. call to their helpline should solve it.
w 12 is offline   Reply With Quote
Old 5th January 2007, 14:52   #159
@TSK : Will do as you asked and update.
@Esteem Lover & W12 : Thats the first thing I checked. It was about 75 - 80%.
Old 5th January 2007, 15:08   #160
Thanked: 447 Times
75-80 is good enough in dish Tv for most channels. i dont know about sky.
Old 5th January 2007, 15:18   #161
tsk1979's Avatar
@esteem_lover, DVDs will look fine as long as they are connected to S-Video or Digital in. Many LCDs have problem handling Analog input. This is esp true for older models.
Old 5th January 2007, 15:48   #162
Thanked: 447 Times
Yeah, you are right. but even in the normal RCA inputs, the strength of the DVD players' signal is such that it will look great even in the older LCDs if their response time is decent.
Old 5th January 2007, 15:57   #163
tsk1979's Avatar
Signal strength is one issue. I am not sure but there are some refresh rate issues for Analog connections. The reason is due to double conversion
Digital(DVD) - Analog(TV in) - Digital. This double conversion brings in quantization related errors if the TV companies have compromised on their signal processing hardware.
Older TVs had this problem due to cost issues, and it was a classic case of "Penny wise Pound foolish". Saving a few dollars on a 2000$ system(costs then).
Old 5th January 2007, 20:44   #164
krazykul's Avatar
hey, Am little late here givin my comments but i am fully satisfied with the services of DTH. i have a Dish TV connection for quite a long time and am fully satisfied with it.
Some advantages i feel are
1) Hve complete control over my connection unlike the cable provided by cable providers. Main issue
2) Picture and sound clarity cannot be compared with normal cable.
3) Regarding more than one TV in a house i believe they will give packages where you can have more that one STBs for a nominal price, instead of buying independent STBs and Card. I think Tata Sky has that facility but Dish TV hasn't tilll yet.
krazykul is offline   Reply With Quote
Old 5th January 2007, 22:34   #165
ECM
ECM's Avatar
GTO....ask your dealer to check AVG bias and here I give you one clue,do you see white color with some black patches on screen and here picture use a to tilt slightly from the top when white color appears?Check and if this is the issue then your AVG is set on high which is a malfunction or a faulty piece of t.v,this happens when you get a very strong signal and your (automatic) AVG is faulty and not reducing the bias feed to I.F section via tuner.Check and respond.
*AVG=Automatic VDO Gain.
ECM is offline   Reply With Quote
Your Favourite Host? (television presenters) Pferdestärke Shifting gears 102 28th December 2012 12:17
Has anyone tried Direct to Car (DTC) using DTH receivers ? StarVegabond In-Car Entertainment 13 9th December 2009 10:14
Civic Hybrid to be only available as a direct company import, not through showrooms. sidindica The Indian Car Scene 15 17th June 2009 13:42
40 inch LCD Television mobike008 Gadgets, Computers & Software 3 16th February 2007 05:03
Dish TV - DTH VMG Gadgets, Computers & Software 7 9th November 2005 15:26
