Old 27th December 2012, 15:56   #1891
k2max6's Avatar
Thanked: 129 Times
As per norm a standard dish takes upto 4 connections be it SD or HD. Although only 2 DVR's run off a single dish as each requires two cables.
Airtel, TataSky & DishTV do the same for MultiRoom connections.
A separate dish is installed only in the case of a separate connection with a separate customer id.
k2max6 is offline   Reply With Quote
Old 17th January 2013, 20:21   #1892
vnabhi's Avatar
Thanked: 1,246 Times
Default Re: Direct-To-Home television in India. Update DTH HD announced
Originally Posted by vasoo View Post
Hathway provides all of them in addition to CNBC Prime HD, Travel XP HD and MTunes HD. And all this for Rs 200 per month. Not sure if there are any more HD channels in India other than this, except the ones from Sun TV group.
I wanted to renew my old Hathway connection and inquired about their HD services. I was told that it would cost me Rs 6500 for the first year including the set top box, and that the prices after one year are still unknown.
Am I being taken for a ride or is this a reality? Can Hathway users please confirm?
I prefer Hathway to other providers as I don't want messy wires from the dish antenna to the TV.
Old 17th January 2013, 23:19   #1893
smsrini's Avatar
Thanked: 268 Times
Infractions: 0/1 (4)
Is it true that tata sky is upgrading their satellite and will be adding 60 additional channels ? And to receive these you need a THIRD cable running from the dish to the he ever ?
Can any one confirm .
Srini
smsrini is offline   Reply With Quote
Old 17th January 2013, 23:39   #1894
Sn1p3r's Avatar
Thanked: 224 Times
How long should a DTH box last? I have a TATA-SKY HD box that is having issues and in 2 years we have max watched 700 hours of TV as its the third TV in house and wasn't used much. It starts and then refuses to show picture for first 15 mins after which it starts working perfectly, then if you power-off to standby using remote it repeats the same issue. Is there something I can do on my own as TS service says to replace the box and they will buy back at ₹ 350 while I paid ₹ 3000 at the time of launch with no fault of ours. Should I go in for exchange with TataSky HD plus? Thanks!
Sn1p3r is offline   Reply With Quote
Old 18th January 2013, 07:54   #1895
vasoo's Avatar
Thanked: 207 Times
I paid Rs 5000 for the HD STB and got another 500 in exchange for the old one. There are no additional charges after that and the monthly charges remain the same, in my case Rs 200 per month.
In your case, is 6500 for both box and one year charges? If that is the case, it looks good. The best option for you will be to get the box and use it for one year. Keep the old SD one with you. If they play prank after that, continue on SD. I notice that here in most apartments I know they don't have a different rental for HD. Not sure about how they do it for individual houses.
vasoo is offline   Reply With Quote
Old 18th January 2013, 08:09   #1896
dre@ms's Avatar
Thanked: 178 Times
Originally Posted by dre@ms View Post
Had a discussion with uhe sun direct guys, they said Sun HD with the box/antenna cost around 2940/-
Since I am already with the SD, they can give me a 500/- discount. Insane!!
But should I opt for it? I have a 40" LCD
As of now I recharge for 200/- PM
What would be the monthly spend if I go for HD?
Think all missed my post. Which HD service is better in terms of quality/service?
dre@ms is offline   Reply With Quote
Old 18th January 2013, 13:30   #1897
vnabhi's Avatar
Sounds like a plan. Thanks for your information. It looks like you are paying Rs 6900 for the first year. Though it may be slightly higher, the yearly charges look attractive in your case.
I might shift the SD box to another room that has a 32" LCD. I was told that I'd need to pay half of monthly charges for SD for it, which works out to Rs 115 approx.
I visited Hathway website and it shows around 8K for HD option. I remember it was 5.5 K or so around 2 weeks back.
Old 18th January 2013, 14:03   #1898
esteem_lover's Avatar
Thanked: 448 Times
I can comment only on Airtel since I am using one. I have a HD recorder and the HD channels are terrific. I bought this for 5,250 in exchange for my old SD receiver.
Cons
1. Removed Star Cricket, ESPN and Start Sports from their HD platform.
2. No Animal Planet HD
3. No provision to transfer the recorded contents to any other media.
4. Recorded programs do not play if you have subsequently removed that particular channel from your subscription.
5. Recorded programs do not play when you experience signal outages like during thunderstorms, rain or strong winds.
I think the Tata Sky is also pretty much the same. Do check out HD channels available with each operator and choose accordingly. Dont trust the asli HD channels, they are SD.
Old 18th January 2013, 14:07   #1899
neofromcapone's Avatar
Thanked: 122 Times
I got a Videcon d2h HD STB, by paying One year's Subscription fees upfront. Its was around 5500/- for the primary connection. In Addition they give me 50 days extra along with it.
The way I see it, NO capex, only monthly fee. Next year when renewal time, I will move freely to the best available offer.
As I will not have an investment stuck in the STB, the box should be reliable for one year at least, and that's the duration of the warranty.
neofromcapone is online now   Reply With Quote
Old 18th January 2013, 14:07   #1900
mmxylorider's Avatar
Thanked: 184 Times
Originally Posted by smsrini View Post
Not confirming, but there could be some merit in what you have heard. Our building has a common dish installed by TataSky and one of their engineers recently came by to do an inspection. On being questioned why, he mentioned that they are trying to determine the capabilities to run additional cables off that dish.
mmxylorider is offline   Reply With Quote
Old 18th January 2013, 14:55   #1901
dre@ms's Avatar
Thanked: 178 Times
Thanks. How much are you paying monthly, for SD and HD? Did you exchange Airtel SD for HD?
Old 18th January 2013, 15:03   #1902
audioholic's Avatar
Thanked: 5,488 Times
Is it true that tata sky is upgrading their satellite and will be adding 60 additional channels ? And to receive these you need a THIRD cable running from the dish to the receiver ?
Seriously? Two cables are required so as to run two different channels parallely, so now unless TATA Sky is planning to enable recording or viewing of three channels parallely, I dont think three cables will be required. If that is true, then people will have a problem with both internal and external wiring. Who would like three fat cables running across the living room, or three cables running in the duct, which is a difficult thing to achieve especially with coaxial cables.
audioholic is offline   Reply With Quote
Old 18th January 2013, 15:07   #1903
sa_kiran's Avatar
Thanked: 161 Times
1. Removed Star Cricket, ESPN and Start Sports from their HD platform. - AVAILABLE ON TATASKY
2. No Animal Planet HD - NOT AVAILABLE ON TS
3. No provision to transfer the recorded contents to any other media. - NOT POSSIBLE WITH TS STB, PIRACY ISSUE
4. Recorded programs do not play if you have subsequently removed that particular channel from your subscription. - I NOTICED IT IN TS 2 YEARS AGO, DON'T KNOW THE CURRENT SITUATION
5. Recorded programs do not play when you experience signal outages like during thunderstorms, rain or strong winds. - THANK GOD, TS STB IS NOT SO DUMB
Based on my experience discussions with friends, I have understood that TS costs a bit more and offers fewer true HD channels. But overall experience is the best of the lot.
sa_kiran is offline   Reply With Quote
Old 18th January 2013, 15:46   #1904
mac187's Avatar
Thanked: 316 Times
That is incorrect.
1. Star Cricket, ESPN and Start Sports available in HD platform.
2. Animal Planet HD is available
3. No provision to transfer the recorded contents to any other media - True
4. Recorded programs do not play if you have subsequently removed that particular channel from your subscription. - Not sure about this.
5. Recorded programs do not play when you experience signal outages like during thunderstorms, rain or strong winds. - False
mac187 is offline   Reply With Quote
Old 18th January 2013, 15:59   #1905
Thanked: 448 Times
Yes, it was for exchange. I have chosen the basic SD package (Rs.208) and selected only the English HD Channels(Rs.91, I think) (Of course they always find a way to squeeze/force in some Hindi Channels). My daily burn rate is Rs.9.98.
Your Favourite Host? (television presenters) Pferdestärke Shifting gears 102 28th December 2012 12:17
Has anyone tried Direct to Car (DTC) using DTH receivers ? StarVegabond In-Car Entertainment 13 9th December 2009 10:14
Civic Hybrid to be only available as a direct company import, not through showrooms. sidindica The Indian Car Scene 15 17th June 2009 13:42
40 inch LCD Television mobike008 Gadgets, Computers & Software 3 16th February 2007 05:03
Dish TV - DTH VMG Gadgets, Computers & Software 7 9th November 2005 15:26
