Old 19th August 2013, 11:51   #2101
dre@ms's Avatar
Thanked: 186 Times
Default Re: Direct-To-Home television in India. Update DTH HD announced
Originally Posted by diyguy View Post
Yes best to call Airtel CC direct. Dish TV offers this reinstall free for certain subscribers (priority or something). Check if Airtel has such a scheme.
Just did some search and was able to get the required details from Airtel website.
The charges for uninstall is 125/- and re-install with the same old dish and STB is 250/- + 12/- per metre cable.
If for new dish and STB, its 600/-
I have decided to remove the dish myself and call up Airtel for re-installation. The same I did for Sun Direct too.
dre@ms is offline   Reply With Quote
Old 19th August 2013, 13:47   #2102
diyguy's Avatar
Thanked: 179 Times
Removing is quite painful too, if the dish has been there for sometime. The legs and bolts etc are usually rusted. Sometimes it is in a risky place for you to reach, so watch out for that. I nearly fell from my terrace one day when I was cutting off branches of a tree that had grown in the line of sight of my dish... having said that, I would do it myself too
diyguy is offline   Reply With Quote
Old 19th August 2013, 15:47   #2103
dre@ms's Avatar
Thanked: 186 Times
Here is the point. I first had Sun Direct fitted. For some reason, all of a sudden it stopped working. Calls to their CC heaped no result. So switched to Airtel. I used the same beam connected to the wall and just replaced the dish alone. So I have all the beam with proper screws brand new with me.
No, my terrace is very open and devoid of any trees and also the beam is fixed in the middle of the terrace on the parapet wall. I will try unscrewing, if not will remove the clamp and remove the rest.
Will update how it went. And thanks for your suggestions and concerns.
Old 24th August 2013, 23:26   #2104
Supercool's Avatar
Thumbs down Re: Direct-To-Home television in India. Update DTH HD announced
Called up TS customer care and even though it was Ramzan, the installation was done in two hours flat after calling. Called at 11:45hrs and the guy arrived at around 13:20 and he was done with his installation by 14:00.
You are lucky my friend that you got TATA Sky installed in two hours. I wasted whole day today just to get TATA Sky installed in NOIDA.
Called customer care and ordered TATA Sky HD in the morning. Payment through credit card. I was informed by customer care executive that TATA Sky will be installed same day. Received SMS from TATA Sky confirming installation today by 4.30 pm. Unfortunately, nobody from TATA Sky came for installation. I called customer care 10 times. As usual, customer care executive was apologetic each time I called and reassured that installation will be done today. What an unprofessional approach. If you cannot deliver you should not promise. I would have ordered Airtel DTH but unfortunately I have already made payment to TATA Sky. Feeling cheated.
I have used Airtel DTH for over three years. Good services. As I like to explore and experiment, thought to go for TATA Sky this time. Very frustrating star of relationship with TATA Sky.
Supercool is offline   Reply With Quote
Old 30th August 2013, 14:14   #2105
VW2010's Avatar
Thanked: 2,121 Times
Videocon is the worst of all DTH when adding new channels. The Star sports 2 is available is my cable tv and Videocon is still not able to add this channel.
La Liga is a goner due to their delay.
VW2010 is offline   Reply With Quote
Old 2nd September 2013, 14:07   #2106
rm_arjuna's Avatar
Thanked: 55 Times
Finally opted for TSHD+ Mega South HD annual pack after sitting on the fence for 1 year , Customer service guys were v.good in clearly all doubts and installation completed in 1.5 hrs after payment . even the installation was done properly and very happy with quality work done .The difference is immense compared to my old STB .have already recorded moto gp and couple of other programs and saves lot of time since you can skip all advts and finish viewing 1/2 hr slot in about 20 mins .
rm_arjuna is offline   Reply With Quote
Old 7th September 2013, 08:00   #2107
vinu_h's Avatar
Thanked: 75 Times
Had a multi-tv HD connection installed yesterday. The newer HD boxes are more compact, quicker and with USB ports that you can store and play from. The primary connection, my 1st HD box from Airtel, is about 2 years old and without trouble. Good job Airtel.
vinu_h is offline   Reply With Quote
Old 11th September 2013, 10:48   #2108
coolclouds's Avatar
Thanked: 514 Times
Can I shift a Sun Direct Kerala connection to Karnataka? What is the procedure for re installation? Does the channel list remain same?
Read an old post (2010) that its possible. Any recent updates?
coolclouds is offline   Reply With Quote
Old 11th September 2013, 22:07   #2109
nareshov's Avatar
Thanked: 165 Times
From http://www.sundirect.in/faq-general.aspx
Q. If one changes his residence or moves to some other city, can he continue to use the same STB and the Dish to receive SUN DIRECT?
A. Yes, please contact our call center for further assistance
nareshov is offline   Reply With Quote
Old 12th September 2013, 12:39   #2110
fine69's Avatar
Thanked: 877 Times
I need some help in deciding the best DTH package as per the below requirements -
1. All English movie & entertainment (star world, axn etc.) channels needed
2. All Hindi channels needed (Sony, Colors, Star Plus etc.)
3. All Infotainment channels needed (Nat geo, Nat geo wild, Discovery etc.)
4. Rest everything is manageable, I mean one or two music channels missing, news channel missing is ok with me - basically I need all channels :P
5. I don't need HD channels as I currently have a 26" LCD tv, only SD channels for now
My monthly budget is not to exceed 450 for subscription (inclusive of taxes).
- Now I'm getting Airtel's Ultra pack at 430 per month, it has almost all channels that I need.
- Dish TV's Super Platinum at 400 per month, it has a couple of english entertainment channels missing like CBS Prime, CBS love etc. The Titanium pack is at 500 so that's a no
- Tata Sky's Mega pack at 5500 per annum (only if I pay the whole year amount at one go, else it becomes 500 a month). Unable to make out what other packages they have that'd fulfill my needs
For now Airtel seems to be the way to go, I live in Lajpat Nagar-1 area but what is surprising is that there isn't a single Airtel dish around. Its either Tata Sky or Dish.
Any comments?
fine69 is offline   Reply With Quote
Old 12th September 2013, 13:48   #2111
VW2010's Avatar
Can you check Videocon for the same. The package is very attractive for the requirement you have mentioned and upgrading or adding another connection is as simple as it can be,
And i can actually say their customer service is pretty good for me. So far no matter when i called they have been able to respond immediately.
Old 12th September 2013, 14:42   #2112
fine69's Avatar
Thanked: 877 Times
Went through the Videocon DTH website and their monthly packages are the most economical for someone wanting the 2nd best package (like me). However, what Dish offered me over phone sounded highly lucrative.
I pay 2449/- (installation + equipment, no other hidden charges) and get an SD Unlimited Recorder along with 750 rupees in account to recharge my monthly subscription pack which is Super Platinum, costing 400 per month. The only 5 channels it does not have is 2-3 sports channels, Discovery Kids and Zee Khana Khazana.
This seems to be the best offer for now. What say?
EDIT: Can someone tell me how much in advance I can set a program to be recorded while I'm away? Also, can I record simultaneously while watching another program? This is particularly for Dish TV SD Recorder.
Old 12th September 2013, 20:56   #2113
fine69's Avatar
Thanked: 877 Times
Finally purchased Tata Sky connection at 2090 with 3 months of Grand Sports Pack (basically 95% of the channels) free. I got 3 months instead of the regular 2 because my organization was listed in the corporate discount offer, there are about 11 companies listed.
Now waiting for the installation guy to book a time and come over. Turn around Time mentioned on the website is between 4-5 days, lets see.
Old 13th September 2013, 11:27   #2114
myavu's Avatar
Thanked: 653 Times
Arrow Re: Direct-To-Home television in India. Update DTH HD announced
After a long wait of 3 years, TATA SKY finally added 19 Malayalam Channels (earlier only 4).
Mohanlal is their new brand ambassador
Note: The channels are available only for MPEG4 boxes
Cheers!
Vinu
myavu is online now   Reply With Quote
Old 13th September 2013, 11:39   #2115
VW2010's Avatar
Videocon DTH - No Start sports 2, no star world premiere (New channel to be launched).
Videocon has good service, good clarity and a good deal.
But lacks in adding new channels..
Your Favourite Host? (television presenters) Pferdestärke Shifting gears 102 28th December 2012 12:17
Has anyone tried Direct to Car (DTC) using DTH receivers ? StarVegabond In-Car Entertainment 13 9th December 2009 10:14
Civic Hybrid to be only available as a direct company import, not through showrooms. sidindica The Indian Car Scene 15 17th June 2009 13:42
40 inch LCD Television mobike008 Gadgets, Computers & Software 3 16th February 2007 05:03
Dish TV - DTH VMG Gadgets, Computers & Software 7 9th November 2005 15:26
