Old 25th March 2015, 18:02   #1
abhi182's Avatar
Thanked: 200 Times
Default DIY: Home Automation
Some of you old timers may remember me as the guy who had setup a full fledged PC in his Corsa for Music/Nav etc back in the era when uttering the word Tablet would lead to a question on what your ailment is
Of course, that whole project is a pointless one now but it had been a while since I had done something substantial DIY-wise..
This time , I diverted the attention of my drill bits and wiring harnesses to my home (much to the chagrin of the lady of the house). Eventually though, she likes what it resulted in :
This was done for rather cheap using off the shelf components and supports any business logic combination you want to use - some examples I
- Send me an alert with Pics if there is motion in Porch but only if its a weekday and time is between 10AM to 7PM
- Switch living room lights 10 mins before sunset with a warm hue if temperature <24C or cool hue if temp >28C
- Dim living room lights to pale blue if a movie is switched on the media center, brighten if paused or stopped
DIY: Home Automation-dommoticz2.jpg
DIY: Home Automation-domoticz1.jpg
DIY: Home Automation-domoticz2.jpg
DIY: Home Automation-domoticz4.jpg
DIY: Home Automation-domoticz6.jpg
DIY: Home Automation-domotticza5.jpg
DIY: Home Automation-domo10_1.jpg
DIY: Home Automation-domo6_1.jpg
DIY: Home Automation-domo4_1.jpg
abhi182 is offline   Reply With Quote
Old 25th March 2015, 18:14   #2
knp
Thanked: 18 Times
Default re: DIY: Home Automation
Interesting work and I believe, it's the right time we talk about home automation.
I'm thinking to do the same and would you please share more details on the hardware, etc?
knp is offline   Reply With Quote
Old 25th March 2015, 18:42   #3
abhi182's Avatar
Thanked: 200 Times
Here you go - Attaching scrshot as text formatting is getting messed up
Old 25th March 2015, 19:03   #4
gautamkhadse's Avatar
Thanked: 153 Times
Dear Abhi ,
Am so glad that this thread came up and you're in pune too . Am in the process of doing up my home and I was initially looking at Philips Hue bulbs which are super expensive . They I shifted to Yeelight by Xiaomi , however its a gamble , getting it from ali express .
Now that I see LIFX and MiLIght . If you ever have time , I'd like to see your setup , just the bulbs . Am relying heavily on these bulbs for mood lighting in my house .
If its not to much to ask can you PM me your contact number . I'd like to have a quick word . Would also like to know where you sourced these from .
gautamkhadse is offline   Reply With Quote
Old 25th March 2015, 19:13   #5
raghu.t.k's Avatar
Thanked: 161 Times
Interesting stuff. I am aware that the upcoming gadgets could be enabled for the internet of things, but how do you do it on the earlier gadgets like the media player ?
raghu.t.k is offline   Reply With Quote
Old 25th March 2015, 19:15   #6
abhi182's Avatar
Thanked: 200 Times
Sure, I haven't used Yeelight so can't comment - although i see they are 6W so the lumen output will probably be low and you may need multiple of these for a single room
The LIFX is highly recommended, very bright (18W) and the color spectrum it can reproduce is far superior to the Hue- Very expensive but worth at least for your living room
The Milight is 9W, does not support white temperature adjustment but is cheap and reasonably bright (around 1200 a pop)
I sourced some from aliexpress but later found a local site (enrg.in) that stocks them
Will PM you my number in just a bit
Fairly straightforward actually
Since the central server and media player (XBMC) are on the same network, the server listens to events on XBMC and can switch a scene on/off based on a play/pause event
Having said that, it will probably not be possible for the really old media players (like a seagate media player I had which had been summarily discarded a long time ago for reasons other than automation)
Old 26th March 2015, 16:50   #7
Default Re: DIY: Home Automation
A Very Nice DIY indeed. This is basically my B.Tech Final Year project that I am continuing right now. What we have implemented till now- Configured the Raspberry Pi to take input from various sensors(Light sensor, Temperature Sensor) through GPIOs and accordingly control relays, LEDs, Air Conditioner etc.
We are presently working on the motion sensor picture alert. Could you please elaborate how you are interfacing the Raspberry Pi with more than 2 cameras. And is the alert feature e-mail based?
satya0721 is offline   Reply With Quote
Old 26th March 2015, 17:49   #8
recshenoy's Avatar
Thanked: 91 Times
Excellent and an inspirational DIY for me. I bought some home automation components a year back but am yet to start the design. Let me resume buying the components and start the design.
How are the images captured? Using jpg camera attached to arduino/Raspberry?
recshenoy is offline   Reply With Quote Received Infraction
Old 27th March 2015, 10:27   #9
abhi182's Avatar
Thanked: 200 Times
The cameras are IP cameras, I missed adding those to the component list
Alerts are via Telegram, On motion detection during office hours, Images are captured and included in the notification
As mentioned above, I am using a bunch of IP Cameras
The Raspberry Pi captures the jpeg stream
Old 27th March 2015, 11:16   #10
::CMS::'s Avatar
Thanked: 464 Times
How are you accessing the cameras outside your home n/w, Static IP or through NoIP or something similar?
::CMS:: is offline   Reply With Quote
Old 27th March 2015, 11:49   #11
itwasntme's Avatar
Thanked: 1,421 Times
Hi, 2 queries:
I have a bunch of D-Link IP cams for monitoring my home and garden when at work or outstation. I use the mydlink portal for this.
Can you recommend a cheapish DVR where I can record the streams? Not really keen for HD quality etc. but just as a recording tool for any untoward incidents.
Secondly, any cheap PTZ camera which you'd recommend? The D-Link ones are very expensive!
itwasntme is online now   Reply With Quote
Old 27th March 2015, 13:22   #12
abhi182's Avatar
Thanked: 200 Times
NoIP and port forwarding on the modem and router to access the full platform
Hi, 2 queries:
No idea about conntinous recoding via DVRs, I instead use motion detection during unexpected hours to simply capture multiple frames
I currently use 3 fixed D-Links Cams (not sure why you say they are expensive- The day versions are around 3-4K online) and 1 generic FOSCAM clone with IR (for night view) and pan/tilt controls for the porch (around 4K on ebay)
The picture quality from the cheap D-Links is far superior to the FOSCAM clone
Old 28th March 2015, 14:49   #13
itwasntme's Avatar
To clarify, the Dlink PTZ ones are expensive. Not the fixed ones, the latter are super VFM!
Old 15th July 2015, 15:20   #14
paras211's Avatar
Thanked: 55 Times
This is very cool. I am doing up my house from the ground up, I would really like some tips and tricks, I am tech challenged, so a lot i do not understand, is there a basic guide or a 101 or something i could read?
Or should I just go with a brand like Creston.
paras211 is offline   Reply With Quote
Old 20th September 2015, 13:37   #15
Thanked: 59 Times
In the last days, I have been playing with an Arduino Uno board and I have a small motion detector built. I now want to get my Arduino connected to the internet and send me notifications on my Android device when my set up detects any changes in its neighbourhood!
I guess I need an Ethernet shield. Could anyone here point me to DIY tutorials that shows me how I could do this? I'm not looking at setting up a Web server on my Arduino, but rather I would just want my Arduino to push those signals to my Android device!
joe1980 is online now   Reply With Quote
Home automation Thread bullock-Car Shifting gears 29 25th April 2017 12:58
Automation: Game of Designing & Building Cars adrian Gadgets, Computers & Software 0 19th February 2014 14:21
Ford Figo DIY for USB cable! How do I DIY? fedexp In-Car Entertainment 51 27th February 2013 21:22
A DIY Story: Home Audio Speaker Boxes in a Car??? Yes!!! hotstuff In-Car Entertainment 14 8th June 2010 12:35
