| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #31 (permalink) |
| BHPian | Airtel has changed all its plans from January 2008. Most plans have added usage limits with some decrease of the free calls. Details vary from state to state which is easily available from their call centres (websites are not yet updated with new changes). Airtel unlimited plans are starting from Rs.750/-. Hi Nikunj, your line disturbance also can be caused by any mobile charger plugged in anywhere close to your modem. Please have a check. I cant use my landphone at all when my mobile is being charged in the same room. Hi Akshay, Tata has the worst service in my area. Remember, BSNL and Airtel have only telecommunication in their business priority. Tata has 100s of things to care for, broadband is just one of their many concerns, so dont expect top-class service. Coming to 8 Mbps plan of airtel, I dont think its available everywhere. Its meant for business class, which involves professional photographers, builders, news reporters, news hubs and similar fields that need huge file transfers in less time. This is what I heard from the sales person. Open for corrections !
__________________ "Woods are lovely, dark and deep. But I have promises to keep and miles to go before I sleep." Robert Frost |
| | #33 (permalink) |
| Team-BHP Moderator ![]() | If you can't use your internet connection when a mobile charger/tubelight/cell phone/TV etc., is on, its a problem. You should get 20dB SNR no matter what. Get your cabling checked if thats not the case. Even with a 5 meter cable running from the jack to my modem, passing close to a tubelight, LCD TV, 2 mobile chargers, a home theater system, I get 30dB SNR. As for undersea cable cut, reliance and Tata are the ones hit. The cable was FLAG telecoms. FLAG is owned by reliance, and the termination station at cochin is Tata's, funny arrangement I must say, but thats how it. Airtel should not be affected as they use the Singapore Cable(Landed at Chennai). AFAIK, Airtel does not use FLAG. Regarding plans, all major bb providers(Tata/BSNL/Airtel) have plans starting from 200rs/month to 50,000/month. Take your pick Too Too low. I am wondering how is your connection working at all. Remove splitter and republish(direct connection to the jack from router)
__________________ My DCMAG Portfolio! Last edited by tsk1979 : 4th February 2008 at 11:20. |
| | #34 (permalink) |
| Senior - BHPian | After connecting the phone line directly to the modem ![]() Everything else was switched off except for the modem and laptop. ![]()
__________________ Prajesh - << will be offline till August >> A true friend is someone who says nice things behind your back... |
| | #35 (permalink) |
| Team-BHP Moderator ![]() | Slight improvement, but it wont help. 11dB is too low. There is something wrong with your line. Get the engineer, and tell them you see this SnR. After that its their job. Was there any digging etc., in your area recently? In ADSL, the lower frequency(upto 4KHz) is used for Voice. Upstream uses 25.875 KHz to 138 kHz, and downstream uses 138-1104KHz. If you notice, you have very strong attenuation in downstream. This indicates antenna loss. Looks like shielding is damaged somewhere, or there is some cable damage etc., which is leading to blockage of high frequencies. IF you have another telephone cable with you, try changing your cable and checking SnR, though I doubt this would help in your case
__________________ My DCMAG Portfolio! |
| | #36 (permalink) |
| BHPian | Quote:
__________________ ------------------------------------- Ford Fiesta 1.6 sxi 2007 WagonR LXi 2001 |
| | #39 (permalink) | |
| Senior - BHPian | Quote:
__________________ Prajesh - << will be offline till August >> A true friend is someone who says nice things behind your back... | |
| | #41 (permalink) | |
| Newbie Join Date: Oct 2007 Location: Secunderabad
| Quote:
Cheers. | |
| | #43 (permalink) |
| Senior - BHPian | The only joint in the whole setup is on the terrace and BSNL guys are saying that moisture depositing on the joint is causing this problem. So they are gonna change the whole wire to avoid the joint..
| | #44 (permalink) |
| Team-BHP Moderator ![]() | Simple joints in a ADSL line!! Thats the craziest thing. Its low even by BSNL standards. But even after wiring change don't give up unless you get SNR of atleast 25dB. With BSNL you have to break your head multiple times. I shifted to Airtel just because of this reason! The BSNL exchange is walking distance from my house. So I used to go there and get lineman personally. In case of airtel, whenever I have made a complaint they have fixed issues within 20 minutes, or sent a technician within 30 minutes if call was made before 5pm.
| | #45 (permalink) |
| BHPian Join Date: Feb 2004 Location: Alleppey, Kerala
| Hi, > But even after wiring change don't give up unless you get SNR of atleast > 25dB. My downstream snr is 8 db and upstream snr is 11.3 db in my BSNL broadband. Browsing is slow since the cable started, otherwise fine. No disconnections. It is MT882 modem
__________________ Rajesh -Marina LS, Oct 05, 43100 (43578) kms, 13.93 kpl -City CVT, Sep 07, 14301 kms, 13.19 kpl |
« Power tools
A 2 second UPS? »
| Thread Tools | |
Similar Threads | ||||
| How To Improve BSNL/MTNL BroadBand Output | finetuning | Gadgets, Computers & Software | 4 | 11th July 2007 17:18 |
| Alternative to BSNL/ Airtel | ajayclicks | Shifting gears | 8 | 20th June 2007 09:57 |
| A question to all BSNL Broadband Unlimited Plan users | adya33 | Shifting gears | 24 | 13th June 2007 19:10 |
| BSNL Broadban @ 2Mbps | abhibh | Shifting gears | 63 | 20th January 2007 21:11 |
| Any BSNL ADSL users here? | tsk1979 | Shifting gears | 2 | 12th July 2005 23:48 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
