Old 20th June 2011, 11:25   #586
rjstyles69's Avatar
Thanked: 795 Times
Default Re: BSNL BroadBand Issues
Originally Posted by Raccoon View Post
You won't get a modem in the market for the price BSNL sells for. I'd suggest you try getting one on rent (mostly they will give you a used one) until they get stock of new modems. Else try to buy one from other exchanges.
Picked up a Dlink : DSL-2730U Wireless N 150 ADSL2+ 4-Port Router from the local vendor here. I got it for a good price.
Now the biggest problem is my download speed. P2P or even rapidshare downloads are capped at 40kbps. I download quite a lot of music from the internet. The damn download speed doesn't go beyond 40kbps even on my 720kbps line.
I am at the end of my wits now, the blokes at BSNL say that this is normal. Am toying the idea of moving to Airtel now. Have already called Airtel and waiting for them to come home and check if they could give me a connection.
rjstyles69 is online now   Reply With Quote
Old 20th June 2011, 12:03   #587
rohan_iitr's Avatar
Thanked: 412 Times
Have you configured port forwarding in the router settings ?
Rohan
rohan_iitr is offline   Reply With Quote
Old 20th June 2011, 12:26   #588
rjstyles69's Avatar
Thanked: 795 Times
Rohan
Port forwarding on the router itself ? If yes I don't think I saw this when I configured it. Otherwise I prolly will have to go back and check on the DNS configuration at 192.168.1.1.
Old 20th June 2011, 14:26   #589
rohan_iitr's Avatar
Thanked: 412 Times
You need to check which ports your P2P programs are using and then open these ports in the router settings (probably in advanced settings tab).
Rohan
Old 21st June 2011, 13:44   #590
sajjt's Avatar
Thanked: 97 Times
I used to surf the net by connecting PC to the BSNL mobile at home. But some times cell phone is not getting connected to the PC showing a message " Acquiring Network Access." continuously as if its on a loop. Normal case this message will flash for a 1-2 seconds and gets the authentication.
If get this message, I have to re boot the PC and cell phone as well. Some times it will connect after the PC reboot. Can any one suggest what could be the reason and what should be done to avoid this?
My cell phone is Samsung Galaxy 3, running on Froyo and using the net by tethering. PC is Dual Core 2GHz, 2GB RAM running on Win XP Prof.
sajjt is offline   Reply With Quote
Old 24th June 2011, 17:27   #591
Raccoon's Avatar
Thanked: 105 Times
Rohan
Its better to try with bridged mode 1st. You may be able to ascertain if there is an issue with the line or the modem/router. The Teracom wired modem+router I had was not able to handle P2P with port forwarding properly.
Old 25th June 2011, 06:37   #592
aaren's Avatar
Thanked: 259 Times
Gentlemen,
I also have a BSNL Broadband connection. Earlier I had a Huawei Wireless Modem/Router (used for almost 5 years) and I got it changed through BSNL to Ericsson Wireless Modem. I used to have Airtel prior to that. My experience is this:
a. BSNL - when it works, it is utterly stable;
b. When you are not getting the connectivity. please note down the downtime and when the bill from BSNL comes, pay the bill; however, give the complaint in writing and get an acknowledgement from the exchange guys. There were many times, due to re-laying of roads at Indore, my internet connection would take a hit. I have got necessary credit in the subsequent bills.
c. The general thing when one raises a complaint, do not shout. It does not help. Tell them with facts and figures (on what dates, for how many hours etc.) that you could not avail of the service. Believe me, it helps in getting your problem resolved without loosing your temper or patience.
d. In my opinion, after dealing with other mobile companies, dealing with BSNL is a lot more easier. In some cases, I have had to take help of my friend who was earlier with TRAI to solve my issues with the companies. Otherwise, these companies do not bother to solve especially your billing issues. I believe Vodafone is an exception.
aaren is offline   Reply With Quote
Old 8th July 2011, 12:45   #593
Awaiting Email Confirmation
Thanked: 4,225 Times
I am a happy and satisfied customer of BSNL broadband [unlimited]+LL combo plan, which is fully suited for my requirement. I also get 20% rebate applicable for working/retired PSU employees. Their customer care is very good.
Yesterday, the settings of my BSNL Nokia Siemens Networks modem got disturbed and displayed 'Authentication Failure'. I tried in vain to reset the user ID and password myself. So, today, I called their toll-free CC number 1800 424 1600 and I was telephonically guided to reset the user ID and password and it works fine now.
J.Ravi is offline   Reply With Quote
Old 19th July 2011, 17:54   #594
dhanushs's Avatar
Thanked: 4,507 Times
Guys, my house is about 6 kms away from the exchange and the service is pathetic. In an hour, I lose DSL atleast once. I'm tired of complaining to the exchange. All the time, they say that my house is too far for uninterrupted service.
Now.. Is there a way to boost the ADSL signal? Is there a booster of some kind?.
Thanks in advance!
Old 19th July 2011, 21:57   #595
rki2007's Avatar
Thanked: 139 Times
I was using BSNL broadband for about 3 years and i had no issues. A couple of times there was a technical fault for which i had to struggle with the authorities and later found them to be too irritating and shifted to Airtel. Until things are good you will have no problem with BSNL. They are not crooks and do not cheat you in anyway like anyother private companies do.
Later was using Airtel for 2.5 years and found the service to be very good and the connection speed was also good. Just a phone call will solve any issues.
Then shifted to the Reliance netconnect plus for wireless access for the laptop. The speed is verybad and it never crossed 0.4 to 0.7 MBPS. But they are very transperant and the data usage details are true.The connectivity is also good and sometimes i get connected in small villages also when i am travelling.
rki2007 is offline   Reply With Quote
Old 19th July 2011, 22:39   #596
devil_klm's Avatar
Thanked: 190 Times
I second your opinion. I got my BSNL broadband connection last month.
When i got my first bill it was 1800+.
I thought there was some error in the bill as i purchased my own modem(My tariff was home unlimited 750+).
Went to nearest customer care office and it was cleared.
out of 1800, 1250 is refundable amount 500 is installation charge(Not thhe installation at home but for the wiring and other setups in the broadband switching center).
was fully satisfied with the explanation given.
I was using reliance broadband before and disconnected it because i shifted to a new place where the service was not available.
it took 10 days for them to collect the equipments from me after disconnecting and in the final bill they charged me for those unused period also.
Tried to call customer care and it was always busy.
Sent a mail and got the reply after 5 days saying i need to pay the amount for unused days also.
Will never go back to reliance.
Last edited by bblost : 20th July 2011 at 08:41. Reason: Fixed the quotes tag. Thanks
devil_klm is offline   Reply With Quote
Old 20th July 2011, 08:23   #597
rjstyles69's Avatar
Thanked: 795 Times
Thanks in advance!
I dont think there is something on the lines of a signal booster and that your house being too far is horse crap being fed to you. Whose is your service provider ?
Old 20th July 2011, 09:05   #598
rki2007's Avatar
Thanked: 139 Times
Thanks in advance!
Let your house be 6 kms from the Telephone exchange. I don't think this is a problem. BSNL normally gives you the telephone connection from the nearest pole close to your house and the broadband connection is activated through the linked telephone line. There is no concept of signal since it is not a dial up connection. As far as the i know there should be some mistake with your modem. I strongly suggest you to meet the Junior Engineer at your respective Telephone exchange and do not talk to the line man or any staff.
Also i suggest you to pay some small amount to the line man and get the connection box ( A small white color box) installed on your house premises compound wall itself. The reason for the same is better connectivity and less disturbance in the telephone line and this may solve your problem.
Old 20th July 2011, 10:10   #599
bhp_maniac's Avatar
Thanked: 111 Times
I think I should agree with the exchange guys there. 6km from exchange means around 81dB (6*13.5dB) of signal attenuation and hence it will affect your SNR value and hence connection stability. For an ADSL link to be called stable, an SNR value of more than 10dB should be there. Please post the connection status from your modem page here. I don't think any ADSL modem can sync at 2MBPS with exchange at that distance with a stable SNR value. But I am sure, the exchange guys can decrease the sync speed at the exchange and solve the issue.
bhp_maniac is offline   Reply With Quote
Old 20th July 2011, 15:01   #600
dhanushs's Avatar
Service Provider is BSNL.
Hi rki2007, The exchange in my hometown is a very small one, and I'm in good terms with my JE. He tried every possible way from the exchange to no avail. We even tried Wi-Max from BSNL, but that too didnt have the required range near my home. Now, JE says, my home is too far, and the lines are old. So, the only solution is replace the whole lines. Thats the reason, I'm asking about a signal booster.
MTNL and BSNL's combo plan for broadband Minardi Shifting gears 35 20th June 2017 19:44
BSNL Broadband Wireless Configuration carboy Gadgets, Computers & Software 69 9th October 2012 23:19
Team-BHP is extremely slow with BSNL-Broadband! SumitB Shifting gears 23 1st August 2010 18:47
How To Improve BSNL/MTNL BroadBand Output finetuning Gadgets, Computers & Software 12 23rd December 2008 16:02
A question to all BSNL Broadband Unlimited Plan users adya33 Gadgets, Computers & Software 28 21st December 2008 20:25
