Old 6th August 2010, 00:28   #136
Ponmayilal's Avatar
^Seagate 1TB Freeagent Go portable USB 2 is available on Global Easy Buy. Cost Rs.12000+.
Just now I ordered a 750GB portable Seagate Freeagent GoFlex for Rs.6460 On GEB. It will be supplied with a USB 2 cable/adapter. The feature of the GoFlex drives is that optional cables/adapters will be available for USB 3, Firewire, esata so that you can upgrade depending upon the available port/s on your machine/s. That is why it is called GoFlex.
The lineup:
Ponmayilal is offline   Reply With Quote
Old 6th August 2010, 15:42   #137
Ponmayilal's Avatar
UPDATE: The Seagate GoFlex Ultraportable 1TB is available from a number of vendors on ebay, India in a priceband Rs.9500 to 10500 while the GoFlex Desk variety costs just about 50% of the ultraportable.
The Seagate Freeagent Gos are therefore a sort of obsolete and one need not look at them any longer. The price I had mentioned in the previous post from the ebay USA vendor ( Rs.12000) seems to be a freak but this is common in U.S.A where you find the same goods cost double and more in the upscale malls and even with some online vendors. So one has to excercise caution when buying on GEB and go through all the listings for a particular item patiently to strike the best deal.
Old 6th August 2010, 18:10   #138
Thanked: 155 Times
1 GB = 1,073,741,824 bytes (not 1,000,000,000)
You are right and wrong!
As per most OS (Windows and some other) 1GB=1,073,741,824 bytes.
But as per ISO standard 1 GB = 1,000,000,000 bytes! Some OS have already migrated to this (like mac)!
RaguHolla is offline   Reply With Quote
Old 7th August 2010, 00:59   #139
Thanked: 658 Times
Its useless to Buy all this adapter based HDD.
When the USB3 becomes main stream, the casing price will go definitely down. And I have not seen dramatic speed with USB3.
Old 7th August 2010, 02:16   #140
Raajiv's Avatar
Just got the Green Drive from Fantom Drives - 1 TB with e-SATA and USB port for 59$ .(after deal)
Raajiv is offline   Reply With Quote
Old 7th August 2010, 10:53   #141
ampere's Avatar
Thanked: 8,760 Times
The standard WD Passport is a good buy! I see many folks vouching for it. I have a 320GB one.
Old 7th August 2010, 10:55   #142
SPARKled's Avatar
Thanked: 325 Times
For real portability get the free agent go seagate external drive. Got myself a 1TB drive. It works with a single usb cable and does not need external power supply. Very fast too.
SPARKled is online now   Reply With Quote
Old 7th August 2010, 11:39   #143
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
What is the price range for Western digital HDD (portable). I am planning to upgrade from my 250 GB WD HDD to a higher capacity one.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 7th August 2010, 13:19   #144
ampere's Avatar
Spike
1TB WD Passport : 8560; 500GB WD 4K
Source : Computer Warehouse (Barton Center)
Old 7th August 2010, 14:21   #145
Ponmayilal's Avatar
Since I have not yet got my 750GB GoFlex and also not equipped with an USB3 port or the adapters, I have to draw upon some of the reviews which have put the GoFlex on test.
CNET Has this to say:
........ but the big speed gains are much more noticeable when you pair the drive with USB 3.0; our anecdotal tests with the Maingear Vybe transferred a 6.62GB file at 70 megabytes per second with USB 3.0 and eSATA, whereas the FireWire 800 reached speeds around 37MB/s on our testbed hardware.
Source: Seagate FreeAgent GoFlex Pro (500GB) External Hard Drive reviews - CNET Reviews
And now a picture from another review:
Source :Seagate FreeAgent GoFlex 500Gb Ultra-portable Drive Review
That said about the transfer speed, it is absolutely one's prerogative
whether he should go for an external casing plus a 2.5" lappy drive of his choice and keep changing his external cases according to his needs when such a need arises
or
one should buy a name-brand external HDD with USB2 and be happy with it for all times
or
one should go for the Goflex with options to change the adapter according to his present and future needs as envisaged by him.
Just to elaborate, my desktop HTPC has USB2, Firwire 800, eSata ports. My Zotac HTPC in the living room has USB2 and eSata ports. The lappy in the home network has only USB2 ports. I also plan to put a USB3 PCIe card on my desktop within months from now making it USB3 capable. (not going to change to a new motherboard with USB3 in the immediate future.) I shall leave the appropriate adapters plugged into these and only shift the HDD as and when required. When the need arises for more TBs I shall buy another one without any adapters - bare GoFlex drives without the adapter are also available.
So the key point is each one according to his needs, present and future.
And for anyone wanting to buy anything my advice will be to go through all the reviews of the ones shortlisted by him or recommended by friends, get to know the pros and cons of each and decide according to his perceptions and needs.
Amen.
Old 7th August 2010, 19:51   #146
I got myself a WD My Book Essentials 1 TB for Rs. 4300/- from S.P. road.
coolfyre is offline   Reply With Quote
Old 4th October 2010, 17:44   #147
cyclops's Avatar
Thanked: 9 Times
Hello! Need to buy an external 2.5 HDD urgently. Interseted in buysing 320 or 500 GB ones.
Please advise on the most reliable brand and the best deals online or local (Pune).
I was keen on getting the Transcend one because of their shock protection feature.
So far never bought one, so help from all would be really appreciated..
cyclops is offline   Reply With Quote
Old 4th October 2010, 19:36   #148
Thanked: 431 Times
I recently got Toshiba Canvio plus 1TB HDD (2.5") from US for 129 USD (~6k). It is quite silent and unlike Seagate doesnt heat up even on continuous use for days! Extremely satisfied. I had sourced it thru a relative returning from US. Had bought it from Amazon.com
joslicx is offline   Reply With Quote
Old 5th October 2010, 10:45   #149
cyclops's Avatar
Thanked: 9 Times
Thanks for the advise. I never thought of Toshiba as an option. Will consider that as well. But I need to buy it locally..
Guys, I was preferring transcend due to its shock protection feature. Does it really works? Or is its just some marketing gimmick? I also got to know seagate comes with a 5 year warrantly, which is impressive..
Please advise..
Old 5th October 2010, 11:34   #150
sgiitk's Avatar
Thanked: 3,794 Times
Infractions: 0/1 (5)
I think all major brands WD, Seagate, Transcend, etc. are equally good. It is more a matter of bad luck if a unit fails. Many of them have a three year replacement warranty as well.
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 705 17th January 2018 13:43
Portable Jump-Start Packs rameshspassion Technical Stuff 6 4th January 2015 11:54
Ipod to portable HDD Data Transfer viper Gadgets, Computers & Software 5 26th April 2008 14:39
Which is the best SONY model HDD Handycam sathyaprakash Gadgets, Computers & Software 0 11th November 2007 17:42
Smallest portable nokia charger amit1101 Gadgets, Computers & Software 18 30th March 2006 08:26
