Old 27th September 2012, 19:38   #196
Thanked: 49 Times
Default Re: Which Portable HDD ?
An awesome deal if someone can buy one in the US - http://www.compusa.com/applications/...&sku=S130-9006
CrackedHead is offline   Reply With Quote
Old 27th September 2012, 23:54   #197
allauddin's Avatar
Originally Posted by Guite View Post
Thanks for the tip on partition and encryption. A few questions:-
1. Do you encrypt first and copy to external HDD, or the encryption process output can be directed to write to external HDD? What is the encryption output:- one single chunk of file or each individual files with same name and extension as original?
Plase follow the tutorial link provided here
http://www.truecrypt.org/docs/?s=tutorial
The tutorial is for creating VOLUME based file, which is not good, It will create a big file in your system, instead I suggest carete non-system partition/drive
This drive is always hidden and very secure.
Even a data recovery professional agencies cannot retrieve data from these kind of file systems, so be careful in case if the HDD gives any issue you cannot recover data by any method.
Once you create this encrypted volume then you can mount the volume whenever you want to using the given password while creating the volume.
After mounting the volume , you can use that Partition like any other partition, just open the folder , copy files that's it.
2. How do you prevent a TV or media player search through one partition?
If you wish to prevent TV or media player search through a partition, convert the parition to NTFS file system, most of the TVs and Media players will not be able to read NTFS file systems, but your computer can read NTFS file system.
allauddin is offline   Reply With Quote
Old 28th September 2012, 23:13   #198
Guite's Avatar
Thanked: 187 Times
Thanks for the tips. I thought the easy way out for me is to go for NTFS partition. However upon checking up I founf that my external HDD is already NTFS and my TV is reading confortably from it. Not surprising because the TV media player supports MTS and other full HD videos, so it couldn't be constrained by FAT32 file size limit.
So I will either have to go for tedious volume encryption or new HDD. If you do volume encryption how do you add new files to the volume?
Guite is offline   Reply With Quote
Old 29th September 2012, 01:20   #199
allauddin's Avatar
You are right, if your TV is able to play mkv files, then it would read NTFS partition.
Once you encrypt the volume, by default it will not be visible in the system.
To access the partition, first you will need to launch Truecrypt
Select any drive letter from the list it shows ( It will default to the drive letter last used )
use the automount button, it will prompt for password, once you give correct password the drive letter gets added to your file system.
Now you can go back to windows explorer and use that drive letter partition like any other partion. copy paste files like the way you do in your normal HDD.
One more simple file management utility I found is QDIR. Always check the files for viruses.
Old 29th September 2012, 10:13   #200
Thanked: 285 Times
Originally Posted by mukeshgoel View Post
Yes, it will work. I have been using a 2TB HDD with USB 2.0 and USB 3.0 on different computers.
At tradus, they have the following categories in 'refine your search'
http://www.tradus.com/hard-disk-driv...apacity=500+gb
USB2
USB3
USB 2/3
Sata
What's the USB 2/3 category?
carboy is online now   Reply With Quote
Old 29th September 2012, 10:45   #201
mukeshgoel's Avatar
Thanked: 387 Times
USB2
USB3
USB 2/3
Sata
USB3 and USB 2/3 is same.
They have categorized it just the manufactures specifications without using their own brain.
For example, I picked up this from USB 3.0 category and in the description, you will see that "It has backward compatibility with USB 2.0".
www.tradus.com/wd-my-passport-essential-500gb-usb-30/p/PDR0000004757528
mukeshgoel is offline   Reply With Quote
Old 12th October 2012, 15:50   #202
Thanked: 285 Times
I am looking for an external disk mainly for storing software installers and backup my laptop. I am not sure whether I should go for 500 GB or 1TB - 500 GB should be enough but if there is not a heavy price diff, should I go for 1TB? What brands are good? And what features should I look for?
I got a Transcend 500 GB USB 3.0 drive.
I have a few questions
1) There are 2 usb jacks you connect to your Laptop - one for power & one for the actual connection. Does it make any diff which you connect first - i.e. should you first connect the thin one & then thick one - or does it make no diff.
2) Do you guys use the HDD as is or do you first format it as NFTS - i think by default it comes with FAT32.
3) What do you use for Backups - do you use windows backup or any other software? Transcend has this - http://www.transcend-info.com/Suppor...=3&Func2No=205 - I was wondering if it's any good?
Old 22nd November 2012, 13:57   #203
drmohitg's Avatar
Thanked: 3,874 Times
Hey guys I am looking to buy a 1TB external HDD. I am confused between WD and Seagate. Price wise Seagate looks to be costlier by 500 Rs ( figures taken from Flipkart). Which one should I purchase?
drmohitg is offline   Reply With Quote
Old 22nd November 2012, 18:46   #204
Sn1p3r's Avatar
Thanked: 230 Times
No difference. And try connecting only single USB, it might be the USB2 and USB1. In my device single USB powers the drive.
Windows auto detects and you do not have to make adjustments if you are going to use it with your computer. However, certain devices (media players) need FAR32 only and thus you need to format it accordingly.
[/quote]
3) What do you use for Backups - do you use windows backup or any other software? Transcend has this - http://www.transcend-info.com/Suppor...=3&Func2No=205 - I was wondering if it's any good?[/quote]
I just copy and paste the data I want to backup. Windows Autobackup is good enough if you want to backup the complete computer. If my windows crash, I get it going from scratch rather than from backup. Your choice.
Buy the one with higher RPM speed and with USB 3.0 if available. Cheers!
Sn1p3r is offline   Reply With Quote
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 733 26th July 2018 16:27
Portable Jump-Start Packs rameshspassion Technical Stuff 6 4th January 2015 11:54
Ipod to portable HDD Data Transfer viper Gadgets, Computers & Software 5 26th April 2008 14:39
Which is the best SONY model HDD Handycam sathyaprakash Gadgets, Computers & Software 0 11th November 2007 17:42
Smallest portable nokia charger amit1101 Gadgets, Computers & Software 18 30th March 2006 08:26
