Old 7th June 2007, 12:29   #61
Thanked: 294 Times
Originally Posted by Mugen_Power View Post
isnt 3.5 inch hdd are cheaper than 2.5 inch hdd ??
ya 3.5 inch is cheaper than the 2.5 inch but the capacity of 3.5 is quite large when compared to the 2.5 inch one....and the 3.5 inch is also heavier than the 2.5 inch one.
Old 7th June 2007, 12:37   #62
Thanked: 11 Times
Originally Posted by revtech View Post
its not tht slow.... i have a hitachi 160 GB HD in a transcend casing and ii love it....
as far as i know Seagate's data transfer is 61mb per second when compared to hitachi's 56mb per second but hitachi runs cooler than seagate.
Mugen_Power is offline   Reply With Quote
Old 7th June 2007, 13:06   #63
zakaaaaasss's Avatar
rev how much did u grabbed the 160gb Hitachi for?
zakaaaaasss is offline   Reply With Quote
Old 7th June 2007, 13:17   #64
Thanked: 294 Times
Rs 2400 approx....but the best bet is the 250 gb which is in 3200 range.....
Old 7th June 2007, 13:19   #65
thanks lbm....will have a look at that...
are there any specifics that i need to see before buying the HDD and Transcend casing? maybe your tips
Old 7th June 2007, 13:22   #66
Thanked: 294 Times
nothing much is there.....so get the casing and the HDD and enjoy Backing up your PC....
Old 7th June 2007, 13:27   #67
Thanked: 11 Times
Just make sure that you buy Sata2 hdd and Sata2 Usb casing.
Get a Transcend Usb2 Storejet 3.5. It supports upto 750gb hdd and will cost you approx 1700.
Old 7th June 2007, 13:32   #68
as i understand from above discussion, the 3.5 will need extra power supply, isnt it? i need one without power adaptor
will the 2.5" ones (both HDD and Transcend casing) will have sata2 ? i have Dell Inspiron 5100
Old 7th June 2007, 13:38   #69
abhibh's Avatar
Thanked: 34 Times
Ok So for internal HDD hitachi is good too ?
Old 7th June 2007, 13:41   #70
hydrashok's Avatar
l_b_m, could you post pics of your HDD & casing, please? Is it like a slot-in & plug-in job, setting up the HDD in the casing? I mean, I'd like to set this up, but without too much of uh... trouble
Old 7th June 2007, 13:47   #71
u can see few pics here (the last one shows how to put the HDD into the casing
Transcend 2.5" Portable Hard Drive Casing
Old 7th June 2007, 13:51   #72
Thanked: 11 Times
As far as i know you will have to buy 80gb 2.5 inch hdd if you want run the hdd with single cable.
Old 7th June 2007, 13:56   #73
hydrashok's Avatar
Thanks, buddy! That's easy as pie
Old 7th June 2007, 14:01   #74
Thanked: 294 Times
hmm right now in mumbai....so cannot post pics...
Guys guy you all are mixing the 2.5 with the 3.5 one...
normal 2.5 ide interface one...
Welcome to Transcend Website - StoreJet 2.5 S/B/R/T
2.5 inch sata casing
Welcome to Transcend Website - StoreJet 2.5 SATA S/B/R/T
3.5 inch sata casing
Welcome to Transcend Website - StoreJet 3.5
Old 8th June 2007, 00:41   #75
revtech's Avatar
Thanked: 35 Times
i got the hard disk for 6500 and the transcend casing for 700 so the total was 7200.by the way this is the 2.5 inch HD which DOES NOT need the external power supply.
Rev
revtech is offline   Reply With Quote
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 731 19th July 2018 12:33
Portable Jump-Start Packs rameshspassion Technical Stuff 6 4th January 2015 11:54
Ipod to portable HDD Data Transfer viper Gadgets, Computers & Software 5 26th April 2008 14:39
Which is the best SONY model HDD Handycam sathyaprakash Gadgets, Computers & Software 0 11th November 2007 17:42
Smallest portable nokia charger amit1101 Gadgets, Computers & Software 18 30th March 2006 08:26
